  3. Please help to build Raspberry Pi Gateway
23 Posts 5 Posters 5.1k Views 4 Watching
    BTW, why are you using the beta version?
    • B bigvlad
      Hello everybody!
      Please help to build Raspberry Pi Gateway.
      There is Raspberry Pi 3 model B.
      I do everything according to the instructions:
      https://www.mysensors.org/build/raspberry
      The compound NRF24L01 +
      Configuration:
      ./configure --my-transport = nrf24 --my-rf24-irq-pin = 15 --my-gateway = serial --my-serial-is-pty --my-serial-pty = / dev / ttyMySensorsGateway - -my-leds-err-pin = 12 --my-leds-rx-pin = 16 --my-leds-tx-pin = 18
      When you install branch master - I get an error
      "mysgw: Starting gateway ...
      mysgw: MCO: BGN: INIT GW, CP = RNNG ---, VER = 2.2.0-beta
      mysgw: TSM: INIT
      mysgw: TSF: WUR: MS = 0
      mysgw:! TSM: INIT: TSP FAIL
      mysgw: TSM: FAIL: CNT = 1
      mysgw: TSM: FAIL: PDT "
      If I install --branch development that all does not work.
      For Domoticz, I install the port / dev / ttyUSB20.
      Perhaps there is another instruction?
      dbemowskD
      dbemowskD
      @bigvlad Make sure when you are wiring to the GPIO port on the Pi, that you are using the pin number and NOT the GPIO number for the column labeled raspberry.
      This is stated right in the docs for building the gateway.
      Don't sweat it though. If that was your mistake, it is a common one.
      • F
        F
        fals3illusion
        @mfalkvidd said in Please help to build Raspberry Pi Gateway:
        Welcome to the MySensors community @bigvlad
        means the Raspberry Pi is unable to communicate with the nrf24 radio. The most common cause is wrong wiring. Double-check the wiring. If you can't find any fault, post photos. Getting a new pair of eyes often helps to discover mistakes.
        i am having this same problem. I have tried so many different radios/multiple RPI's with openhabian on them. When running the test it always says.. Checked the wiring 100x and i know i have the wiring correct. have tried it with and without a 10uf capacitor across VCC and GND. I did verify I am getting 3.3v across GND and VCC.
        I've tried both
        AND
        git clone https://github.com/mysensors/MySensors.git --branch development
        [09:52:00] openhabian@openHABianPi:~/MySensors$ sudo ./bin/mysgw
        Apr 19 09:52:02 INFO Starting gateway...
        Apr 19 09:52:02 INFO Protocol version - 2.3.0-alpha
        Apr 19 09:52:02 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,VER=2.3.0-alpha
        Apr 19 09:52:02 DEBUG TSF:LRT:OK
        Apr 19 09:52:02 DEBUG TSM:INIT
        Apr 19 09:52:02 DEBUG TSF:WUR:MS=0
        Apr 19 09:52:02 DEBUG !TSM:INIT:TSP FAIL
        Apr 19 09:52:02 DEBUG TSM:FAIL:CNT=1
        Apr 19 09:52:02 DEBUG TSM:FAIL:DIS
        Apr 19 09:52:02 DEBUG TSF:TDI:TSL
        Any ideas guys i'm going crazy trying to get this up and running?
        mfalkviddM gohanG 2 Replies Last reply
        • F fals3illusion
          I've tried both
          AND
          Welcome to the MySensors forums @fals3illusion !
          Could you post photos of your wiring? Maybe we can help spot something.
          Could you also post the full ./configure command you used?
          Were there any warnings or errors when running make?
          F 1 Reply Last reply
          • F fals3illusion
            I've tried both
            AND
            @fals3illusion did you try another image for raspberry like plain raspian or dietpi?
              F
              F
              fals3illusion
                F
                F
                fals3illusion
                @mfalkvidd
                sudo ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
                I did not see any warnings, maybe i am missing something.... here is full code that posts after make
                [13:42:36] openhabian@openHABianPi:~/MySensors$ make
                gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GA TEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_ CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_ MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c dri vers/Linux/log.c -o build/drivers/Linux/log.o
                gcc -MT build/drivers/Linux/config.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/config.c -o build/drivers/Linux/config.o
                g++ -MT build/drivers/Linux/StdInOutStream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/StdInOutStream.cpp -o build/drivers/Linux/StdInOutStream.o
                g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
                g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
                g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
                g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
                g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID="mygateway1" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mysensors-in" -DMY_MQTT_PUBLISH_TOPIC_PREFIX="mysensors-out" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
                g++ -pthread -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/config.o build/drivers/Linux/StdInOutStream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/compatibility.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/interrupt.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
                  Try to compile it as ethernet just as test
                    F
                    F
                    fals3illusion
                    @gohan
                    sorry im fairly new.. just this command correct?
                    sudo ./configure --my-gateway=ethernet --my-port=5003
                    • F fals3illusion
                      @gohan
                      F
                      F
                      fals3illusion
                      @fals3illusion said in Please help to build Raspberry Pi Gateway:
                      @gohan
                      if this is correct... still the same thing...
