  3. Connecting sensor to gateway via RS485 instead of nRF24
rs485
13 Posts 5 Posters 10.9k Views 3 Watching
  • Johny MielonyJ
    Johny MielonyJ
    Johny Mielony
    Hi!
    Does anyone tried to connecting sensors with RS485 interface?
    I was wondering if it possible to replace wireless connection with wired one and maintaining all of protocol used. Just get rid of nRF24 routines and replacing them with those for RS485.
    A axillentA 2 Replies Last reply
    • Johny MielonyJ Johny Mielony
      Hi!
      andriej
      Great idea, especially when someone have an oppoturnity to lay cables in new built house.
        Hi!
        axillentA
        axillentA
        axillent
        @Johny-Mielony why not?
        the job gateway is doing is very simple
        you can modify gateway sketch to deal with RS485 instead of RF24 library
        sense and drive
        • Johny MielonyJ
          Johny MielonyJ
          Johny Mielony
          @axillent looking at gateway's sketch I find it quite easy to modify for listening on serial interface, it just passes messages between interfaces.
          But how about sensors? I find it more tricky. Do I understand it right? I mainly need to modify functions in MySensor.cpp as sendWrite and process? Or there is something else?
          • axillentA
            axillentA
            axillent
            all it depends on the protocol design on your RS485 network
            Possibly are 2 scenario here:
            1. using any free design for the communication between your rs485 sensors and rs485 gateway
              It can be any existing third party design
              In this scenario you will need to make sure that your gateway will translate messages from rs485 network to match the logic of mysensors network before sending data to Vera
            2. take a look to mysensors library. you can replicate the same data exchange using rs485 instead of nordic radio
              this thay your gateway will not need a translation, it will have just to pass data between Vera and rs485 network
            sense and drive
            • Johny MielonyJ
              Johny MielonyJ
              Johny Mielony
              I don't have any protocol on RS485, I wanted to use MySensors protocol.
              Idea is that I want to replace the physical layer of transmission.
              Where I can place cables I want to place them, but where I can't do that I want to use radio.
              I'm not using Vera, I'm going to use OpenHAB on single board computer.
              I need just hint where to start.
              axillentA 1 Reply Last reply
                axillentA
                axillentA
                axillent
                @Johny-Mielony just read about modbus today. Its logic is very similar to Mysensors - it have ID of the sender and ID of the reciever.
                Take a look, may be one of the modbus implementation can be used to pass mysensors data. I'm not sure it can match the need but may be it will - http://www.freemodbus.org/
                If you will succeed on this it can be a good value for the MySensors
                sense and drive
                • Johny MielonyJ
                  Johny MielonyJ
                  Johny Mielony
                  I know about modbus. At first I thought about using it, but it's more for industrial than home use.
                  I will experiment with RS485. I have some ideas, just need to find some time to test it.
                  Of course I will share if I get to something useful.
                  • ch3b7C
                    ch3b7C
                    ch3b7
                    See this https://www.kickstarter.com/projects/1370454848/chainduino
                    • ch3b7C ch3b7
                      axillentA
                      axillentA
                      axillent
                      @ch3b7 cool idea
                      but cat5 is too much
                      i just purchased a set of 6p6c connectors - phone standard
                      RS485 + power requires just 4 wires
                      have an idea of the set of devices to control my swimming pool
                      in my idea only the master device will be integrated to Mysensors, all other will not, it will be local RS485 network
                      But if Johny will be successful I will probably will connect all devices to MySensors)
                      sense and drive
                      • Johny MielonyJ
                        Johny MielonyJ
                        Johny Mielony
                        This chainduino looks good, but it is just arduino with on-board RS485 hardware. Still all job is done in software.
                        I'm thinking about encapsulating MySensors message into frame which will be sent via RS485 bus.
                        • ch3b7C
                          ch3b7C
                          ch3b7
                          http://sourceforge.net/p/arduino-icsc/wiki/RS-485/ this is a good library to start! now im stuck with ethernet controller in my program in .net at now i cant see any string but the gateway work good ¬¬ i need more time ^^
                          • N
                            N
                            nickma
                            Hi, Have you seen the following:
                            rs485-rs232-serial-transport-class-for-mysensors-org
                            Is that what you are looking for?
