  3. I'm stuck! - !TSM:FPAR:FAIL
14 Posts 6 Posters 3.1k Views 6 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    I'm seeing exactly the same with my atmega1284p based sensor, the atmega328p based sensors do get replies from the gateway, FPAR does get a response on my atmega328p sensors.
    Maybe this is a timing issue ?
      @zapped yes there is a legend. Read https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for a quick introduction to the most effective troubleshooting methods, and use the log parser to make the logs more readable.
      While these resources should give you more insight, they might not be sufficient for figuring out this particular problem.
      The sensor seems to be configured to use ID=123. Is this on purpose? If it isn't, use the ClearEeprom example on the sensor to clear the eeprom from old stuff, and then upload your sketch again.
      Z
      Z
      zapped
      wrote on last edited by zapped
      @mfalkvidd Many thanks for the link to the log parser!!
      Don't know where the 123 appeared from, must have set it at some point in the endless attempts I have made.
      Cleared EEPROM on both gw and node, and the log seems to have changed somewhat. It's now receiving OK response to FPAR, but then no response to ID:REQ.
      @GertSanders, I don't know that that's what's happening my end. All three of mine are 328p, however, gw is 3.3v pro mini (8MHz), one of the nodes I tried is 5v pro mini (16MHz), and the other node is the old 5v uno (also 16MHz). I did set them all to 38400. Just to rule something similar out, I've flashed the 5v pro mini with the gw code and ran the node on the uno.
      Logs now with the setup mentioned above:
      Gateway:
      0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
      0;255;3;0;9;13 TSM:INIT
      0;255;3;0;9;19 TSF:WUR:MS=0
      0;255;3;0;9;32 TSM:INIT:TSP OK
      0;255;3;0;9;40 TSM:INIT:GW MODE
      0;255;3;0;9;49 TSM:READY:ID=0,PAR=0,DIS=0
      0;255;3;0;9;60 MCO:REG:NOT NEEDED
      0;255;0;0;18;2.2.0
      0;255;3;0;9;70 MCO:BGN:STP
      0;255;3;0;9;92 MCO:BGN:INIT OK,TSP=1
      0;255;3;0;9;7264 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;7282 TSF:MSG:BC
      0;255;3;0;9;7289 TSF:MSG:FPAR REQ,ID=255
      0;255;3;0;9;7301 TSF:CKU:OK,FCTRL
      0;255;3;0;9;7310 TSF:MSG:GWL OK
      0;255;3;0;9;7503 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;7526 TSF:MSG:READ,255-255-0,s=18,c=3,t=3,pt=0,l=0,sg=0:
      255;18;3;0;3;
      0;255;3;0;9;9537 TSF:MSG:READ,255-255-0,s=252,c=3,t=3,pt=0,l=0,sg=0:
      255;252;3;0;3;
      0;255;3;0;9;11565 TSF:MSG:READ,255-255-0,s=232,c=3,t=3,pt=0,l=0,sg=0:
      255;232;3;0;3;
      0;255;3;0;9;13593 TSF:MSG:READ,255-255-0,s=212,c=3,t=3,pt=0,l=0,sg=0:
      255;212;3;0;3;
      0;255;3;0;9;25661 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;25679 TSF:MSG:BC
      0;255;3;0;9;25688 TSF:MSG:FPAR REQ,ID=255
      0;255;3;0;9;25699 TSF:PNG:SEND,TO=0
      0;255;3;0;9;25708 TSF:CKU:OK
      0;255;3;0;9;25716 TSF:MSG:GWL OK
      0;255;3;0;9;25884 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;25907 TSF:MSG:READ,255-255-0,s=223,c=3,t=3,pt=0,l=0,sg=0:
      255;223;3;0;3;
      0;255;3;0;9;27923 TSF:MSG:READ,255-255-0,s=203,c=3,t=3,pt=0,l=0,sg=0:
      255;203;3;0;3;
      0;255;3;0;9;29952 TSF:MSG:READ,255-255-0,s=184,c=3,t=3,pt=0,l=0,sg=0:
      255;184;3;0;3;
      0;255;3;0;9;31980 TSF:MSG:READ,255-255-0,s=164,c=3,t=3,pt=0,l=0,sg=0:
