  3. Node running on supercaps and a solar panel.
59 Posts 5 Posters 11.2k Views 6 Watching
    What supercap where you using?
    alexsh1A Offline
    alexsh1A Offline
    alexsh1
    @gohan 2 caps in series 10F x 2.7V
    gohanG 1 Reply Last reply
    • A Anticimex
      @alexsh1 that is awesome! Was this with signing enabled and with the receiver of your messages requesting signatures? Would be interesting to see what effect the atsha and signing algorithms would have on the consumption. The atsha is kept in dormant state unless it is needed.
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      @anticimex No, this time I have use Sensebender GW Serial and have had a few issues with the computer going into a sleep mode. Therefore, I disabled signing for now. Testing signing would be the next step.
      • alexsh1A alexsh1
        @alexsh1 what brand and where did you get them? I am running too a solar node but even with more capacitance than yours I am not getting that much runtime, probably because I am sending every 10 minutes temperature, humidity, tx pwr percentage, tx and rx rssi, battery % and supercap voltage
        alexsh1A 1 Reply Last reply
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @gohan I cannot tell you about the brand. @ceech soldered those for me. I am going to test it with another node and see how much run time I'll get. I must also admit that the node is very-very low power.
            I noticed there isn't much attached to it, so a real case scenario with a temp hum sensor could be more useful
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @gohan I have a node with temp/hum/pressure/light/lightning sensor - I'll try this one.
              Yes so far I have only tried reporting voltage. Let's see how other sensors can impact the run time.
                I bet you will see a proportional drop according to the number of values you want to report. I am still stressing it a bit, so I think there may be margin to save some power by sending less important values with a lower frequency
                • alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  I have got my hands on 30F 2.7V supercapacitor.
                  With it was charged for the first time, it only lasted sending 2583 times (1 time a minute voltage and an 20ms LED pulse and then sleeping; sleeping consumption is 4-5uA). The number is a bit disappointing. It is however connected via boost MCP1640 to provide the node with a stable 3.3V. I may try to get the supercapacitor connected directly to the node to see if I can extract more packets.
                  Y N alexsh1A 3 Replies Last reply
                  • alexsh1A alexsh1
                    Y Offline
                    Y Offline
                    @alexsh1 Nice experiment :+1:
                    Thanks for reporting!
                    • alexsh1A alexsh1
                      N Offline
                      N Offline
                      @alexsh1 said in Node running on supercaps and a solar panel.:
                      That's your best choice, unless you're also running a PIR or something that requires a higher minimum voltage. In that case, you could switch to this boost converter, which has only 7ua quiescent current:
                      https://www.openhardware.io/view/285/33v-Boost-Converter-with-Pass-Through
                      • N NeverDie
                        alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        @neverdie I think you are right. I have tinkered with your other boost converter - https://www.openhardware.io/view/279/Adjustable-Boost-Converter-with-Pass-Through
                        MCP1640's quiescent current is much higher 19uA.
                        Now, I'll try to run it from the supercapacitor directly. Pity that anything below 1.9V is going to be wasted (nrf24l01+ is unstable around 1.9V)
                        N 1 Reply Last reply
                          alexsh1A Offline
                          alexsh1A Offline
                          alexsh1
                          @gohan Just to let you know. I have been running this node with Si1132 + Si7021 + another sensor (reporting more than 6 values every 5-10 mins) for weeks now. I have just measured the caps = 4.8V (peak is around 5.2V) - it is late at night. In the morning the voltage will go up. I managed to find a very small, but efficient solar cell smaller than in the photo.
                          The key is to have a low sleeping consumption, i.e. all sensors must sleep properly. In this case you get 4-8uA sleeping current and can live on supercaps for days without recharge.
                          • alexsh1A alexsh1
                            N Offline
                            N Offline
                            Please do tell: what did you find? And where?
                            • alexsh1A alexsh1
                              N Offline
                              N Offline
                              Or, better yet, just turn it on prior to your sensor readings, and then turn it off.
                              • N NeverDie
                                alexsh1A Offline
                                alexsh1A Offline
                                alexsh1
                                @neverdie you mean like using a mosfet or something?
                                It is used to supply 3.3v to atmega328p, I do not think I can just turn it off.
                                • N NeverDie
                                  alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  @neverdie sure - this is the one i am very much happy with. Previous one was not supplying enough juice to charge fully supercaps.
                                  https://www.ebay.co.uk/itm/Polycrystalline-Solar-Panel-Cell-5v-30mA-0-15w-53mm-x-30mm-DIY-LED-Garden-Light/362000885812?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                                  • alexsh1A alexsh1
                                    N Offline
                                    N Offline
                                    Sorry, I meant switch to "pass through".
                                    alexsh1A 2 Replies Last reply
                                    • N NeverDie
                                      alexsh1A Offline
                                      alexsh1A Offline
                                      alexsh1
                                      @neverdie Yes, that's on my 'to do' list. However, right now I'd like to see how much I can extract from supercap directly wired to the node.
                                        How much does the supercap self discharge?
                                          alexsh1A Offline
                                          alexsh1A Offline
                                          alexsh1
                                          #24
                                          @gohan I need to implement the voltage measurement (simple voltage divider) as I have a pass though buck converter so 3.3v is shown. All I can say now is that after a few charges self discharge really improved.