                      [14:03:59] openhabian@openHABianPi:~/MySensors$ sudo ./bin/mysgw
                      Apr 19 14:04:02 INFO Starting gateway...
                      Apr 19 14:04:02 INFO Protocol version - 2.3.0-alpha
                      Apr 19 14:04:02 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,VER=2.3.0-alpha
                      Apr 19 14:04:02 DEBUG TSF:LRT:OK
                      Apr 19 14:04:02 DEBUG TSM:INIT
                      Apr 19 14:04:02 DEBUG TSF:WUR:MS=0
                      Apr 19 14:04:02 DEBUG !TSM:INIT:TSP FAIL
                      Apr 19 14:04:02 DEBUG TSM:FAIL:CNT=1
                      Apr 19 14:04:02 DEBUG TSM:FAIL:DIS
                      Apr 19 14:04:02 DEBUG TSF:TDI:TSL
                        Use master branch pls and post a photo of your setup. Did you try other Linux images other than openhabian?
                        F 2 Replies Last reply
                          F
                          F
                          fals3illusion
                          @gohan
                          sorry, whats master branch? :see_no_evil:
                          I have yet to try any other images besides openhabian with MySensors. I'm at work now and in the process of installing rasbian on my test PI, once i get the rasbian configured, openhab and MQTT installed. I'll start to test and post updates.
                          Thanks for all the help! I try not to post unless I've researched for at least a whole day and ran out of all options!
                            The mysensors master branch from github that is version 2.2
                            Just install raspian, enable spi and compile the ethernet gateway, skip Openhab and mqtt for now so we keep fewer variables into play.
                              F
                              F
                              fals3illusion
                              wrote on last edited by fals3illusion
                              @gohan
                              duh, sorry had a brain fart.
                              Still got the same thing...
                              mysgw: Starting gateway...
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: !TSM:INIT:TSP FAIL
                              mysgw: TSM:FAIL:CNT=1
                              mysgw: TSM:FAIL:DIS
                              mysgw: TSF:TDI:TSL
                              Could it be that all of my radio's are bad?
                                F
                                F
                                fals3illusion
                                @gohan :
                                Here are pictures ...
                                https://www.use.com/editset.pl?set=4a4cfdfdbf7a504cf3c0
                                https://www.use.com/supersize.pl?set=b59559d26af25f54aca6&p=1
                                https://www.use.com/supersize.pl?set=6c01364aef48f2db2854&p=1
                                https://www.use.com/supersize.pl?set=6c01364aef48f2db2854&p=2
                                • F
                                  F
                                  fals3illusion
                                  Sorry for long post. This is what reads on SSH
                                  pi@raspberrypi:~/MySensors $ sudo ./configure --my-gateway=ethernet --my-port=5003
                                  [OK] SPI driver detected:BCM.
                                  [OK] Finished.
                                  pi@raspberrypi:~/MySensors $ make
                                  gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                  g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                  g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                  g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                                  g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                  g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                  g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                  g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                  g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                  g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                  g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                  g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                                  g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                  g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                  g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                  gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
                                  g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
                                  g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
                                  g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
                                  g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
                                  g++ -pthread -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
                                  • F fals3illusion
                                    @gohan :
                                    @fals3illusion the wiring looks good to me.
                                    • F
                                      F
                                      fals3illusion
                                      @gohan
                                      So, turns out that i had a pack of 10 sensors and just my luck the three that i happened to grab first to try and use were DOA. The other 7 work like a charm...
                                      Thanks for all of the help, will try not and use MQTT and openhab on it
                                        If you got the Chinese clones that sell for 10$ for 10, they are usually poor quality.
                                          F
                                          F
                                          fals3illusion
                                          @gohan
                                          Yeah, I’m guessing that’s what they are. I just got them from amazon just got into home automation and now I’m trying to learn, build, and play around with MySensors !!
                                          Which radios/sensors do you recomend for future purchases that are better quality build ?
                                          12.5k
