  3. Will a NRF24L01+PA+LNA help with my signal problems
17 Posts 4 Posters 4.0k Views 5 Watching
  • G GreyLinux
    @mfalkvidd
    Thanks for the reply, I've just noticed the fine print ( If you are using the nrf24 PA/LNA version you need to use a 5V->3.3V regulator because the Raspberry Pi 3.3V can't supply enough power.
    Is this what it refers to here?
    out of interest how do I connect this inline from the 5v pin to radio 3.3v pin ? I notice that the link suggests 2 x 10 uF capacitors either side of the regulator . What I'm asking is how best to wire this up with the Raspberry pi pins, the radio , the capacitors and the regulator .
    thanks for you help .
    @greymarvel yes, the LD1117-3.3 will work fine.
    https://www.mysensors.org/build/connect_radio#connecting-a-voltage-regulator describes how to connect a voltage regulator.
    https://www.mysensors.org/build/connect_radio#connecting-a-decoupling-capacitor describes how to connect a capacitor.
    G 1 Reply Last reply
      G
      G
      GreyLinux
      @mfalkvidd thanks for all your help, I really should of read that page a lot more carefully and maybe i wouldnt of missed those two explanations .
      • G GreyLinux
        @greymarvel no worries. There is a lot of information to take in :)
        Don't be afraid to ask more if things are unclear.
        • ThucarT
          ThucarT
          Thucar
          @Greymarvel for a gateway I would suggest using a shielded version of the NRF24L01+PA+LNA as well as this supply adapter
          I was having world of issues with my setup until I did that.
          Controller: Node-Red
          Gateway: SerialGateway & GSMMQTTGateway
          MySensors: 2.2.0
          • ThucarT Thucar
            G
            G
            GreyLinux
            @thucar
            yeah I read somewhere that unshielded the NRF24L01+ was awful . The socket adapter you linked what is the benefit of using it ? Is it meant to replace the regulator and make a better connection for the radio ?
            • ThucarT
              ThucarT
              Thucar
              I has an onboard voltage reg as well as caps. So you do not need to use any additional hardware.
              MySensors: 2.2.0
              • ThucarT Thucar
                G
                G
                GreyLinux
                @thucar
                that is brilliant I will be getting one of these anything to make life easier . Thanks for your help
                  G
                  G
                  GreyLinux
                  wrote on last edited by GreyLinux
                  @mfalkvidd I need your advice regarding the radio's on my Arduino nodes . I've wired the power for the radio to vcc on the Arduino which is boosted by a 3.3v step up booster .
                  I have a decoupling capacitor between the vcc and Gnd of the radio but I think my limited range is because of the noise from the booster . If I wire the power of the radio directly to the battery the radio fails completely as seen in the serial monitor . What are my options ?
                  Should I used one of the adapters recommended by @Thucar on all my battery sensors ?
                  • G GreyLinux
                    @greymarvel people here are using different solutions. My preferred way is to power the Arduino and the nrf24 directly by 2xAA, with a 4.7uF capacitor as close to the nrf24 as possible (between vcc and gnd). No step-up, no ldo.
                    I like this solution because it involves very few components, which means less things that can go wrong and easier troubleshooting if something does go wrong.
                      G
                      G
                      GreyLinux
                      @mfalkvidd
                      is it possible for me to remove the booster if I've removed the regulator on the pro mini?
                      How long do your sensors last without a booster ?
                      Why do you think my radio's fail when I power them straight from the battery ? Cheap clones maybe ?
                      • G GreyLinux
                        @mfalkvidd
                        @greymarvel said in Will a NRF24L01+PA+LNA help with my signal problems:
                        @mfalkvidd
                        Yes. See https://www.mysensors.org/build/battery for more information
                        About 10 years
                        It could be anything.
                          @mfalkvidd
                          About 10 years
                          G
                          G
                          GreyLinux
                          @mfalkvidd
                          you sir are amazing , I soldered the 47uF capacitor practically on the radio and now I'm getting about 10 metres before I get Nack=0 messages . Hopefully with the addition of the NRF24L01+PA+LNA on the gateway I should be able to cover all of the property.
                          Thank you so much again for your help .
                          • ThucarT
                            ThucarT
                            Thucar
                            wrote on last edited by Thucar
                            @Greymarvel for me that 47uF cap is essential whenever I'm not using the full adapter I suggested for your gateway.
                            I'm getting over 30 meters through two 35cm concrete walls and some trees with the following setup: Gateway with a shielded nRF24L01-PA-LNA (not DIY foil shielded, but proper shielded one) and the forementioned adapter.
                            Solar + battery powered sensor with the basic nRF24L01 (PCB antenna) the only booster is that 47uF cap on the radio power pins.
                            MySensors: 2.2.0
                            • TmasterT
                              TmasterT
                              Tmaster
                              Hi to @Greymarvel .Well i already seen this movie before. I bought diferent nrf24 nodes,amplifed ,not amplified,with or without capacitors. In fact i had worst redults with amp nodes. I just change to rfm69hw and w
                              . No more low power/high power...etc. now i got my 4000m2 terrain covered (around 80m long).
                              I didn't check max range but i never had lost a packet again. I was a very good increment on my network stability.
                              That fake nrf24 chips are crazy and unstable and yes,all ebay cheap nodes are fake second i know.
                              i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                              12.5k
