  2. Announcements
  • AnticimexA Anticimex
    @masmat looks to me that your gateway is not set up for signing
    @anticimex I think he didn't use all the parameters for the configure, right?
    AnticimexA MasMatM 2 Replies Last reply
      AnticimexA
      AnticimexA
      Anticimex
      @gohan the simple flags should not need more args, but I don't use a rPi as gw so I honestly am not sure exactly the args to use. The beta documentation has clear instructions for rPi signing, but those are specifically for beta branch and probably don't map exactly to the release yet.
        MasMatM
        MasMatM
        MasMat
        wrote on last edited by MasMat
        #879
        @gohan The whole configure-line:
        sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
        If anyone can tell what's missing or if there's a typo?
        • MasMatM MasMat
          AnticimexA
          AnticimexA
          Anticimex
          @masmat https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html
          • MasMatM MasMat
            AnticimexA
            AnticimexA
            Anticimex
            #881
            @masmat you have redundant flags. The password option require no other signing flags. Only if you select software as signing backend you need other options (and none of the simple flags)
            And remember that if you use software signing and not password signing, you need to personalize the GW and/or node.
            MasMatM 1 Reply Last reply
              MasMatM
              MasMatM
              MasMat
              #882
              @anticimex I thought so too, but I'm grasping at straws to get the signing to work.
              To clarify, is the following enough for simple signing: --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ
              And the arduino code #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
              Any difference where it's placed in the code? Anything else to check for?
              AnticimexA 1 Reply Last reply
              • MasMatM MasMat
                AnticimexA
                AnticimexA
                Anticimex
                @masmat it needs to be defined prior to the inclusion of mysensors.h. That should be it. (on the arduino node that is).
                • alowhumA
                  alowhumA
                  alowhum
                  While on the subject: what would be the flags needed for setting the gateway to only use the simple encryption but not the (simple) signing feature?
                  I looked in the documentation and the node commands aren't mirrored for the gateway. I was hoping for something like:
                  --MY_SIGNING_SIMPLE_PASSWD=flowerpot77
                  --MY_ENCRYPTION_SIMPLE_PASSWD=spiderman41
                    It's actually not needed since you can still set signing as optional on gateway
                    • alowhumA alowhum
                      AnticimexA
                      AnticimexA
                      Anticimex
                      #886
                      @alowhum that feature is still only available for beta and is documented here: https://www.mysensors.org/apidocs-beta/group__SecuritySettingGrpPub.html
                      EDIT: not yet for rPi
                      Pull requests are welcome. I don't have time for this at the moment.
                      • alowhumA
                        alowhumA
                        alowhum
                        #887
                        Right. So is this correct?
                        NODES (arduino nano)
                        On all my nodes I will update them to have this code at the top:
                        #define MY_ENCRYPTION_SIMPLE_PASSWD spiderman41 // unfortunately Nano hardware doesn't really have enough memory for signing.
                        #define MY_RF24_CHANNEL 100 // in EU the default channel 76 overlaps with wifi.
                        #define MY_RF24_DATARATE RF24_1MBPS // slower datarate makes the network more stable?
                        GATEWAY (Raspberry Pi Zero W)
                        On my gateway I will use this configure code:
                        --my-security-password=spiderman41
                        --my-rf24-encryption-enabled
                        --my-rf24-channel=100
                        --extra-cxxflags="-DMY_RF24_DATARATE=(RF24_1MBPS)"
                        • alowhumA alowhum
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @alowhum you will need to enable weak security as well as that will enable both signing and encryption with signature requirements from all nodes on the gw
                          • alowhumA
                            alowhumA
                            alowhum
                            #889
                            @Anticimex thanks!
                            But I don't want signing? Or do you mean that it will remove that requirement?
                            I only need to set that on the gateway, right?
                            I've also added a slower datarate, thinking that will also create a more stable connection. I am in a busy urban environment with lots of RF noise. Is that smart?
                            • alowhumA alowhum
                              @Anticimex thanks!
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @alowhum I thought you did not want signing: "but not the (simple) signing feature?"
                              • alowhumA
                                alowhumA
                                alowhum
                                #891
                                Yes, I don't want signing. But what you wrote said that it wil ENABLE signing. Check your sentence. Probably a typo, but I wanted to make sure :-)
                                • alowhumA alowhum
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @alowhum the simple security flag enables signing yes.
