  2. Announcements
  3. 💬 Advanced Gateway Options
59 Posts 16 Posters 35.3k Views 13 Watching
  • mntlvrM
    mntlvrM
    mntlvr
    I think you are miss-understanding me the Mysensors Plugin for Vera does all of the connecting to Vera. I have nothing connected to my Vera directly except the Vera address and the Ethernet Address which is applied to the plugin that you use to create the Icon for Mysensors. Whether I use the WiFi version or the Ethernet version the use the same plugin.Wireless except for the Address each unit has on the network
    dbemowskD 1 Reply Last reply
    • mntlvrM mntlvr
      dbemowskD
      dbemowskD
      @mntlvr Sorry, I don't have ethernet or WiFi gateways, so I wasn't sure if or how they connected to the Vera. When you go to the properties on the MySensors plugin, is it that you have the start and stop buttons for inclusion, or do you not have the buttons?
      • mntlvrM
        mntlvrM
        mntlvr
        Yes the inclusion buttons are under properties no need of having button on gw.
        How does you serial gw talk to your Vera ? Do you have a plugin that is used to create your Icon.
        See when the icon is created on my Vera Plus it shows the plugin version but not the library version so I know just by that issue the plugin is not configuring to any gw.
        • S Strixx
          @mntlvr said in 💬 Advanced Gateway Options:
          So what is the finial solution to using the Led's on a ESP 8266-E gateway are they of any use if using a Vera Controller?
          I have had a lot of help with the leds. I have noticed that you get a lot of errors (in some positions it is impossible to communicate with the nodes at all) if not the radio is positioned to close to the ESP. It seems to me that the radio on the NodeMCU interferes with the NRF24L01+PA+LNA that i am using on my gateway. I found I thread on this forum about it but can't find it again.
          So thanks to the leds I have been able to build a box where i have no transmission errors due to interference.
          mntlvrM
          mntlvrM
          mntlvr
          @strixx said in 💬 Advanced Gateway Options:
          Strixx
          You have a WiFi gw up and working , right? What version of the MYSensors are you using? Also what type of Vera are you using. I am using a Vera3 and a Vera Plus? Also which plugin are you using for your Vera. I have built both WiFi and Ethernet and the sensors talk wonderfully to the gw's no matter which I power up but neither of my Vera's will configure and use the plugin that are the latest available from git-hub.
          S 1 Reply Last reply
          • mntlvrM mntlvr
            dbemowskD
            dbemowskD
            @mntlvr I believe the plugin is similar, if not the same for the serial gateway also. Did you enable the inclusion mode?
            // Enable inclusion mode
            If you do a port scan of the IP address of the ESP8266, what ports does it show as open? Do you have this in you sketch?
            #define MY_PORT 5003
            • mntlvrM
              mntlvrM
              mntlvr
              Oh yes I mentioned that several days ago.
              My vera's have port 3480 and 80 opened
              dbemowskD 2 Replies Last reply
              • mntlvrM mntlvr
                dbemowskD
                dbemowskD
                #45
                @mntlvr But do you have port 5003 defined in the gateway sketch that you have on the ESP8266? You should be seeing a port 5003 open. If not, you will need to check the sketch and find out why? What happens if you open your web browser to port 80 at that IP address? Does it bring you to a configuration page?
                • mntlvrM mntlvr
                  dbemowskD
                  dbemowskD
                  @mntlvr Also, It's not the Vera's IP that you want to scan ports on. It would be the IP of the ESP8266.
                  • mntlvrM mntlvr
                    Strixx
                    Strixx
                    @mntlvr
                    Strixx
                    I don't use Vera. I use Domoticz.
                    • mntlvrM
                      mntlvrM
                      mntlvr
                      okay thanks
                      • mntlvrM
                        mntlvrM
                        mntlvr
                        @dbemowsk
                        No the gw is the like the host and the Controller is like the client so If you look into the Ethernet or WiFi sketches it will explain that you must use the Controller's ip address so the gw knows where to send the information to and the Vera is the one that is listening so it has to have a port open not the gw. the sensors send the info to the gw and the gw acknowledges it received the message then passing that message on to the controller thru the plugin
                        • Nick WillisN
                          Nick WillisN
                          Nick Willis
                          What does the red error LED indicate? I'm seeing reds on my gateway sometimes.
                          • Nick WillisN Nick Willis
                            #51
                            @nick-willis it indicates an error ;-) The list of possible errors is available at https://github.com/mysensors/MySensors/blob/121648f34bb45ab0e21fc4b4835959d27b28a9c6/core/MyIndication.h#L49
                            Most common reason is probably transmit failure.
