1.1k Posts 105 Posters 792.8k Views 98 Watching
    did you cut the compile time of the gateway?
    @gohan yes?
    gohanG 1 Reply Last reply
      @gohan yes?
      @mfalkvidd on my Pi3 it takes 40 around seconds, are you using an old Pi1 ?
        @gohan no, I'm using a Pi3.
        • mfalkviddM
          Today I finally got my thumbs out and upgraded my plant monitoring to MySensors 2.x (from 1.x).
          Updated sketch is available on Github: https://github.com/mfalkvidd/arduino-plantmoisture
          Result: I really need to water my plants ;-) But the 2.5 year old batteries are still going strong.
          maghacM 1 Reply Last reply
          • sundberg84S
            sundberg84S
            Tonight some more PCB design:
            dbemowskD 1 Reply Last reply
            • sundberg84S sundberg84
              dbemowskD
              dbemowskD
              @sundberg84 I will throw my two cents in on the design. An issue that I had brought up on previous revisions had to do with capacitors. On the Rev 9 and below boards, your capacitor footprints were pretty much all for flat ceramic capacitors. While I was able to make it work for the couple can style electrolytics that I used, it wasn't quite right. Now on this revision, I see that all of your capacitors have a can electrolytic style footprint. I think it needs to be a mix. The 4.7uf and 10 uf capacitors should be can style footprint, whereas your 0.1s should be non polarized ceramic flat cap footprints. The flat pack ceramics I think have a wider hole spacing.
              Again, just my two cents
              • dbemowskD dbemowsk
                sundberg84S
                sundberg84S
                #465
                @dbemowsk the positive with polarized footprint is that you can use both and it's very easy for a newbie to see which one is Gnd. You who are more experienced can determine if you want to use a flat unpolarized cap.
                • mfalkviddM
                  This evening I spent a few hours finding more MySensors keywords that exist but weren't highlighted.
                  I found about 20 that were documented but not highlighted, so I added them.
                  I also found 3 that weren't documented nor highlighted. I have created issues on github to document them. Help is welcome. Documenting the keywords is an easy way to contribute to the project.
                  https://github.com/mysensors/MySensors/issues/1090
                  https://github.com/mysensors/MySensors/issues/1089
                  https://github.com/mysensors/MySensors/issues/1088
                    dbemowskD
                    dbemowskD
                    @sundberg84 one of the 0.1uf caps that i use has short leads and wouldn't fit that hole spacing. They are higher voltage capacitors that i bought years ago for another project that i am trying to use up. I do see your point though.
                      maghacM
                      maghacM
                      maghac
                      @mfalkvidd said in What did you build today (Pictures) ?:
                      What kind of components is this running on? I am having trouble getting my batteries to run even 2.5 months (or 2.5 weeks for the outside temp sensor...) :)
                      • maghacM maghac
                        #469
                        @maghac see the link in my post for full details. But basically it is just what's recommended on the battery page. Arduino pro mini with power led and ldo removed, bod set to 1.8V, powered by 2xAA.
                          sundberg84S
                          sundberg84S
                          • ThucarT
                            ThucarT
                            Thucar
                            Controller: Node-Red
                            Gateway: SerialGateway & GSMMQTTGateway
                            MySensors: 2.2.0
                            dirkcD 1 Reply Last reply
                            • ThucarT Thucar
                              dirkcD
                              dirkcD
                              dirkc
                              wrote on last edited by dirkc
                              #472
                              @thucar what display do you use and where did you buy it? What library did you use?
                              Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
                              • ThucarT
                                ThucarT
                                Thucar
                                wrote on last edited by Thucar
                                #473
                                @dirkc the display is a JLX12864-378 off a chinese “component tester” kit I had available. Using the u8g2 library to run it.
                                MySensors: 2.2.0
                                • sundberg84S
                                  sundberg84S
                                  #474
                                  Today I built a led dimmer and motion detector for my kitchen. Running on 12v and a led list of about 2m.
                                  Everything is built on my MysX led board and it was so easy to assemble everything and it's really small.
                                  I have documented this project and will show you in a video when edited.
                                  • SpannersS
                                    SpannersS
                                    Spanners
                                    wrote on last edited by Spanners
                                    #475
                                    Today I built a new Ethernet Gateway.
                                    Using a Freetrionics Ethermega - Fixed SPI bus, so no soft SPI and I can use MY_RX_MESSAGE_BUFFER_FEATURE. PoE, improved voltage regulator design so I can run the amplified NRF24 with MY_RF24_PA_LEVEL RF24_PA_HIGH.
                                    Under the radio is a small prototyping area with capacitor for the radio and an ATSHA204A - because one day I swear I will implement signing.
                                    Slightly modified Gateway sketch that writes successful DHCP IP addresses to EEPROM. I assign a static address on my router. If there's a power failure, the gateway will start up with last address - router takes ages to come online.
                                    Fired up the X-carve to cut the aluminium chassis, which has added benefit of shielding the NRF radio as well. The complicated cutout on the front was to allow air intake for the fan. Was supposed to just be a grille, but after a couple of beers I got too cute for my own good. Took 2 hours to cut that. :)
                                    • sundberg84S
                                      sundberg84S
                                      A video of my Ledstrip project in the kitchen:
                                      https://www.youtube.com/watch?v=SdD6Ozf80bk&t=7s
                                      • kalinaK
                                        kalinaK
                                        kalina
                                        Today I have finished work on control center for my smart home. The box includes a Raspberry Pi 3, gateway, ethernet switch, power supplies 5V and 9V. Audio input jack, ethernet and AC line cabels out from the box. Maybe, a GSM module should be included to the free space too (i will thinking about...). I am going to install this box in the near future.
                                        S 1 Reply Last reply
                                        • kalinaK kalina
                                          sindrome73
                                          @kalina said in What did you build today (Pictures) ?:
                                          ione di installare questa scatola
                                          if I can know !! The audio socket what is it for ???
                                          kalinaK 1 Reply Last reply
