  3. Serial communication between Arduino nano and ADC
ardunio nanoserial communicationadc
6 Posts 5 Posters 2.1k Views 5 Watching
  • D
    Derby Jhon
    Banned
    I wanted to interface analog sensor with Arduino nano using ADC, What is the best way to interface it using serial communication?
    How can I adjust the baud-rate of serial communication (suppose if I wanted to send the data at 200Kbps only) ?
    Any lead on this will be very helpful
    gohanG 1 Reply Last reply
    • mfalkviddM
      (link modified by moderator to avoid potential promotion attempt. Link now points to original TI component)
      • D Derby Jhon
        @derby-jhon that is I2C interface, it is not serial.
        • D
          Derby Jhon
          Banned
          wrote on last edited by Derby Jhon
          If I have connected analog sensor with I2C based ADC controller is it possible to send the I2C based data converted serially and send to arduino or not ?
          If yes then what will be the best way to do ?
          dbemowskD 1 Reply Last reply
          • tbowmoT
            tbowmoT
            tbowmo
            @Derby-Jhon
            The mcu on your arduino, has already I2C built in. I found this project that seems to be using the linked ADC with Arduino. So it could probably give some hints..
            • D Derby Jhon
              dbemowskD
              dbemowskD
              @derby-jhon Why are you concerned about sending it serially? Is there a reason you can't use I2C?
