  3. Issue while interfacing NRF24L01 and RFID on same arduino
15 Posts 5 Posters 3.9k Views 5 Watching
    I had the same problem when I tried it: if you connect the rfid reader you loose the nrf24 communication. It is like they don't like sharing the SPI :D
      @gohan that's probably why the examples has this:
      // Enable soft spi as radio has a hard time sharing spi
        123cheatn
        wrote on last edited by 123cheatn
        thanks to all of you for the reply.
        I found the solution.
        after looking at the code and some debugging.
        my code is working fine now.
        This is the code
         * Example sketch/program showing how to read data from more than one PICC to serial.
         * This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
         * Example sketch/program showing how to read data from more than one PICC (that is: a RFID Tag or Card) using a
         * MFRC522 based RFID Reader on the Arduino SPI interface.
         * Warning: This may not work! Multiple devices at one SPI are difficult and cause many trouble!! Engineering skill
         *          and knowledge are required!
         * @license Released into the public domain.
         * Typical pin layout used:
         *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
         *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
         * Signal      Pin          Pin           Pin       Pin        Pin              Pin
         * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
         * SPI SS 1    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
         * SPI SS 2    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
         * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
         * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
         * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
        #include <MFRC522.h>
        #include <nRF24L01.h>
        #include <RF24.h>
        RF24 radio(7, 8); // CE, CSN
        const byte add[6] = "00001";
        #define RST_PIN         9          // Configurable, see typical pin layout above
        #define SS_PIN        10         // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
        //#define SS_2_PIN        8          // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
        #define NR_OF_READERS   1
        byte ssPins[] = {SS_PIN};
        MFRC522 mfrc522[NR_OF_READERS];   // Create MFRC522 instance.
         * Initialize.
          Serial.begin(9600); // Initialize serial communications with the PC
          while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
          SPI.begin();        // Init SPI bus
          for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
            mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
            Serial.print(F("Reader "));
            Serial.print(reader);
            Serial.print(F(": "));
            mfrc522[reader].PCD_DumpVersionToSerial();
          radio.begin();
          radio.openWritingPipe(add);
          radio.setPALevel(RF24_PA_MAX);
          radio.stopListening();
         * Main loop.
            // Look for new cards
            if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
              // Show some details of the PICC (that is: the tag/card)
              Serial.print(F(": Card UID:"));
              dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
              Serial.println();
              mfrc522[reader].PCD_StopCrypto1();
         * Helper routine to dump a byte array as hex values to Serial.
        void dump_byte_array(byte *buffer, byte bufferSize) {
          int c[]={176,240,158,94};
          int count=0;
          delay(10);
          for (byte i = 0; i < bufferSize; i++) {
            delay(10);
            Serial.print(buffer[i] < 0x10 ? " 0" : " ");
            Serial.print(buffer[i], HEX);
          Serial.println();
            if(buffer[i]==c[i]){
              count++;
          int flag=0;
          if(count==4){
            const char text[] = "17624015894";
            radio.write(&text, sizeof(text));
          }else{
            const char text[] = "No";
        void before() {
        // Make sure MFRC is disabled from the SPI bus
        pinMode(RST_PIN, INPUT);
        digitalWrite(RST_PIN, HIGH);
        pinMode(SS_PIN, OUTPUT);
        digitalWrite(SS_PIN, LOW);
          But you still haven't used any mysensors code :thinking_face:
          YveauxY 1 2 Replies Last reply
            @gohan and we still don't know what the issue was :rolling_on_the_floor_laughing:
            1 1 Reply Last reply
              he wrote me a PM, so the problem is the one I described
              • YveauxY Yveaux
                123cheatn
                @yveaux the problem was in the code and in the circuit, actually both the modules were not working together.
                Previously I had to disconnect either one of the module.
                  123cheatn
                  hey, @gohan it was working fine without mysensors library.
                  gohanG 1 Reply Last reply
                  • 1 123cheatn
                    @123cheatn Ok, clear. Thanks for reporting back! :+1:
                    • 1 123cheatn
                      @123cheatn if you make it to work with mysensors, pls report back
                        123cheatn
                        @gohan sure I will try.
                        • G
                          G
                          Gokhan Tuncel
                          @123cheatn I'm trying very similar project but could not achieve it :(
                          On master Arduino, RFID UID ID will be read and send to 4 other Arduinos; they will react regarding to UID ID (activate a relay, led etc.). Also those 4 Arduinos have MFRC522 but won't be sending RF UID ID's, just reacting depending on which UID ID read by their reader.
                          I think I could not solve multiple SPI module code :/ Here is my code;
                          #include <RF24.h>
                          #include <NRF24.h>
                          NRF24 radio;
                          unsigned long time_now = 0;
                          int blinkled = 300;
                          int value;
                          int displace = 1000;
                          unsigned long CountDownStarted = 0;
                          int CountdownState = 0;
                          int Set60State = 0;
                          int Set90State = 0;
                          int EngineState = 0;
                          #define EnginePin 6
                          #define StartPin 7
                          #define Set90Pin 8
                          #define Set60Pin 9
                          #define TestLed 13
                          String cardUID ;
                          #define SS_RF 10
                          #define RST 5
                          #define SS_NRF 53
                          MFRC522 mfrc522(SS_RF, RST);   // Create MFRC522 instance.
