  3. Request Value from Node
15 Posts 4 Posters 3.9k Views 4 Watching
    take a look at this https://www.mysensors.org/build/pulse_power
    SoloamS
    SoloamS
    Soloam
    @gohan Ii can see the request:
        } else if (sendTime && !pcReceived) {
            // No pulse count value received. Try requesting it again
            request(CHILD_ID, V_VAR1);
            lastSend=now;
    But I can't seem to understand where is being processed, in the receive function no validation is preformed to check if it's a request or a actuation. In this case I presume that It's irrelevant (because is a informative node only), but in the case of a nodes with actuators, I need to know if the message that is arriving is a actuator (set) or a request.
      It is checking if it is a V_VAR1 message, the other messages use different variable types
      SoloamS 1 Reply Last reply
        SoloamS
        SoloamS
        Soloam
        @gohan I see, it's the same solution that i'm using at the moment, it would be nice to have a flag in the requests replay, that would allow to make a cleaner code, without having to use dummy variables.
        Thank You @gohan
          I am using the pulse power meter but I didn't use any dummy variable. Also the controller plays a role too.
            SoloamS
            SoloamS
            Soloam
            @gohan you don't use a dummy variable (VAR_1)? So who do you know when the message arrives if it's a request?
            • SoloamS Soloam
              rozpruwaczR
              rozpruwaczR
              rozpruwacz
              I think that @Soloam is asking how can a gateway request a value from the node not how node can request a value from gateway. If so then You must hadle it in the receive funtion (https://www.mysensors.org/download/sensor_api_20#requesting-data). The request message has distinct command type (https://www.mysensors.org/download/serial_api_20). You can get the message command type with getCommand method - unfortunetly this is not documented ... why ?
              • rozpruwaczR rozpruwacz
                SoloamS
                SoloamS
                Soloam
                wrote on last edited by Soloam
                @rozpruwacz You are rigth, I Want GW => Node Request or Node => Node Requests, and I've seen the command type in the notes, but who can I access that command value in the code?
                1;1;2;0;2;0 - Requesting Node 1 Child 1 variable V_STATUS, Who do I know that the Command is 2 (request) ?
                mfalkviddM rozpruwaczR 2 Replies Last reply
                • SoloamS Soloam
                  @soloam looks like you should be able to use mGetCommand and check for C_SET / C_REQ.
                  SoloamS rozpruwaczR 2 Replies Last reply
                    SoloamS
                    SoloamS
                    Soloam
                    @mfalkvidd thank you, that will do the job! I leave the ideia to a isReq()! :)
                    Thank you all
                    • SoloamS Soloam
                      rozpruwaczR
                      rozpruwaczR
                      rozpruwacz
                      @soloam said in Request Value from Node:
                      as I said You need to use getCommand method on the message object.
                        rozpruwaczR
                        rozpruwaczR
                        rozpruwacz
                        wrote on last edited by rozpruwacz
                        @mfalkvidd said in Request Value from Node:
                        Is this mGetCommand is official API ? because it does not look like. I wouldn't use undocumented methods, because they may disapear in new releases.
                          @rozpruwacz yes it is.
                          • rozpruwaczR
                            rozpruwaczR
                            rozpruwacz
                            I didn't see that before, thanks :)