      255;164;3;0;3;
      0;255;3;0;9;44049 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;44068 TSF:MSG:BC
      0;255;3;0;9;44076 TSF:MSG:FPAR REQ,ID=255
      0;255;3;0;9;44087 TSF:PNG:SEND,TO=0
      0;255;3;0;9;44096 TSF:CKU:OK
      0;255;3;0;9;44104 TSF:MSG:GWL OK
      0;255;3;0;9;44229 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;44252 TSF:MSG:READ,255-255-0,s=134,c=3,t=3,pt=0,l=0,sg=0:
      255;134;3;0;3;
      0;255;3;0;9;46268 TSF:MSG:READ,255-255-0,s=114,c=3,t=3,pt=0,l=0,sg=0:
      255;114;3;0;3;
      0;255;3;0;9;48296 TSF:MSG:READ,255-255-0,s=95,c=3,t=3,pt=0,l=0,sg=0:
      255;95;3;0;3;
      0;255;3;0;9;50326 TSF:MSG:READ,255-255-0,s=75,c=3,t=3,pt=0,l=0,sg=0:
      255;75;3;0;3;
      0;255;3;0;9;62394 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;62413 TSF:MSG:BC
      0;255;3;0;9;62420 TSF:MSG:FPAR REQ,ID=255
      0;255;3;0;9;62432 TSF:PNG:SEND,TO=0
      0;255;3;0;9;62442 TSF:CKU:OK
      0;255;3;0;9;62449 TSF:MSG:GWL OK
      0;255;3;0;9;63512 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;63534 TSF:MSG:READ,255-255-0,s=214,c=3,t=3,pt=0,l=0,sg=0:
      255;214;3;0;3;
      0;255;3;0;9;65550 TSF:MSG:READ,255-255-0,s=194,c=3,t=3,pt=0,l=0,sg=0:
      255;194;3;0;3;
      0;255;3;0;9;67579 TSF:MSG:READ,255-255-0,s=175,c=3,t=3,pt=0,l=0,sg=0:
      255;175;3;0;3;
      0;255;3;0;9;69608 TSF:MSG:READ,255-255-0,s=155,c=3,t=3,pt=0,l=0,sg=0:
      255;155;3;0;3;
      0;255;3;0;9;81678 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;81696 TSF:MSG:BC
      0;255;3;0;9;81704 TSF:MSG:FPAR REQ,ID=255
      0;255;3;0;9;81716 TSF:PNG:SEND,TO=0
      0;255;3;0;9;81725 TSF:CKU:OK
      0;255;3;0;9;81733 TSF:MSG:GWL OK
      0;255;3;0;9;82622 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;82644 TSF:MSG:READ,255-255-0,s=121,c=3,t=3,pt=0,l=0,sg=0:
      255;121;3;0;3;
      0;255;3;0;9;84661 TSF:MSG:READ,255-255-0,s=102,c=3,t=3,pt=0,l=0,sg=0:
      255;102;3;0;3;
      0;255;3;0;9;86689 TSF:MSG:READ,255-255-0,s=82,c=3,t=3,pt=0,l=0,sg=0:
      255;82;3;0;3;
      0;255;3;0;9;88718 TSF:MSG:READ,255-255-0,s=63,c=3,t=3,pt=0,l=0,sg=0:
      255;63;3;0;3;
      0;255;3;0;9;100789 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;100808 TSF:MSG:BC
      0;255;3;0;9;100816 TSF:MSG:FPAR REQ,ID=255
      0;255;3;0;9;100828 TSF:PNG:SEND,TO=0
      0;255;3;0;9;100837 TSF:CKU:OK
      0;255;3;0;9;100845 TSF:MSG:GWL OK
      0;255;3;0;9;101392 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;101414 TSF:MSG:READ,255-255-0,s=201,c=3,t=3,pt=0,l=0,sg=0:
      255;201;3;0;3;
      0;255;3;0;9;103431 TSF:MSG:READ,255-255-0,s=182,c=3,t=3,pt=0,l=0,sg=0:
      255;182;3;0;3;
      0;255;3;0;9;105459 TSF:MSG:READ,255-255-0,s=162,c=3,t=3,pt=0,l=0,sg=0:
      255;162;3;0;3;
      0;255;3;0;9;107489 TSF:MSG:READ,255-255-0,s=143,c=3,t=3,pt=0,l=0,sg=0:
      255;143;3;0;3;
      0;255;3;0;9;119561 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;119580 TSF:MSG:BC
      0;255;3;0;9;119588 TSF:MSG:FPAR REQ,ID=255
      0;255;3;0;9;119600 TSF:PNG:SEND,TO=0
      0;255;3;0;9;119610 TSF:CKU:OK
      0;255;3;0;9;119618 TSF:MSG:GWL OK
      0;255;3;0;9;120506 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;120528 TSF:MSG:READ,255-255-0,s=114,c=3,t=3,pt=0,l=0,sg=0:
      255;114;3;0;3;
      0;255;3;0;9;122547 TSF:MSG:READ,255-255-0,s=95,c=3,t=3,pt=0,l=0,sg=0:
      255;95;3;0;3;