                          { pinMode(EnginePin, OUTPUT);
                            pinMode(StartPin, OUTPUT);
                            pinMode(Set90Pin, OUTPUT);
                            pinMode(Set60Pin, OUTPUT);
                            Serial.begin(115200);   // Initiate a serial communication
                            SPI.begin();      // Initiate  SPI bus
                            radio.setAddress(0xD2);
                            radio.begin(40, 53);
                            radio.setChannel(124);
                            radio.setRetries(0, 15);
                            radio.setActive(true);
                            pinMode(SS_RF, OUTPUT);
                            pinMode(SS_NRF, OUTPUT);
                            pinMode(TestLed, OUTPUT);
                            digitalWrite(EnginePin, LOW);
                            digitalWrite(StartPin, LOW);
                            digitalWrite(Set90Pin, LOW);
                            digitalWrite(Set60Pin, LOW);
                            digitalWrite(TestLed, LOW);
                            radio.startListening();
                            if (CountdownState == 1) {
                              CountDown();
                            if ( ! mfrc522.PICC_IsNewCardPresent())
                              return;
                            // Select one of the cards
                            if ( ! mfrc522.PICC_ReadCardSerial())
                              return;
                            //Show UID on serial monitor
                            Serial.print("UID tag :");
                            String content = "";
                            byte letter;
                            for (byte i = 0; i < mfrc522.uid.size; i++)
                              Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
                              Serial.print(mfrc522.uid.uidByte[i], HEX);
                              content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
                              content.concat(String(mfrc522.uid.uidByte[i], HEX));
                            Serial.println();
                            Serial.print("Message : ");
                            content.toUpperCase();
                            if (content.substring(1) == "E0 0A DD A4" || content.substring(1) == "C0 57 FE A7" || content.substring(1) == "B0 AB 9F A5" || content.substring(1) == "50 51 1B A4" )
                              if (EngineState == 0) {
                                digitalWrite(EnginePin, HIGH);
                                Serial.print(F("Sending Engine Code... "));
                                bool sent = radio.send(0xD3, "E0 0A DD A4");
                                bool sent2 = radio.send(0xD4, "E0 0A DD A4");
                                bool sent3 = radio.send(0xD5, "E0 0A DD A4");
                                bool sent4 = radio.send(0xD6, "E0 0A DD A4");
                                Serial.println(sent ? "OK" : "failed");
                                Serial.println(sent2 ? "OK" : "failed");
                                Serial.println(sent3 ? "OK" : "failed");
                                Serial.println(sent4 ? "OK" : "failed");
                                EngineState = 1;
                                delay(50);
                              if (EngineState == 1) {
                                delay(100);
                            if ((EngineState != 0) && (content.substring(1) == "CD 9E 08 75" || content.substring(1) == "7D A6 4F 75" || content.substring(1) == "8D 2B 55 75" || content.substring(1) == "DD D1 6C 3E" ))
                              if (CountdownState == 0) {
                                Serial.println("Countdown Started");
                                digitalWrite(StartPin, HIGH);
                                delay(50);
                                Serial.print(F("Sending Start Code... "));
                                bool sent = radio.send(0xD3, "CD 9E 08 75");
                                bool sent2 = radio.send(0xD4, "CD 9E 08 75");
                                bool sent3 = radio.send(0xD5, "CD 9E 08 75");
                                bool sent4 = radio.send(0xD6, "CD 9E 08 75");
                                CountdownState = 1;
                                delay(100);
                            if ((EngineState != 0) && (content.substring(1) == "7D 1C 65 5C" || content.substring(1) == "AD C2 5C 74"))
                              if (Set90State == 0) {
                                digitalWrite(Set90Pin, HIGH);
                                delay(50);
                                Serial.print(F("Sending 90' Code... "));
                                bool sent = radio.send(0xD3, "7D 1C 65 5C");
                                bool sent2 = radio.send(0xD4, "7D 1C 65 5C");
                                bool sent3 = radio.send(0xD5, "7D 1C 65 5C");
                                bool sent4 = radio.send(0xD6, "7D 1C 65 5C");
                                Set90State = 1;
                                delay(50);
                                delay(100);
                            if ((EngineState != 0) && (content.substring(1) == "20 C4 18 A4" || content.substring(1) == "1D AE 2C 75"))
                              if (Set60State == 0) {
                                digitalWrite(Set60Pin, HIGH);
                                delay(50);
                                bool sent = radio.send(0xD3, "20 C4 18 A4");
                                bool sent2 = radio.send(0xD4, "20 C4 18 A4");
                                bool sent3 = radio.send(0xD5, "20 C4 18 A4");
                                bool sent4 = radio.send(0xD6, "20 C4 18 A4");
                                Set60State = 1;
                                delay(50);
                                delay(100);
                            if (radio.available()) {
                              char buf[32];
                              uint8_t numBytes = radio.read(buf, sizeof(buf));
                              Serial.print(F("Received: "));
                              Serial.println(buf);
                          void CountDown() {
                            time_now = millis();
                            value = 128 + 127 * cos(2 * PI / blinkled * time_now);
                            analogWrite(TestLed, value);
                            //Serial.println(value);
                          Do you have any idea to solve this?
                          12.5k
