  3. Battery power sensor acting strange
6 Posts 3 Posters 3.0k Views 1 Watching
  • G Offline
    G Offline
    gadu
    So, I hooked up a Pro Mini with a DS18B20 and Battery Sensor resistors from the guide here. I have not yet cut off the LED or regulator and the complete sensor is running on 2xAA batteries.
    Everything is working just fine, but today I noticed some strange behaviour where the battery percentage bounched to 87%, back to 83% and up to 89%... is this normal? What could be the reasons behind it?
    This is how it looks like
    Code I'm using
     #include <OneWire.h>
     unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
     int oldBatteryPcnt = 0;
     int numSensors=0;
     boolean receivedConfig = false;
     boolean metric = true;
     MyMessage msg(0,V_TEMP);
     MyMessage msgvolt(1,V_VAR1);
       // Startup OneWire
       sensors.begin();
       analogReference(INTERNAL);
       // Startup and initialize MySensors library. Set callback for incoming messages.
       gw.begin();
       //gw.sendSketchInfo("Temperature Sensor", "1.0");
          gw.present(i, S_TEMP);
       // Process incoming messages (like config from server)
    float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
    if (lastTemperature[i] != temperature && temperature != -127.00) {
      gw.send(msg.setSensor(i).set(temperature,1));
        // get the battery Voltage
        //Serial.println(sensorValue);
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
          // Power up radio after sleep
          //gw.sendBatteryLevel(batteryPcnt);
          gw.send(msgvolt.set(batteryPcnt));
          oldBatteryPcnt = batteryPcnt;
       gw.sleep(SLEEP_TIME);
    • D Offline
      daulagari
      wrote on last edited by daulagari
      I see in your code that before the battery level is sent the temperature is sent:
      Could it be that when measuring the battery voltage just after the temperature data has been sent the battery voltage is temporary lower?
      A way to test that is to add a delay before sending the temperature.
      • K Offline
        K Offline
        kalle
        Maybe this is your problem, which also described at the building page.
        "The tap point could be bypassed with a 0.1 uF capacitor to keep the noise level low, at this otherwise high impedance point. "
        G 1 Reply Last reply
        • K kalle
          G Offline
          G Offline
          gadu
          @kalle aah... that could be the reason!
          noobish question perhaps, but what's the tap point?
          • K Offline
            K Offline
            kalle
            Take a look here, I hope that make it more clear.
            • K kalle
              G Offline
              G Offline
              gadu
              @kalle Crystal clear, thanks! :-)