      0;255;3;0;9;124576 TSF:MSG:READ,255-255-0,s=76,c=3,t=3,pt=0,l=0,sg=0:
      255;76;3;0;3;
      0;255;3;0;9;126606 TSF:MSG:READ,255-255-0,s=58,c=3,t=3,pt=0,l=0,sg=0:
      255;58;3;0;3;
      Node:
      0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
      10 TSM:INIT
      13 TSF:WUR:MS=0
      23 TSM:INIT:TSP OK
      28 TSM:FPAR
      32 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      238 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      253 TSF:MSG:FPAR PREF
      259 TSF:MSG:FPAR OK,ID=0,D=1
      267 TSM:FPAR:OK
      271 TSM:ID
      274 TSM:ID:REQ
      279 TSF:MSG:SEND,255-255-0-0,s=18,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      2297 TSM:ID
      2300 TSM:ID:REQ
      2306 TSF:MSG:SEND,255-255-0-0,s=252,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      4325 TSM:ID
      4328 TSM:ID:REQ
      4333 TSF:MSG:SEND,255-255-0-0,s=232,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      6353 TSM:ID
      6356 TSM:ID:REQ
      6362 TSF:MSG:SEND,255-255-0-0,s=212,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      8381 !TSM:ID:FAIL
      8385 TSM:FAIL:CNT=1
      8391 TSM:FAIL:DIS
      8395 TSF:TDI:TSL
      18401 TSM:FAIL:RE-INIT
      18407 TSM:INIT
      18416 TSM:INIT:TSP OK
      18422 TSM:FPAR
      18427 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      18617 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      18632 TSF:MSG:FPAR PREF
      18638 TSF:MSG:FPAR OK,ID=0,D=1
      18647 TSM:FPAR:OK
      18652 TSM:ID
      18655 TSM:ID:REQ
      18661 TSF:MSG:SEND,255-255-0-0,s=223,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      20680 TSM:ID
      20683 TSM:ID:REQ
      20689 TSF:MSG:SEND,255-255-0-0,s=203,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      22709 TSM:ID
      22712 TSM:ID:REQ
      22718 TSF:MSG:SEND,255-255-0-0,s=184,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      24737 TSM:ID
      24740 TSM:ID:REQ
      24747 TSF:MSG:SEND,255-255-0-0,s=164,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      26766 !TSM:ID:FAIL
      26771 TSM:FAIL:CNT=2
      26776 TSM:FAIL:DIS
      26781 TSF:TDI:TSL
      36787 TSM:FAIL:RE-INIT
      36793 TSM:INIT
      36802 TSM:INIT:TSP OK
      36808 TSM:FPAR
      36813 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      36960 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      36975 TSF:MSG:FPAR PREF
      36981 TSF:MSG:FPAR OK,ID=0,D=1
      36989 TSM:FPAR:OK
      36995 TSM:ID
      36998 TSM:ID:REQ
      37004 TSF:MSG:SEND,255-255-0-0,s=134,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      39023 TSM:ID
      39026 TSM:ID:REQ
      39032 TSF:MSG:SEND,255-255-0-0,s=114,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      41052 TSM:ID
      41055 TSM:ID:REQ
      41061 TSF:MSG:SEND,255-255-0-0,s=95,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      43080 TSM:ID
      43083 TSM:ID:REQ
      43089 TSF:MSG:SEND,255-255-0-0,s=75,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      45109 !TSM:ID:FAIL
      45114 TSM:FAIL:CNT=3
      45119 TSM:FAIL:DIS
      45124 TSF:TDI:TSL
      55130 TSM:FAIL:RE-INIT
      55136 TSM:INIT
      55145 TSM:INIT:TSP OK
      55151 TSM:FPAR
      55156 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      56240 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      56255 TSF:MSG:FPAR PREF
      56261 TSF:MSG:FPAR OK,ID=0,D=1
      56269 TSM:FPAR:OK
