  2. Announcements
    You could also make a simple node running mock mysensors sketch that can simulate a working sensor, if you need some data running through the gateway. When I recompile the gateway I usually stop the service, uninstall the mysgw service and do the make and make install. I don't really know if it is actually required but I like to keep things clean
    MasMatM
    MasMatM
    MasMat
    wrote on last edited by MasMat
    #868
    @gohan I made a sensor that sends DHT11 temp+hum. This is the output (some of it..) from mosquitto_sub to topic mysensors-out. So I appear to have a something working. OpenHab2 is not finding any items still...
    pi@DietPi:~ $ mosquitto_sub  -u XXXXXX -P YYYYYY -v -t 'mysensors-out/#'
    mysensors-out/99/1/1/0/0 14.0
    mysensors-out/99/0/1/0/1 46.0
    mysensors-out/99/1/1/0/0 15.0
    mysensors-out/99/0/1/0/1 45.0
    mysensors-out/99/0/1/0/1 44.0
    Once I changed the config to include simple password, it's not showing anything anymore in mosquitto_sub
    It would appear that something is missing from my setup or there's a bug in the configure-line. Can someone tell if there's a bug here somewhere:
    sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXXXX --my-mqtt-password=YYYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
      Look also in node log, that's the first place to look at
      MasMatM 1 Reply Last reply
        MasMatM
        MasMatM
        MasMat
        #870
        @gohan I did, I will post it (but it appears to send normally). But the only things I changed was:
        1. Rpi configure added: --my-signing=password --my-signing-password=ZZZZZZ
        2. In the nodes code: #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
        AnticimexA 1 Reply Last reply
          I use also these parameters with the normal signing
          --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug
          of course the debug parameter is there only for debug reasons
          • MasMatM MasMat
            AnticimexA
            AnticimexA
            Anticimex
            @masmat check that the version you are using (release or beta) match your use of the simple flags, as they differ at the moment.
            • AnticimexA Anticimex
              MasMatM
              MasMatM
              MasMat
              #873
              @anticimex Both Arduino IDE is 2.2 and Rpi is compiled with 2.2 stable.
              I'm seeing !TSF:MSG:SIGN FAIL in the serial monitor so something is not compatible... I will try making password >8 characters next (currently 6).
              I will also add those parameters to see if that makes a difference before reuploading arduino code
              • MasMatM MasMat
                AnticimexA
                AnticimexA
                Anticimex
                #874
                @masmat if you add the signing debug flag and use the log parser on the homepage it should become clear what the problem is. You can also use the troubleshooting guide in the signing documentation.
                • MasMatM
                  MasMatM
                  MasMat
                  @anticimex This is what's happening in the gw:
                  TSF:MSG:READ,36-192-15,s=69,c=0,t=81,pt=1,l=21,sg=0:221
                  !TSF:MSG:LEN,16!=28
                  TSF:MSG:READ,75-68-77,s=48,c=1,t=110,pt=1,l=25,sg=1:249
                  !TSF:MSG:LEN,16!=32
                  The parser didn't really help much: more baffled than before....and I came away from the troubleshooting guide feeling really stupid :)
                  • MasMatM MasMat
                    !TSF:MSG:LEN,16!=28
                    !TSF:MSG:LEN,16!=32
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @masmat looks to me that your gateway is not set up for signing
                    gohanG 1 Reply Last reply
                      @anticimex I think he didn't use all the parameters for the configure, right?
                      AnticimexA MasMatM 2 Replies Last reply
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @gohan the simple flags should not need more args, but I don't use a rPi as gw so I honestly am not sure exactly the args to use. The beta documentation has clear instructions for rPi signing, but those are specifically for beta branch and probably don't map exactly to the release yet.
                          MasMatM
                          MasMatM
                          MasMat
                          #879
                          @gohan The whole configure-line:
                          sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                          If anyone can tell what's missing or if there's a typo?
                          • MasMatM MasMat
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @masmat https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html
                            • MasMatM MasMat
                              AnticimexA
                              AnticimexA
                              Anticimex
                              #881
                              @masmat you have redundant flags. The password option require no other signing flags. Only if you select software as signing backend you need other options (and none of the simple flags)
                              And remember that if you use software signing and not password signing, you need to personalize the GW and/or node.
                                MasMatM
                                MasMatM
                                MasMat
                                #882
                                @anticimex I thought so too, but I'm grasping at straws to get the signing to work.
                                To clarify, is the following enough for simple signing: --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ
                                And the arduino code #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
                                Any difference where it's placed in the code? Anything else to check for?
                                • MasMatM MasMat
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @masmat it needs to be defined prior to the inclusion of mysensors.h. That should be it. (on the arduino node that is).
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    While on the subject: what would be the flags needed for setting the gateway to only use the simple encryption but not the (simple) signing feature?
                                    I looked in the documentation and the node commands aren't mirrored for the gateway. I was hoping for something like:
                                    --MY_SIGNING_SIMPLE_PASSWD=flowerpot77
                                    --MY_ENCRYPTION_SIMPLE_PASSWD=spiderman41
                                      It's actually not needed since you can still set signing as optional on gateway
                                      • alowhumA alowhum
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        #886
                                        @alowhum that feature is still only available for beta and is documented here: https://www.mysensors.org/apidocs-beta/group__SecuritySettingGrpPub.html
                                        EDIT: not yet for rPi
                                        Pull requests are welcome. I don't have time for this at the moment.
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          #887
                                          Right. So is this correct?
                                          NODES (arduino nano)
                                          On all my nodes I will update them to have this code at the top:
                                          #define MY_ENCRYPTION_SIMPLE_PASSWD spiderman41 // unfortunately Nano hardware doesn't really have enough memory for signing.
                                          #define MY_RF24_CHANNEL 100 // in EU the default channel 76 overlaps with wifi.
                                          #define MY_RF24_DATARATE RF24_1MBPS // slower datarate makes the network more stable?
                                          GATEWAY (Raspberry Pi Zero W)
                                          On my gateway I will use this configure code:
                                          --my-security-password=spiderman41
                                          --my-rf24-encryption-enabled
                                          --my-rf24-channel=100
                                          --extra-cxxflags="-DMY_RF24_DATARATE=(RF24_1MBPS)"
