  3. No MY_DEBUGDEVICE.begin ?
5 Posts 3 Posters 1.3k Views 3 Watching
  • F
    F
    fac13
    I've been testing a Genuino Zero as a serial gateway. Everything works fine except for the redirection of debug output to the Programming port.
    I saw a thread and a pull request which added MY_DEBUGDEVICE to the architecture files, but if I #define MY_DEBUGDEVICE SERIAL my gateway crashes, silently.
    I believe this is because there is no 'begin' for MY_DEBUGDEVICE.
    When I add one to to relevant architecture file it works fine, with debug output sent as expected to the Programming port.
    I'm a bit puzzled how anybody has got this to work without that mod, have I missed something?
    Note that adding MY_DEBUGDEVICE.begin into Setup in the sketch is too late - the node crashes before it gets to that point.
    • tbowmoT
      tbowmoT
      tbowmo
      I think that it's probably because you are the first that use a separate port for debugging..
      in hwInit for SAMD architecture, we only initialize the standard serial port (MY_SERIALDEVICE)
      https://github.com/mysensors/MySensors/blob/59b15f5824bf060fa153b30065d089b04fff77c7/hal/architecture/SAMD/MyHwSAMD.cpp#L70
      • F fac13
        @fac13 as a workaround, could you try placing MY_DEBUGDEVICE.begin in a function called before() or preHwInit() in your sketch? MySensors will execute them before setup().
        F 1 Reply Last reply
          F
          F
          fac13
          wrote on last edited by fac13
          @mfalkvidd I tried both and neither worked - the node still failed to start.
          My workaround is to add MY_DEBUGDEVICE initialization in hwInit() in MyHwSAMD.cpp , immediately after the initialization of MY_SERIALDEVICE,
          i.e. insert these lines after line #76: -
          MY_DEBUGDEVICE.begin(MY_BAUD_RATE);
          #if defined(MY_GATEWAY_SERIAL)
          while (!MY_DEBUGDEVICE) {}
          Of course if the two devices are the same then MY_SERIALDEVICE gets initialized twice, but doesn't seem to cause a problem.
          • F fac13
            F
            F
            fac13
            fac13 about 2 hours ago
            I realized I should have added a wait after the initialization, like this: -
            void preHwInit()
            MY_DEBUGDEVICE.begin(115200);
            while(!MY_DEBUGDEVICE){};
            With that included, my sketch works without needing the architecture code mod.
            Putting the same code in before() doesn't work.
            Thanks for your help.