      56274 TSM:ID
      56278 TSM:ID:REQ
      56284 TSF:MSG:SEND,255-255-0-0,s=214,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      58303 TSM:ID
      58306 TSM:ID:REQ
      58312 TSF:MSG:SEND,255-255-0-0,s=194,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      60332 TSM:ID
      60335 TSM:ID:REQ
      60341 TSF:MSG:SEND,255-255-0-0,s=175,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      62360 TSM:ID
      62363 TSM:ID:REQ
      62369 TSF:MSG:SEND,255-255-0-0,s=155,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      64389 !TSM:ID:FAIL
      64394 TSM:FAIL:CNT=4
      64399 TSM:FAIL:DIS
      64404 TSF:TDI:TSL
      74411 TSM:FAIL:RE-INIT
      74417 TSM:INIT
      74426 TSM:INIT:TSP OK
      74432 TSM:FPAR
      74437 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      75347 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      75363 TSF:MSG:FPAR PREF
      75369 TSF:MSG:FPAR OK,ID=0,D=1
      75377 TSM:FPAR:OK
      75382 TSM:ID
      75385 TSM:ID:REQ
      75392 TSF:MSG:SEND,255-255-0-0,s=121,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      77411 TSM:ID
      77414 TSM:ID:REQ
      77420 TSF:MSG:SEND,255-255-0-0,s=102,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      79439 TSM:ID
      79442 TSM:ID:REQ
      79449 TSF:MSG:SEND,255-255-0-0,s=82,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      81468 TSM:ID
      81471 TSM:ID:REQ
      81477 TSF:MSG:SEND,255-255-0-0,s=63,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      83497 !TSM:ID:FAIL
      83503 TSM:FAIL:CNT=5
      83508 TSM:FAIL:DIS
      83513 TSF:TDI:TSL
      93519 TSM:FAIL:RE-INIT
      93526 TSM:INIT
      93535 TSM:INIT:TSP OK
      93541 TSM:FPAR
      93546 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      94115 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      94130 TSF:MSG:FPAR PREF
      94137 TSF:MSG:FPAR OK,ID=0,D=1
      94145 TSM:FPAR:OK
      94150 TSM:ID
      94153 TSM:ID:REQ
      94159 TSF:MSG:SEND,255-255-0-0,s=201,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      96179 TSM:ID
      96182 TSM:ID:REQ
      96188 TSF:MSG:SEND,255-255-0-0,s=182,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      98207 TSM:ID
      98210 TSM:ID:REQ
      98216 TSF:MSG:SEND,255-255-0-0,s=162,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      100236 TSM:ID
      100239 TSM:ID:REQ
      100245 TSF:MSG:SEND,255-255-0-0,s=143,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      102265 !TSM:ID:FAIL
      102270 TSM:FAIL:CNT=6
      102277 TSM:FAIL:DIS
      102282 TSF:TDI:TSL
      112288 TSM:FAIL:RE-INIT
      112294 TSM:INIT
      112305 TSM:INIT:TSP OK
      112311 TSM:FPAR
      112316 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      113226 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      113242 TSF:MSG:FPAR PREF
      113248 TSF:MSG:FPAR OK,ID=0,D=1
      113257 TSM:FPAR:OK
      113262 TSM:ID
      113266 TSM:ID:REQ
      113272 TSF:MSG:SEND,255-255-0-0,s=114,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      115292 TSM:ID
      115295 TSM:ID:REQ
      115301 TSF:MSG:SEND,255-255-0-0,s=95,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      117321 TSM:ID
      117324 TSM:ID:REQ
      117330 TSF:MSG:SEND,255-255-0-0,s=76,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      119351 TSM:ID
      119354 TSM:ID:REQ
