  3. Issue while interfacing NRF24L01 and RFID on same arduino
15 Posts 5 Posters 3.9k Views 5 Watching
    123cheatn
    wrote on last edited by 123cheatn
    thanks to all of you for the reply.
    I found the solution.
    after looking at the code and some debugging.
    my code is working fine now.
    This is the code
     * Example sketch/program showing how to read data from more than one PICC to serial.
     * This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
     * Example sketch/program showing how to read data from more than one PICC (that is: a RFID Tag or Card) using a
     * MFRC522 based RFID Reader on the Arduino SPI interface.
     * Warning: This may not work! Multiple devices at one SPI are difficult and cause many trouble!! Engineering skill
     *          and knowledge are required!
     * @license Released into the public domain.
     * Typical pin layout used:
     *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
     *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
     * Signal      Pin          Pin           Pin       Pin        Pin              Pin
     * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
     * SPI SS 1    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
     * SPI SS 2    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
     * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
     * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
     * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
    #include <MFRC522.h>
    #include <nRF24L01.h>
    #include <RF24.h>
    RF24 radio(7, 8); // CE, CSN
    const byte add[6] = "00001";
    #define RST_PIN         9          // Configurable, see typical pin layout above
    #define SS_PIN        10         // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
    //#define SS_2_PIN        8          // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
    #define NR_OF_READERS   1
    byte ssPins[] = {SS_PIN};
    MFRC522 mfrc522[NR_OF_READERS];   // Create MFRC522 instance.
     * Initialize.
      Serial.begin(9600); // Initialize serial communications with the PC
      while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
      SPI.begin();        // Init SPI bus
      for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
        mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
        Serial.print(F("Reader "));
        Serial.print(reader);
        Serial.print(F(": "));
        mfrc522[reader].PCD_DumpVersionToSerial();
      radio.begin();
      radio.openWritingPipe(add);
      radio.setPALevel(RF24_PA_MAX);
      radio.stopListening();
     * Main loop.
        // Look for new cards
        if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
          // Show some details of the PICC (that is: the tag/card)
          Serial.print(F(": Card UID:"));
          dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
          Serial.println();
          mfrc522[reader].PCD_StopCrypto1();
     * Helper routine to dump a byte array as hex values to Serial.
    void dump_byte_array(byte *buffer, byte bufferSize) {
      int c[]={176,240,158,94};
      int count=0;
      delay(10);
      for (byte i = 0; i < bufferSize; i++) {
        delay(10);
        Serial.print(buffer[i] < 0x10 ? " 0" : " ");
        Serial.print(buffer[i], HEX);
      Serial.println();
        if(buffer[i]==c[i]){
          count++;
      int flag=0;
      if(count==4){
        const char text[] = "17624015894";
        radio.write(&text, sizeof(text));
      }else{
        const char text[] = "No";
    void before() {
    // Make sure MFRC is disabled from the SPI bus
    pinMode(RST_PIN, INPUT);
    digitalWrite(RST_PIN, HIGH);
    pinMode(SS_PIN, OUTPUT);
    digitalWrite(SS_PIN, LOW);
      But you still haven't used any mysensors code :thinking_face:
      YveauxY 1 2 Replies Last reply
        @gohan and we still don't know what the issue was :rolling_on_the_floor_laughing:
        1 1 Reply Last reply
          he wrote me a PM, so the problem is the one I described
          • YveauxY Yveaux
            123cheatn
            @yveaux the problem was in the code and in the circuit, actually both the modules were not working together.
            Previously I had to disconnect either one of the module.
              123cheatn
              hey, @gohan it was working fine without mysensors library.
              gohanG 1 Reply Last reply
              • 1 123cheatn
                @123cheatn Ok, clear. Thanks for reporting back! :+1:
                • 1 123cheatn
                  @123cheatn if you make it to work with mysensors, pls report back
                    123cheatn
                    @gohan sure I will try.
                    • G
                      G
                      Gokhan Tuncel
                      @123cheatn I'm trying very similar project but could not achieve it :(
                      On master Arduino, RFID UID ID will be read and send to 4 other Arduinos; they will react regarding to UID ID (activate a relay, led etc.). Also those 4 Arduinos have MFRC522 but won't be sending RF UID ID's, just reacting depending on which UID ID read by their reader.
                      I think I could not solve multiple SPI module code :/ Here is my code;
                      #include <RF24.h>
                      #include <NRF24.h>
                      NRF24 radio;
                      unsigned long time_now = 0;
                      int blinkled = 300;
                      int value;
                      int displace = 1000;
                      unsigned long CountDownStarted = 0;
                      int CountdownState = 0;
                      int Set60State = 0;
                      int Set90State = 0;
                      int EngineState = 0;
                      #define EnginePin 6
                      #define StartPin 7
                      #define Set90Pin 8
                      #define Set60Pin 9
                      #define TestLed 13
                      String cardUID ;
                      #define SS_RF 10
                      #define RST 5
                      #define SS_NRF 53
                      MFRC522 mfrc522(SS_RF, RST);   // Create MFRC522 instance.
