  3. Request Value from Node
15 Posts 4 Posters 3.5k Views 4 Watching
  • S Offline
    Soloam
    Hello all, is there a way in the response method to check if is a request? Similar to for example the isACK method, how can I know if the message arriving is a request os if is a message that should actuate the node?
    Thank you
      take a look at this https://www.mysensors.org/build/pulse_power
      S 1 Reply Last reply
        Soloam
        @gohan Ii can see the request:
            } else if (sendTime && !pcReceived) {
                // No pulse count value received. Try requesting it again
                request(CHILD_ID, V_VAR1);
                lastSend=now;
        But I can't seem to understand where is being processed, in the receive function no validation is preformed to check if it's a request or a actuation. In this case I presume that It's irrelevant (because is a informative node only), but in the case of a nodes with actuators, I need to know if the message that is arriving is a actuator (set) or a request.
          It is checking if it is a V_VAR1 message, the other messages use different variable types
            Soloam
            @gohan I see, it's the same solution that i'm using at the moment, it would be nice to have a flag in the requests replay, that would allow to make a cleaner code, without having to use dummy variables.
            Thank You @gohan
              I am using the pulse power meter but I didn't use any dummy variable. Also the controller plays a role too.
                Soloam
                @gohan you don't use a dummy variable (VAR_1)? So who do you know when the message arrives if it's a request?
                • S Soloam
                  rozpruwaczR Offline
                  rozpruwaczR Offline
                  rozpruwacz
                  I think that @Soloam is asking how can a gateway request a value from the node not how node can request a value from gateway. If so then You must hadle it in the receive funtion (https://www.mysensors.org/download/sensor_api_20#requesting-data). The request message has distinct command type (https://www.mysensors.org/download/serial_api_20). You can get the message command type with getCommand method - unfortunetly this is not documented ... why ?
                  • rozpruwaczR rozpruwacz
                    Soloam
                    wrote on last edited by Soloam
                    @rozpruwacz You are rigth, I Want GW => Node Request or Node => Node Requests, and I've seen the command type in the notes, but who can I access that command value in the code?
                    1;1;2;0;2;0 - Requesting Node 1 Child 1 variable V_STATUS, Who do I know that the Command is 2 (request) ?
                    mfalkviddM rozpruwaczR 2 Replies Last reply
                    • S Soloam
                      @soloam looks like you should be able to use mGetCommand and check for C_SET / C_REQ.
                      S rozpruwaczR 2 Replies Last reply
                        Soloam
                        @mfalkvidd thank you, that will do the job! I leave the ideia to a isReq()! :)
                        Thank you all
                        • S Soloam
                          rozpruwaczR Offline
                          rozpruwaczR Offline
                          rozpruwacz
                          @soloam said in Request Value from Node:
                          as I said You need to use getCommand method on the message object.
                            rozpruwaczR Offline
                            rozpruwaczR Offline
                            rozpruwacz
                            wrote on last edited by rozpruwacz
                            @mfalkvidd said in Request Value from Node:
                            Is this mGetCommand is official API ? because it does not look like. I wouldn't use undocumented methods, because they may disapear in new releases.
                              @rozpruwacz yes it is.
                              • rozpruwaczR Offline
                                rozpruwaczR Offline
                                rozpruwacz
                                I didn't see that before, thanks :)
                                12.2k