      119360 TSF:MSG:SEND,255-255-0-0,s=58,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      121380 !TSM:ID:FAIL
      121385 TSM:FAIL:CNT=7
      121392 TSM:FAIL:DIS
      121397 TSF:TDI:TSL```
      • Z zapped
        Gateway:
        0;255;0;0;18;2.2.0
        255;18;3;0;3;
        255;252;3;0;3;
        255;232;3;0;3;
        255;212;3;0;3;
        255;223;3;0;3;
        255;203;3;0;3;
        255;184;3;0;3;
        255;164;3;0;3;
        255;134;3;0;3;
        255;114;3;0;3;
        255;95;3;0;3;
        255;75;3;0;3;
        255;214;3;0;3;
        255;194;3;0;3;
        255;175;3;0;3;
        255;155;3;0;3;
        255;121;3;0;3;
        255;102;3;0;3;
        255;82;3;0;3;
        255;63;3;0;3;
        255;201;3;0;3;
        255;182;3;0;3;
        255;162;3;0;3;
        255;143;3;0;3;
        255;114;3;0;3;
        255;95;3;0;3;
        255;76;3;0;3;
        255;58;3;0;3;
        Node:
        10 TSM:INIT
        13 TSF:WUR:MS=0
        23 TSM:INIT:TSP OK
        28 TSM:FPAR
        267 TSM:FPAR:OK
        271 TSM:ID
        274 TSM:ID:REQ
        2297 TSM:ID
        2300 TSM:ID:REQ
        4325 TSM:ID
        4328 TSM:ID:REQ
        6353 TSM:ID
        6356 TSM:ID:REQ
        8381 !TSM:ID:FAIL
        8385 TSM:FAIL:CNT=1
        8391 TSM:FAIL:DIS
        8395 TSF:TDI:TSL
        18407 TSM:INIT
        18422 TSM:FPAR
        18647 TSM:FPAR:OK
        18652 TSM:ID
        18655 TSM:ID:REQ
        20680 TSM:ID
        20683 TSM:ID:REQ
        22709 TSM:ID
        22712 TSM:ID:REQ
        24737 TSM:ID
        24740 TSM:ID:REQ
        26766 !TSM:ID:FAIL
        26776 TSM:FAIL:DIS
        26781 TSF:TDI:TSL
        36793 TSM:INIT
        36808 TSM:FPAR
        36989 TSM:FPAR:OK
        36995 TSM:ID
        36998 TSM:ID:REQ
        39023 TSM:ID
        39026 TSM:ID:REQ
        41052 TSM:ID
        41055 TSM:ID:REQ
        43080 TSM:ID
        43083 TSM:ID:REQ
        45109 !TSM:ID:FAIL
        45119 TSM:FAIL:DIS
        45124 TSF:TDI:TSL
        55136 TSM:INIT
        55151 TSM:FPAR
        56269 TSM:FPAR:OK
        56274 TSM:ID
        56278 TSM:ID:REQ
        58303 TSM:ID
        58306 TSM:ID:REQ
        60332 TSM:ID
        60335 TSM:ID:REQ
        62360 TSM:ID
        62363 TSM:ID:REQ
        64389 !TSM:ID:FAIL
        64399 TSM:FAIL:DIS
        64404 TSF:TDI:TSL
        74417 TSM:INIT
        74432 TSM:FPAR
        75377 TSM:FPAR:OK
        75382 TSM:ID
        75385 TSM:ID:REQ
        77411 TSM:ID
        77414 TSM:ID:REQ
        79439 TSM:ID
        79442 TSM:ID:REQ
        81468 TSM:ID
        81471 TSM:ID:REQ
        83497 !TSM:ID:FAIL
        83508 TSM:FAIL:DIS
        83513 TSF:TDI:TSL
        93526 TSM:INIT
        93541 TSM:FPAR
        94145 TSM:FPAR:OK
        94150 TSM:ID
        94153 TSM:ID:REQ
        96179 TSM:ID
        96182 TSM:ID:REQ
        98207 TSM:ID
        98210 TSM:ID:REQ
        100236 TSM:ID
        100239 TSM:ID:REQ
        102265 !TSM:ID:FAIL
        102277 TSM:FAIL:DIS
        102282 TSF:TDI:TSL
        112294 TSM:INIT
        112311 TSM:FPAR
        113257 TSM:FPAR:OK
        113262 TSM:ID
        113266 TSM:ID:REQ
        115292 TSM:ID
        115295 TSM:ID:REQ
        117321 TSM:ID
        117324 TSM:ID:REQ
        119351 TSM:ID
        119354 TSM:ID:REQ
        121380 !TSM:ID:FAIL
        121392 TSM:FAIL:DIS
        @zapped the controller is responsible for handing out IDs. Are you using a controller? If not, use one or set static ID on all nodes.
