  3. Node running on supercaps and a solar panel.
59 Posts 5 Posters 11.2k Views 6 Watching
  • N NeverDie
    @alexsh1 said in Node running on supercaps and a solar panel.:
    I may try to get the supercapacitor connected directly to the node to see if I can extract more packets.
    That's your best choice, unless you're also running a PIR or something that requires a higher minimum voltage. In that case, you could switch to this boost converter, which has only 7ua quiescent current:
    https://www.openhardware.io/view/285/33v-Boost-Converter-with-Pass-Through
    alexsh1A Offline
    alexsh1A Offline
    alexsh1
    @neverdie I think you are right. I have tinkered with your other boost converter - https://www.openhardware.io/view/279/Adjustable-Boost-Converter-with-Pass-Through
    MCP1640's quiescent current is much higher 19uA.
    Now, I'll try to run it from the supercapacitor directly. Pity that anything below 1.9V is going to be wasted (nrf24l01+ is unstable around 1.9V)
    N 1 Reply Last reply
      I bet you will see a proportional drop according to the number of values you want to report. I am still stressing it a bit, so I think there may be margin to save some power by sending less important values with a lower frequency
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      @gohan Just to let you know. I have been running this node with Si1132 + Si7021 + another sensor (reporting more than 6 values every 5-10 mins) for weeks now. I have just measured the caps = 4.8V (peak is around 5.2V) - it is late at night. In the morning the voltage will go up. I managed to find a very small, but efficient solar cell smaller than in the photo.
      The key is to have a low sleeping consumption, i.e. all sensors must sleep properly. In this case you get 4-8uA sleeping current and can live on supercaps for days without recharge.
      • alexsh1A alexsh1
        N Offline
        N Offline
        Please do tell: what did you find? And where?
        alexsh1A 1 Reply Last reply
        • alexsh1A alexsh1
          N Offline
          N Offline
          Or, better yet, just turn it on prior to your sensor readings, and then turn it off.
          • N NeverDie
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @neverdie you mean like using a mosfet or something?
            It is used to supply 3.3v to atmega328p, I do not think I can just turn it off.
            • N NeverDie
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @neverdie sure - this is the one i am very much happy with. Previous one was not supplying enough juice to charge fully supercaps.
              https://www.ebay.co.uk/itm/Polycrystalline-Solar-Panel-Cell-5v-30mA-0-15w-53mm-x-30mm-DIY-LED-Garden-Light/362000885812?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
              • alexsh1A alexsh1
                N Offline
                N Offline
                Sorry, I meant switch to "pass through".
                alexsh1A 2 Replies Last reply
                • N NeverDie
                  alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @neverdie Yes, that's on my 'to do' list. However, right now I'd like to see how much I can extract from supercap directly wired to the node.
                    How much does the supercap self discharge?
                      alexsh1A Offline
                      alexsh1A Offline
                      alexsh1
                      #24
                      @gohan I need to implement the voltage measurement (simple voltage divider) as I have a pass though buck converter so 3.3v is shown. All I can say now is that after a few charges self discharge really improved.
                        That is something you can do by leaving the supercap on a desk for 24 hours and a multimeter 😁
                          alexsh1A Offline
                          alexsh1A Offline
                          alexsh1
                          @gohan not an option. Sorry :grin:
                          • alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            Did anyone try using 3V solar cell for 2.7V caps?
                            Seems a perfect fit - no need to use two supercaps in series
                            https://www.ebay.co.uk/itm/3V-x-500-ma-Mini-solar-panel-epoxy-encapsulated-virtually-indestructible-1-5W/171216986698?hash=item27dd53e24a:g:14YAAOxyRhBS1H0O
                            • N NeverDie
                              alexsh1A Offline
                              alexsh1A Offline
                              alexsh1
                              @neverdie Did you make any estimates running your mote on supercap? I cannot understand how come on RFM69HW (lowpowerlab), this guy managed to extract 14,111 packets transmitted https://lowpowerlab.com/forum/projects/a-solar-supercap-powered-moteino/
                              This is on 15F supercap.
                              • alexsh1A alexsh1
                                N Offline
                                N Offline
                                @alexsh1 His numbers are 100% accurate.
                                • N NeverDie
                                  alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  #30
                                  @neverdie I am not questioning his numbers. I am trying to understand why with a normal transceiver (non-H) I am getting so much less. I must admit also that with BQ25570, I have 2x10F in series, which makes it 5F in total only vs 15F.
                                  I should wait until my 30F cap runs out of juice and see how many packets I extracted
                                    If you are happy with your setup to power the node, why are you bothering that much to send that many more packets if you actually don't need them anyway?
                                      alexsh1A Offline
                                      alexsh1A Offline
                                      alexsh1
                                      @gohan This is not about being happy. Engineering mind can never be satisfied ;-)
                                        alexsh1A Offline
                                        alexsh1A Offline
                                        alexsh1
                                        #33
                                        @gohan However, in the nutshell you are right. With a small solar battery (53mm x 30mm, 5V 0.15W), this is what I get:
                                        and today is an extremely cloudy day (no sun at all). Harvesting works really well.
                                        I implemented a voltage divider yesterday with 1.8M / 470k resistors. Now I can monitor voltage in Domoticz:
                                        voltage at 22:00 yesterday - 4.797V
                                        voltage at 12:00 today - 4.887V
                                        gohanG 1 Reply Last reply
                                        • N Offline
                                          N Offline
                                          #34
                                          Try running with your fuses set to xFF xDA xC2, That way your BOD will be turned off, you'll be running from the internal 8mhz resonator, and you'll be waking from sleep in <4uSec.
