  2. Bug Reports
  3. Possible Bug version 2.2.0
38 Posts 4 Posters 8.1k Views 3 Watching
    sindrome73
    In the evening ..... Now I'm at work and I can not
    AnticimexA 1 Reply Last reply
    • S sindrome73
      AnticimexA
      AnticimexA
      Anticimex
      @sindrome73 no problem
        sindrome73
        Here I am at home .... I proceeded to redo the procedure and this sot is the log ....
        I had to put an image because the last signs that mida I can not copy them as text ....
        • S sindrome73
          AnticimexA
          AnticimexA
          Anticimex
          @sindrome73 log looks pretty corrupt, but I can't find any signing related messages so it would seem signing is not enabled on the node. Do you have a log from the GW? Is it also running 2.2.0?
          • S sindrome73
            AnticimexA
            AnticimexA
            Anticimex
            @sindrome73 sorry, the capabilities string indicate software signing. But I don't see the backend initialization message. Could you please enable verbose signing debug?
              sindrome73
              tell me how to abbilitate the detailed signature debug .....
              • S sindrome73
                AnticimexA
                AnticimexA
                Anticimex
                @sindrome73 https://www.mysensors.org/apidocs-beta/group__MySigningTroubleshootinggrp.html
                  sindrome73
                  Here is the log with the Debug signed abbreviation.
                  I specify that I had to disable // # define MY_DEBUG because the scketch is too big
                  • S sindrome73
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @sindrome73 signing messages look sane. But the logs look very corrupt. It also looks like the sketch crashed and restarted so I suspect you are running out of stack space. The arduino IDE reports and warns about memory usage and I suspect you get a warning on that.
                      sindrome73
                      Yes indeed I have already said this !! So true that to have the DEBUG of the signature I had to disable the DEBUG.
                      But with this same script, and going to Mysensors 2.1 it works !!
                      • S sindrome73
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @sindrome73 you could try to completely disable debug on your node and observe the behavior of your gw or controller.
                          sindrome73
                          Ok .... Tomorrow I'll do it ..... But it will be difficult to have the Gateway Log because with the signature enabled, the sketch is very large, and does not allow me to activate the Debug ....
                          • S sindrome73
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @sindrome73 well, 2.2.0 could be requiring more memory than 2.1. You can compare since the IDE reports exactly how much memory is used.
                              sindrome73
                              But it is the same with both 2.2 and 2.1.
                              With Arduino Pro Mini, enabling the signature debugging must be disabled because it exceeds counque the maximum available memory .......
                              • S sindrome73
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @sindrome73 you could see in your controller if communication gets though. I could see in the node log that signing handshaking takes place. So I am sure your problem is memory use. You need to reduce the size of your sketch. Or get more powerful hardware to support the features you want to use.
                                  sindrome73
                                  Ok tomorrow calmly I will make these changes and update you .... A Tomorrow, and thanks for now .....
                                  AnticimexA alexsh1A 2 Replies Last reply
                                  • S sindrome73
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @sindrome73 I'm off to bed as well. Good night and we will figure something out later on.
                                    • S sindrome73
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @sindrome73 You can try to load a default sketch from examples with signing to make sure everything is working fine.
                                      If you are out of memory, strange things may happen.
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        https://www.mysensors.org/apidocs/group__memorysavings.html
                                        alexsh1A 1 Reply Last reply
                                        • AnticimexA Anticimex
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #31
                                          @anticimex I must admit that in the world of ESP32 or SAMD I find atmega328p memory restriction more and more an issue. Its ok for 1 sensor and signing, but on some nodes I have 3-4 sensors and debugging and signing have to be disabled due to memory constrains.
                                          BTW, some nodes do behave strangely even when you approach memory limit.
                                          Having said that, I think we need to establish if @sindrome73 node is working fine - a default sketch plus signing would reveal it.