                      { pinMode(EnginePin, OUTPUT);
                        pinMode(StartPin, OUTPUT);
                        pinMode(Set90Pin, OUTPUT);
                        pinMode(Set60Pin, OUTPUT);
                        Serial.begin(115200);   // Initiate a serial communication
                        SPI.begin();      // Initiate  SPI bus
                        radio.setAddress(0xD2);
                        radio.begin(40, 53);
                        radio.setChannel(124);
                        radio.setRetries(0, 15);
                        radio.setActive(true);
                        pinMode(SS_RF, OUTPUT);
                        pinMode(SS_NRF, OUTPUT);
                        pinMode(TestLed, OUTPUT);
                        digitalWrite(EnginePin, LOW);
                        digitalWrite(StartPin, LOW);
                        digitalWrite(Set90Pin, LOW);
                        digitalWrite(Set60Pin, LOW);
                        digitalWrite(TestLed, LOW);
                        radio.startListening();
                        if (CountdownState == 1) {
                          CountDown();
                        if ( ! mfrc522.PICC_IsNewCardPresent())
                          return;
                        // Select one of the cards
                        if ( ! mfrc522.PICC_ReadCardSerial())
                          return;
                        //Show UID on serial monitor
                        Serial.print("UID tag :");
                        String content = "";
                        byte letter;
                        for (byte i = 0; i < mfrc522.uid.size; i++)
                          Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
                          Serial.print(mfrc522.uid.uidByte[i], HEX);
                          content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
                          content.concat(String(mfrc522.uid.uidByte[i], HEX));
                        Serial.println();
                        Serial.print("Message : ");
                        content.toUpperCase();
                        if (content.substring(1) == "E0 0A DD A4" || content.substring(1) == "C0 57 FE A7" || content.substring(1) == "B0 AB 9F A5" || content.substring(1) == "50 51 1B A4" )
                          if (EngineState == 0) {
                            digitalWrite(EnginePin, HIGH);
                            Serial.print(F("Sending Engine Code... "));
                            bool sent = radio.send(0xD3, "E0 0A DD A4");
                            bool sent2 = radio.send(0xD4, "E0 0A DD A4");
                            bool sent3 = radio.send(0xD5, "E0 0A DD A4");
                            bool sent4 = radio.send(0xD6, "E0 0A DD A4");
                            Serial.println(sent ? "OK" : "failed");
                            Serial.println(sent2 ? "OK" : "failed");
                            Serial.println(sent3 ? "OK" : "failed");
                            Serial.println(sent4 ? "OK" : "failed");
                            EngineState = 1;
                            delay(50);
                          if (EngineState == 1) {
                            delay(100);
                        if ((EngineState != 0) && (content.substring(1) == "CD 9E 08 75" || content.substring(1) == "7D A6 4F 75" || content.substring(1) == "8D 2B 55 75" || content.substring(1) == "DD D1 6C 3E" ))
                          if (CountdownState == 0) {
                            Serial.println("Countdown Started");
                            digitalWrite(StartPin, HIGH);
                            delay(50);
                            Serial.print(F("Sending Start Code... "));
                            bool sent = radio.send(0xD3, "CD 9E 08 75");
                            bool sent2 = radio.send(0xD4, "CD 9E 08 75");
                            bool sent3 = radio.send(0xD5, "CD 9E 08 75");
                            bool sent4 = radio.send(0xD6, "CD 9E 08 75");
                            CountdownState = 1;
                            delay(100);
                        if ((EngineState != 0) && (content.substring(1) == "7D 1C 65 5C" || content.substring(1) == "AD C2 5C 74"))
                          if (Set90State == 0) {
                            digitalWrite(Set90Pin, HIGH);
                            delay(50);
                            Serial.print(F("Sending 90' Code... "));
                            bool sent = radio.send(0xD3, "7D 1C 65 5C");
                            bool sent2 = radio.send(0xD4, "7D 1C 65 5C");
                            bool sent3 = radio.send(0xD5, "7D 1C 65 5C");
                            bool sent4 = radio.send(0xD6, "7D 1C 65 5C");
                            Set90State = 1;
                            delay(50);
                            delay(100);
                        if ((EngineState != 0) && (content.substring(1) == "20 C4 18 A4" || content.substring(1) == "1D AE 2C 75"))
                          if (Set60State == 0) {
                            digitalWrite(Set60Pin, HIGH);
                            delay(50);
                            bool sent = radio.send(0xD3, "20 C4 18 A4");
                            bool sent2 = radio.send(0xD4, "20 C4 18 A4");
                            bool sent3 = radio.send(0xD5, "20 C4 18 A4");
                            bool sent4 = radio.send(0xD6, "20 C4 18 A4");
                            Set60State = 1;
                            delay(50);
                            delay(100);
                        if (radio.available()) {
                          char buf[32];
                          uint8_t numBytes = radio.read(buf, sizeof(buf));
                          Serial.print(F("Received: "));
                          Serial.println(buf);
                      void CountDown() {
                        time_now = millis();
                        value = 128 + 127 * cos(2 * PI / blinkled * time_now);
                        analogWrite(TestLed, value);
                        //Serial.println(value);
                      Do you have any idea to solve this?
                      12.5k