                            The gateway debug log will provide more details.
                            • sundberg84S
                              sundberg84S
                              #52
                              Hi all!
                              Im building myself a network rack which will house all gateways and other network equipment. This is a steal frame (ie true faradays cage). I will run the antennas outside with a magnetic base and these antennas with "extension" has worked fine for my 433mhz equipment.
                              For the main 2.4ghz gateway im lookning at this:
                              I guess its just a matter of buy and try, but I know there are some antenna nerds in here so a couple of questions.
                              • Even if it says wifi, i guess it works just as great for MySensors since its the same freq?
                              • Will the extension cord impact the performance in any way?
                              • It say 5dBi, what does this correspond to setting MySensors setting? (Ie. how would you config the gateway settings?)
                              From MyConfig:
                               * @def MY_RF24_PA_LEVEL
                               * - RF24_PA_LOW = -12dBm
                               * - RF24_PA_HIGH = -6dBm
                               * - RF24_PA_MAX = 0dBm
                              • sundberg84S sundberg84
                                Hi all!
                                From MyConfig:
                                Exactly
                                Yes. There will be some attenuation in the cable. Cables have different attenuation at different frequencies, and there are different cables. Hopefully this cable works well with 2.4GHz but it would be hard to tell without a datasheet or by measuring the cable.
                                The antenna (or maybe the antenna + cable, depending on what the specification includes) has 5dBi gain. This means that you'll have to lower the tx power by 5dB to stay within legal limits, compared with an isotropic antenna.
                                  Exactly
                                  sundberg84S
                                  sundberg84S
                                  #54
                                  @mfalkvidd - thanks, very good information!
                                  So to be legal I must go RF24_PA_HIGH = -6dBm (which is default?).
                                  No datasheet found, i guess I have to buy and try.
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @sundberg84 Further to what @mfalkvidd said, please note that most manufacturers state dBi figures as comparatives for the marketplace, rarely do they test them to verify the value and predominantly quote theoretical values instead.
                                    A claimed 5dBi it is likely a 1/4 wave whip ONLY on an infinite ground plane, your actual gain will be less than this depending on attached surface, gain reducing as the area reduces, and the cable attenuating it further depending on the cable used.
                                    i.e. It works, it don't, adjust ;)
                                    • zboblamontZ zboblamont
                                      sundberg84S
                                      sundberg84S
                                      @zboblamont thanks!
                                      The "try, repeat" method was something i was expecting but always good to have the theory behind. But im still not quite understanding this with gain and the MySensors settings (which seems to be negative gain?)
                                      mfalkviddM zboblamontZ 2 Replies Last reply
                                        @zboblamont thanks!
                                        #57
                                        @sundberg84 dBm is just a different way to state output power. Often milliwatts is used. The neat thing with dB is that they can be added and subtracted easily, which cannot be done with milliwatts.
                                        Conversion table: https://www.rfcables.org/dbm-to-milli-watts-table.html
                                        Iirc, the max radiated ouput power for the 433MHz band in EU is 100mW which is 20dB.
                                        The max power for MySensors is 0dBwhich is 1 milliwatt.
                                        With 5dB gain from the antenna, the radiated output power will be 0dB+5dB=5dB which is sligthly above 3 milliwatt (the antenna "focuses" the signal so the signal becomes stronger). So you can use the max output power and still be below 100mW, no worries.
                                        Let's say you had an antenna with 25dB gain. Then you would have to use a max output power of -5dB from MySensors to be within legal limits (25-5=20).
                                        For reference, this is what a 25dB antenna looks like https://www.aliexpress.com/item/YAGI-25DB-2-4G-WiFi-Booster-Antenna-for-Wireless-IP-Camera-or-Router/1886239710.html
                                          @zboblamont thanks!
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          #58
                                          @sundberg84 I see @mfalkvidd has already covered dBm and strangely a thong, presumably a typo rather than domestic distraction ;)
                                          The point I was driving at is you can largely ignore dBi, it is a theoretical isotropic radiation. Beyond the ERP limitations, a touch up or down on power nobody will be screaming at, but it is pointless burning energy for no purpose, you will arrive at a reliable Gateway ERP by experimentation. I very much doubt it will exceed limitations with existing Nodes in any case if your previous antenna was lower gain of any order.
                                          Do the maths by all means, just don't get hung up on it. The thing to remember is that total power remains essentially constant, the lobe formation only squeezes it more tightly with higher gain. A 1/4 lambda is not a high gain antenna...
