  2. Announcements
  • MasMatM MasMat
    @marceloaqno What does your mosquitto.log show?
    So is this normal?
    marceloaqno
    Code Contributor
    @masmat This is my mosquitto.log
    1521680648: mosquitto version 1.4.10 (build date Fri, 22 Dec 2017 08:19:25 +0000) starting
    1521680648: Config loaded from /etc/mosquitto/mosquitto.conf.
    1521680648: Opening ipv4 listen socket on port 1883.
    1521680648: Opening ipv6 listen socket on port 1883.
    1521762617: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
    1521763549: New connection from 127.0.0.1 on port 1883.
    1521763549: New client connected from 127.0.0.1 as mygateway1 (c1, k15, u'rpi').
    A socket error message:
    1521764339: Socket error on client mygateway1, disconnecting.
    shows only if I stop/exit mysgw.
    MasMatM 1 Reply Last reply
    • M marceloaqno
      MasMatM
      MasMatM
      MasMat
      @marceloaqno OK, I will look into that once I have an extra sensor feeding my gw (the one I built is a little complex and could be buggy).
      Another question: I configured mysgw without "simple password" to sort out problems.
      Now to reconfigure mysgw I have to run the "./configure --blah --blahblah..." command and "make", but do I also have to do "make install"? And do I have to re-start & enable the service? Should I stop it first also? Anybody got a step-by-step for this?
        You could also make a simple node running mock mysensors sketch that can simulate a working sensor, if you need some data running through the gateway. When I recompile the gateway I usually stop the service, uninstall the mysgw service and do the make and make install. I don't really know if it is actually required but I like to keep things clean
        M MasMatM 2 Replies Last reply
          marceloaqno
          Code Contributor
          The two patches to fix ethernet stability have been merger into the development branch, and also some changes to the gateway logging. I updated the build instructions to reflect the changes.
            MasMatM
            MasMatM
            MasMat
            wrote on last edited by MasMat
            #868
            @gohan I made a sensor that sends DHT11 temp+hum. This is the output (some of it..) from mosquitto_sub to topic mysensors-out. So I appear to have a something working. OpenHab2 is not finding any items still...
            pi@DietPi:~ $ mosquitto_sub  -u XXXXXX -P YYYYYY -v -t 'mysensors-out/#'
            mysensors-out/99/1/1/0/0 14.0
            mysensors-out/99/0/1/0/1 46.0
            mysensors-out/99/1/1/0/0 15.0
            mysensors-out/99/0/1/0/1 45.0
            mysensors-out/99/0/1/0/1 44.0
            Once I changed the config to include simple password, it's not showing anything anymore in mosquitto_sub
            It would appear that something is missing from my setup or there's a bug in the configure-line. Can someone tell if there's a bug here somewhere:
            sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXXXX --my-mqtt-password=YYYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
              Look also in node log, that's the first place to look at
                MasMatM
                MasMatM
                MasMat
                #870
                @gohan I did, I will post it (but it appears to send normally). But the only things I changed was:
                1. Rpi configure added: --my-signing=password --my-signing-password=ZZZZZZ
                2. In the nodes code: #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
                AnticimexA 1 Reply Last reply
                  I use also these parameters with the normal signing
                  --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug
                  of course the debug parameter is there only for debug reasons
                  • MasMatM MasMat
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @masmat check that the version you are using (release or beta) match your use of the simple flags, as they differ at the moment.
                    • AnticimexA Anticimex
                      MasMatM
                      MasMatM
                      MasMat
                      #873
                      @anticimex Both Arduino IDE is 2.2 and Rpi is compiled with 2.2 stable.
                      I'm seeing !TSF:MSG:SIGN FAIL in the serial monitor so something is not compatible... I will try making password >8 characters next (currently 6).
                      I will also add those parameters to see if that makes a difference before reuploading arduino code
                      • MasMatM MasMat
                        AnticimexA
                        AnticimexA
                        Anticimex
                        #874
                        @masmat if you add the signing debug flag and use the log parser on the homepage it should become clear what the problem is. You can also use the troubleshooting guide in the signing documentation.
                        • MasMatM
                          MasMatM
                          MasMat
                          @anticimex This is what's happening in the gw:
                          TSF:MSG:READ,36-192-15,s=69,c=0,t=81,pt=1,l=21,sg=0:221
                          !TSF:MSG:LEN,16!=28
                          TSF:MSG:READ,75-68-77,s=48,c=1,t=110,pt=1,l=25,sg=1:249
                          !TSF:MSG:LEN,16!=32
                          The parser didn't really help much: more baffled than before....and I came away from the troubleshooting guide feeling really stupid :)
                          • MasMatM MasMat
                            !TSF:MSG:LEN,16!=28
                            !TSF:MSG:LEN,16!=32
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @masmat looks to me that your gateway is not set up for signing
                            gohanG 1 Reply Last reply
                              @anticimex I think he didn't use all the parameters for the configure, right?
                              AnticimexA MasMatM 2 Replies Last reply
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @gohan the simple flags should not need more args, but I don't use a rPi as gw so I honestly am not sure exactly the args to use. The beta documentation has clear instructions for rPi signing, but those are specifically for beta branch and probably don't map exactly to the release yet.
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  #879
                                  @gohan The whole configure-line:
                                  sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                                  If anyone can tell what's missing or if there's a typo?
                                  • MasMatM MasMat
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @masmat https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html
                                    • MasMatM MasMat
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      #881
                                      @masmat you have redundant flags. The password option require no other signing flags. Only if you select software as signing backend you need other options (and none of the simple flags)
                                      And remember that if you use software signing and not password signing, you need to personalize the GW and/or node.
                                        MasMatM
                                        MasMatM
                                        MasMat
                                        #882
                                        @anticimex I thought so too, but I'm grasping at straws to get the signing to work.
                                        To clarify, is the following enough for simple signing: --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ
                                        And the arduino code #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
                                        Any difference where it's placed in the code? Anything else to check for?
                                        • MasMatM MasMat
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @masmat it needs to be defined prior to the inclusion of mysensors.h. That should be it. (on the arduino node that is).
