  2. Announcements
  3. 💬 Advanced Gateway Options
59 Posts 16 Posters 35.3k Views 13 Watching
  • mntlvrM mntlvr
    Oh yes I mentioned that several days ago.
    My vera's have port 3480 and 80 opened
    dbemowskD
    dbemowskD
    @mntlvr Also, It's not the Vera's IP that you want to scan ports on. It would be the IP of the ESP8266.
    • mntlvrM mntlvr
      @strixx said in 💬 Advanced Gateway Options:
      @mntlvr said in 💬 Advanced Gateway Options:
      So what is the finial solution to using the Led's on a ESP 8266-E gateway are they of any use if using a Vera Controller?
      I have had a lot of help with the leds. I have noticed that you get a lot of errors (in some positions it is impossible to communicate with the nodes at all) if not the radio is positioned to close to the ESP. It seems to me that the radio on the NodeMCU interferes with the NRF24L01+PA+LNA that i am using on my gateway. I found I thread on this forum about it but can't find it again.
      So thanks to the leds I have been able to build a box where i have no transmission errors due to interference.
      Strixx
      You have a WiFi gw up and working , right? What version of the MYSensors are you using? Also what type of Vera are you using. I am using a Vera3 and a Vera Plus? Also which plugin are you using for your Vera. I have built both WiFi and Ethernet and the sensors talk wonderfully to the gw's no matter which I power up but neither of my Vera's will configure and use the plugin that are the latest available from git-hub.
      Strixx
      @mntlvr
      Strixx
      I don't use Vera. I use Domoticz.
      • mntlvrM
        mntlvrM
        mntlvr
        okay thanks
        • mntlvrM
          mntlvrM
          mntlvr
          @dbemowsk
          No the gw is the like the host and the Controller is like the client so If you look into the Ethernet or WiFi sketches it will explain that you must use the Controller's ip address so the gw knows where to send the information to and the Vera is the one that is listening so it has to have a port open not the gw. the sensors send the info to the gw and the gw acknowledges it received the message then passing that message on to the controller thru the plugin
          • Nick WillisN
            Nick WillisN
            Nick Willis
            What does the red error LED indicate? I'm seeing reds on my gateway sometimes.
            • Nick WillisN Nick Willis
              #51
              @nick-willis it indicates an error ;-) The list of possible errors is available at https://github.com/mysensors/MySensors/blob/121648f34bb45ab0e21fc4b4835959d27b28a9c6/core/MyIndication.h#L49
              Most common reason is probably transmit failure.
              The gateway debug log will provide more details.
              • sundberg84S
                sundberg84S
                #52
                Hi all!
                Im building myself a network rack which will house all gateways and other network equipment. This is a steal frame (ie true faradays cage). I will run the antennas outside with a magnetic base and these antennas with "extension" has worked fine for my 433mhz equipment.
                For the main 2.4ghz gateway im lookning at this:
                I guess its just a matter of buy and try, but I know there are some antenna nerds in here so a couple of questions.
                • Even if it says wifi, i guess it works just as great for MySensors since its the same freq?
                • Will the extension cord impact the performance in any way?
                • It say 5dBi, what does this correspond to setting MySensors setting? (Ie. how would you config the gateway settings?)
                From MyConfig:
                 * @def MY_RF24_PA_LEVEL
                 * - RF24_PA_LOW = -12dBm
                 * - RF24_PA_HIGH = -6dBm
                 * - RF24_PA_MAX = 0dBm
                • sundberg84S sundberg84
                  Hi all!
                  From MyConfig:
                  Exactly
                  Yes. There will be some attenuation in the cable. Cables have different attenuation at different frequencies, and there are different cables. Hopefully this cable works well with 2.4GHz but it would be hard to tell without a datasheet or by measuring the cable.
                  The antenna (or maybe the antenna + cable, depending on what the specification includes) has 5dBi gain. This means that you'll have to lower the tx power by 5dB to stay within legal limits, compared with an isotropic antenna.
                    Exactly
                    sundberg84S
                    sundberg84S
                    #54
                    @mfalkvidd - thanks, very good information!
                    So to be legal I must go RF24_PA_HIGH = -6dBm (which is default?).
                    No datasheet found, i guess I have to buy and try.
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @sundberg84 Further to what @mfalkvidd said, please note that most manufacturers state dBi figures as comparatives for the marketplace, rarely do they test them to verify the value and predominantly quote theoretical values instead.
                      A claimed 5dBi it is likely a 1/4 wave whip ONLY on an infinite ground plane, your actual gain will be less than this depending on attached surface, gain reducing as the area reduces, and the cable attenuating it further depending on the cable used.
                      i.e. It works, it don't, adjust ;)
                      • zboblamontZ zboblamont
                        sundberg84S
                        sundberg84S
                        @zboblamont thanks!
                        The "try, repeat" method was something i was expecting but always good to have the theory behind. But im still not quite understanding this with gain and the MySensors settings (which seems to be negative gain?)
                        mfalkviddM zboblamontZ 2 Replies Last reply
                          @zboblamont thanks!
                          #57
                          @sundberg84 dBm is just a different way to state output power. Often milliwatts is used. The neat thing with dB is that they can be added and subtracted easily, which cannot be done with milliwatts.
                          Conversion table: https://www.rfcables.org/dbm-to-milli-watts-table.html
                          Iirc, the max radiated ouput power for the 433MHz band in EU is 100mW which is 20dB.
                          The max power for MySensors is 0dBwhich is 1 milliwatt.
                          With 5dB gain from the antenna, the radiated output power will be 0dB+5dB=5dB which is sligthly above 3 milliwatt (the antenna "focuses" the signal so the signal becomes stronger). So you can use the max output power and still be below 100mW, no worries.
                          Let's say you had an antenna with 25dB gain. Then you would have to use a max output power of -5dB from MySensors to be within legal limits (25-5=20).
                          For reference, this is what a 25dB antenna looks like https://www.aliexpress.com/item/YAGI-25DB-2-4G-WiFi-Booster-Antenna-for-Wireless-IP-Camera-or-Router/1886239710.html
                            @zboblamont thanks!
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            #58
                            @sundberg84 I see @mfalkvidd has already covered dBm and strangely a thong, presumably a typo rather than domestic distraction ;)
                            The point I was driving at is you can largely ignore dBi, it is a theoretical isotropic radiation. Beyond the ERP limitations, a touch up or down on power nobody will be screaming at, but it is pointless burning energy for no purpose, you will arrive at a reliable Gateway ERP by experimentation. I very much doubt it will exceed limitations with existing Nodes in any case if your previous antenna was lower gain of any order.
                            Do the maths by all means, just don't get hung up on it. The thing to remember is that total power remains essentially constant, the lobe formation only squeezes it more tightly with higher gain. A 1/4 lambda is not a high gain antenna...
                              must have been a freudian slip ;-)
