  2. Announcements
  • MasMatM MasMat
    @gohan I did, I will post it (but it appears to send normally). But the only things I changed was:
    1. Rpi configure added: --my-signing=password --my-signing-password=ZZZZZZ
    2. In the nodes code: #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
    AnticimexA
    AnticimexA
    Anticimex
    @masmat check that the version you are using (release or beta) match your use of the simple flags, as they differ at the moment.
    MasMatM 1 Reply Last reply
    • AnticimexA Anticimex
      MasMatM
      MasMatM
      MasMat
      wrote on last edited by MasMat
      #873
      @anticimex Both Arduino IDE is 2.2 and Rpi is compiled with 2.2 stable.
      I'm seeing !TSF:MSG:SIGN FAIL in the serial monitor so something is not compatible... I will try making password >8 characters next (currently 6).
      I will also add those parameters to see if that makes a difference before reuploading arduino code
      AnticimexA 1 Reply Last reply
      • MasMatM MasMat
        AnticimexA
        AnticimexA
        Anticimex
        #874
        @masmat if you add the signing debug flag and use the log parser on the homepage it should become clear what the problem is. You can also use the troubleshooting guide in the signing documentation.
        • MasMatM
          MasMatM
          MasMat
          @anticimex This is what's happening in the gw:
          TSF:MSG:READ,36-192-15,s=69,c=0,t=81,pt=1,l=21,sg=0:221
          !TSF:MSG:LEN,16!=28
          TSF:MSG:READ,75-68-77,s=48,c=1,t=110,pt=1,l=25,sg=1:249
          !TSF:MSG:LEN,16!=32
          The parser didn't really help much: more baffled than before....and I came away from the troubleshooting guide feeling really stupid :)
          • MasMatM MasMat
            !TSF:MSG:LEN,16!=28
            !TSF:MSG:LEN,16!=32
            AnticimexA
            AnticimexA
            Anticimex
            @masmat looks to me that your gateway is not set up for signing
            gohanG 1 Reply Last reply
              @anticimex I think he didn't use all the parameters for the configure, right?
              AnticimexA MasMatM 2 Replies Last reply
                AnticimexA
                AnticimexA
                Anticimex
                @gohan the simple flags should not need more args, but I don't use a rPi as gw so I honestly am not sure exactly the args to use. The beta documentation has clear instructions for rPi signing, but those are specifically for beta branch and probably don't map exactly to the release yet.
                  MasMatM
                  MasMatM
                  MasMat
                  #879
                  @gohan The whole configure-line:
                  sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                  If anyone can tell what's missing or if there's a typo?
                  • MasMatM MasMat
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @masmat https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html
                    • MasMatM MasMat
                      AnticimexA
                      AnticimexA
                      Anticimex
                      #881
                      @masmat you have redundant flags. The password option require no other signing flags. Only if you select software as signing backend you need other options (and none of the simple flags)
                      And remember that if you use software signing and not password signing, you need to personalize the GW and/or node.
                        MasMatM
                        MasMatM
                        MasMat
                        #882
                        @anticimex I thought so too, but I'm grasping at straws to get the signing to work.
                        To clarify, is the following enough for simple signing: --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ
                        And the arduino code #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
                        Any difference where it's placed in the code? Anything else to check for?
                        • MasMatM MasMat
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @masmat it needs to be defined prior to the inclusion of mysensors.h. That should be it. (on the arduino node that is).
                          • alowhumA
                            alowhumA
                            alowhum
                            While on the subject: what would be the flags needed for setting the gateway to only use the simple encryption but not the (simple) signing feature?
                            I looked in the documentation and the node commands aren't mirrored for the gateway. I was hoping for something like:
                            --MY_SIGNING_SIMPLE_PASSWD=flowerpot77
                            --MY_ENCRYPTION_SIMPLE_PASSWD=spiderman41
                              It's actually not needed since you can still set signing as optional on gateway
                              • alowhumA alowhum
                                AnticimexA
                                AnticimexA
                                Anticimex
                                #886
                                @alowhum that feature is still only available for beta and is documented here: https://www.mysensors.org/apidocs-beta/group__SecuritySettingGrpPub.html
                                EDIT: not yet for rPi
                                Pull requests are welcome. I don't have time for this at the moment.
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  #887
                                  Right. So is this correct?
                                  NODES (arduino nano)
                                  On all my nodes I will update them to have this code at the top:
                                  #define MY_ENCRYPTION_SIMPLE_PASSWD spiderman41 // unfortunately Nano hardware doesn't really have enough memory for signing.
                                  #define MY_RF24_CHANNEL 100 // in EU the default channel 76 overlaps with wifi.
                                  #define MY_RF24_DATARATE RF24_1MBPS // slower datarate makes the network more stable?
                                  GATEWAY (Raspberry Pi Zero W)
                                  On my gateway I will use this configure code:
                                  --my-security-password=spiderman41
                                  --my-rf24-encryption-enabled
                                  --my-rf24-channel=100
                                  --extra-cxxflags="-DMY_RF24_DATARATE=(RF24_1MBPS)"
                                  • alowhumA alowhum
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @alowhum you will need to enable weak security as well as that will enable both signing and encryption with signature requirements from all nodes on the gw
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      #889
                                      @Anticimex thanks!
                                      But I don't want signing? Or do you mean that it will remove that requirement?
                                      I only need to set that on the gateway, right?
                                      I've also added a slower datarate, thinking that will also create a more stable connection. I am in a busy urban environment with lots of RF noise. Is that smart?
                                      • alowhumA alowhum
                                        @Anticimex thanks!
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @alowhum I thought you did not want signing: "but not the (simple) signing feature?"
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          #891
                                          Yes, I don't want signing. But what you wrote said that it wil ENABLE signing. Check your sentence. Probably a typo, but I wanted to make sure :-)