        Documentation: https://www.mysensors.org/apidocs/group__RoutingNodeSettingGrpPub.html#gac677233da7f20bbf93cb479471e3234e
        Z 1 Reply Last reply
          Z
          Z
          zapped
          @mfalkvidd That would explain a few things! :bulb: ;)
          I've installed HomeGenie on pi (mainly because it supports C# and I'm not as fluent in C++ or Java), but from what I can see, it's support for MySensors is in beta (though the Controllers comparison page is quite old, so don't know how reliable that info is).
          I basically wanted something with a nice GUI that I wouldn't have to spend too much time prettying up (or prettying up in C++ or Java, for that matter :) ). I'll try connecting the two and have a play with it this weekend.
          Thanks again for your help!
          alexsh1A 1 Reply Last reply
          • Z zapped
            alexsh1A
            alexsh1A
            alexsh1
            @zapped
            Try Domoticz. You will be able to quickly set it up and it does have a nice GUI
            • alexsh1A alexsh1
              @zapped
              Z
              Z
              zapped
              @alexsh1 Thanks for the suggestion, will give it a go this weekend! :)
              • alowhumA
                alowhumA
                alowhum
                What helped me was to clear the eeprom of the Arduino. there's a special sketch for that under examples.
                It seems dabbling with encryption made my nodes not want to connect when I used them without encryption.
                AnticimexA 1 Reply Last reply
                • alowhumA alowhum
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alowhum no, encryption has to be enabled on all devices if the gateway use it. And they have to use the same key.
                  • alowhumA
                    alowhumA
                    alowhum
                    My gateway does not use encryption yet. But I was trying to get some sketches' memory use small enough so that they would work when I switch to encryption. To test this, I enabled MY_SIGNING_SIMPLE_PASSWD encryption on them, and then checked if memory use stayed below 80%.
                    Then, when I commented out MY_SIGNING_SIMPLE_PASSWD, I expected the node to just reconnect to my non-encrypted network. But it didn't.
                    When I first noticed that nodes I was building (with old nano's) weren't connecting to Domoticz, I blamed domoticz. And then I started using the 'manual' connection settings. Here's some code from a node:
                    //#define MY_NODE_ID 13                             // for some reason my controller won't allow more than 10 nodes.
                    //#define MY_PARENT_NODE_ID 0
                    Once I cleared the eeprom, Domoticz auto-connects again. Yay!
                    Even though this was probably in the documentation, it never even occured to me to look there for the solution to my problem. I didn't know a Arduino/MySensors had 'hidden settings' which persisted.
                    Perhaps MySensors could clear the eeprom's encryption settings if the node does not implement encryption anymore?
                    • alowhumA alowhum
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alowhum then I think it is related to node id:s. The simple flags does not write to eeprom nor does they read from it. Hence the term "simple". Only the security personalizer does that and I assume you did not run that.
                      • alowhumA
                        alowhumA
                        alowhum
                        Hmm, oh dear. I thought I has solved the mystery :-(
                        • alowhumA alowhum
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @alowhum one way to check is to run the security personaliser without changing it. It will print the security related contents in eeprom. Then enable the simple flag, run a sketch with it, then re-run the personaliser and see if the eeprom content changed.
                          12.5k