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    But does the "--my-signing-weak_security" enable signing?
                                    I want to disable signing completely. What flags do I need to use when building a gateway that only uses encryption?
                                    • alowhumA alowhum
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @alowhum just don't use any flags mentioning signing, personalize the gw according to the documentation and pick the appropriate encryption flag.
                                        MasMatM
                                        MasMatM
                                        MasMat
                                        @anticimex I've built a new node, DHT11 that sends temp&hum data. I reconfigured Rpi with this:
                                        sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing-debug --my-signing=password --my-signing-password=XXXXXX --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=YYYY --my-mqtt-password=ZZZZZ --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                                        This is what I get in gw syslog:
                                        Apr  2 22:53:11 DietPi mysgw: Starting gateway...
                                        Apr  2 22:53:11 DietPi mysgw: Protocol version - 2.2.0
                                        Apr  2 22:53:11 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0
                                        Apr  2 22:53:11 DietPi mysgw: !SGN:BND:PWD<8
                                        Apr  2 22:53:11 DietPi mysgw: !SGN:INI:BND FAIL
                                        Apr  2 22:53:11 DietPi mysgw: TSF:LRT:OK
                                        Apr  2 22:53:11 DietPi mysgw: TSM:INIT
                                        Apr  2 22:53:11 DietPi mysgw: TSF:WUR:MS=0
                                        Apr  2 22:53:11 DietPi mysgw: TSM:INIT:TSP OK
                                        Apr  2 22:53:11 DietPi mysgw: TSM:INIT:GW MODE
                                        Apr  2 22:53:11 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0
                                        Apr  2 22:53:11 DietPi mysgw: MCO:REG:NOT NEEDED
                                        Apr  2 22:53:11 DietPi mysgw: MCO:BGN:STP
                                        Apr  2 22:53:11 DietPi mysgw: MCO:BGN:INIT OK,TSP=1
                                        Apr  2 22:53:11 DietPi mysgw: GWT:RMQ:MQTT RECONNECT
                                        Apr  2 22:53:11 DietPi mysgw: connected to 127.0.0.1
                                        Apr  2 22:53:11 DietPi mysgw: GWT:RMQ:MQTT CONNECTED
                                        Apr  2 22:53:11 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                                        Apr  2 22:53:23 DietPi mysgw: TSF:MSG:READ,99-99-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                        Apr  2 22:53:23 DietPi mysgw: TSF:MSG:BC
                                        Apr  2 22:53:23 DietPi mysgw: TSF:MSG:FPAR REQ,ID=99
                                        Apr  2 22:53:23 DietPi mysgw: TSF:PNG:SEND,TO=0
                                        Apr  2 22:53:23 DietPi mysgw: TSF:CKU:OK
                                        Apr  2 22:53:23 DietPi mysgw: TSF:MSG:GWL OK
                                        Apr  2 22:53:23 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=8
                                        Apr  2 22:53:23 DietPi mysgw: TSF:MSG:SEND,0-0-99-99,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                        Apr  2 22:53:25 DietPi mysgw: TSF:MSG:READ,99-99-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                        Apr  2 22:53:25 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=24
                                        Apr  2 22:53:25 DietPi mysgw: TSF:MSG:PINGED,ID=99,HP=1
                                        Apr  2 22:53:25 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=25
                                        Apr  2 22:53:25 DietPi mysgw: TSF:MSG:SEND,0-0-99-99,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                        Apr  2 22:54:18 DietPi mysgw: TSF:MSG:READ,99-99-0,s=1,c=3,t=16,pt=0,l=0,sg=0:
                                        Apr  2 22:54:18 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                                        Apr  2 22:54:18 DietPi mysgw: !SGN:NCE:GEN
                                        Apr  2 22:54:23 DietPi mysgw: TSF:MSG:READ,99-99-0,s=0,c=3,t=16,pt=0,l=0,sg=0:
                                        Apr  2 22:54:23 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                                        Apr  2 22:54:23 DietPi mysgw: !SGN:NCE:GEN
                                        This is kicking my butt... I cant understand that last part about the nonce :(
                                        I will add the code from the node as soon as possible.
                                        mfalkviddM AnticimexA 2 Replies Last reply
                                        • MasMatM MasMat
                                          @masmat according to the log parser
                                          means the password is too short.
