  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 116.9k Views 41 Watching
  • RFM69R RFM69
    Great code, another question.
    For the SensorDimmer, each sensor has only one type set so a dimmer can't receive v_status & v_percentage messages.
    I've worked around this by registering two sensors at the same Analog out pin. But they don't then have access in a nice way to the status of each other as values are changed. So if I turn the led on/off via the v_status message I can't preserve the previous percentage, set by the other v_percentage sensor.
    Is this normal ? I'm new to all this but at least mycontroller lets you specify for a single sensor both v_status,v_percentage so both types of messages can be sent and processed in onRecieve()...
    Perhaps some enhancement on the SensorDimmer class could do this ? in ModeManager.cpp (if (message.type != _type) return;) inside Sensor::recieve.... isn't that too restrictive ?
    U
    U
    user2684
    @rfm69 for your SensorDimmer request, feel free to give v1.7-dev a try from here https://github.com/mysensors/NodeManager/tree/development. Details on the implementation of your request can be found at https://github.com/mysensors/NodeManager/pull/302. Thanks
    • U
      U
      user2684
      Hi, for anybody interested in giving the upcoming NodeManager v1.7 a try or share a feedback, please have a look at https://forum.mysensors.org/topic/9085/nodemanager-v1-7-beta-feedback-needed. Thanks!
      • U
        U
        user2684
        Hi, the new version of NodeManager (v1.7) is now available! For those interested in having a look at the new features, supported sensors and capabilities, I've opened a dedicated thread on the forum here https://forum.mysensors.org/topic/9165/nodemanager-v1-7-now-available
        • U user2684
          mvader
          @user2684 in the sensebender sketch we turn on digital pin 7 to provide power to the LDR to read it.
          i have many sensors in my house and would rather not re-wire all of them.
          how can i add this cleanly in nodemgr to make it work as before?
          pinMode(7, OUTPUT); // “power pin” for Light Sensor
          digitalWrite(7, LOW); // switch power off
          U 1 Reply Last reply
          • M mvader
            U
            U
            user2684
            @mvader thanks for the feedback, I've added this issue on Github so to fix this in the next dev release https://github.com/mysensors/NodeManager/issues/344
            • U user2684
              mvader
              wrote on last edited by mvader
              #156
              @user2684 said in 💬 NodeManager:
              Thanks!! here is the setup and loop part from the sketch
              setup
              loop
                digitalWrite(7, HIGH); // switch power on to LDR
                sendLight(forceTransmit);
                digitalWrite(7, LOW); // switch power off to LDR
              and the function
               * Sends Ambient Light Sensor information
               * Parameters
              void sendLight(bool force) // Get light level
                if (force) lastLightLevel = -1;
                int rlightLevel =  analogRead(LIGHT_PIN);
                int lightLevel =  (analogRead(LIGHT_PIN) / 10.23) ;
                 gw.send(msgLight.set(lightLevel));
                  lastLightLevel = lightLevel;
              • C
                C
                cpl_ir
                Hi, I am starting with MySensors and I read about the NodeManager. But I have a problem with starting with the nodemanager. I tried to make a node with a BMP280 sensor and a NRF24. Every time I tried I got the following error message
                when compiling (nodemanager actual version, arduino IDE1.8.5). Even no other sensor works.
                What is the reason, can anyone help me?
                Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
                "C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc-ar" rcs  "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\core\core.a" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\core\main.cpp.o"
                "C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc-ar" rcs  "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\core\core.a" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\core\new.cpp.o"
                Archiving built core (caching) in: C:\Users\RADFE~1\AppData\Local\Temp\arduino_cache_196944\core\core_arduino_avr_nano_cpu_atmega328_2c22347d3c992515700a8fa0ae8526cf.a
                "C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539/NodeManager.ino.elf" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\sketch\NodeManager.ino.cpp.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\libraries\SPI\SPI.cpp.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\libraries\Wire\Wire.cpp.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\libraries\Wire\utility\twi.c.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\libraries\Adafruit_BMP280_Library-master\Adafruit_BMP280.cpp.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539/core\core.a" "-LC:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539" -lm
                C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `receive(MyMessage const&)':
                C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:433: undefined reference to `NodeManager::receive(MyMessage const&)'
                C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `loop':
                C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:426: undefined reference to `NodeManager::loop()'
                C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `setup':
                C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:420: undefined reference to `NodeManager::setup()'
                C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `presentation()':
                C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:414: undefined reference to `NodeManager::presentation()'
                C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `before()':
                C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:408: undefined reference to `NodeManager::before()'
                C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `__static_initialization_and_destruction_0':
                C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:313: undefined reference to `NodeManager::NodeManager(int)'
                C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:351: undefined reference to `SensorBMP280::SensorBMP280(NodeManager&, int)'
                C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `_GLOBAL__sub_D__Z6hwInitv':
                C:\Users\Radfedfdf\Documents\Arduino\libraries\NodeManager_Library/NodeManagerLibrary.h:564: undefined reference to `vtable for Sensor'
                Mehrere Bibliotheken wurden für "Adafruit_BMP280.h" gefunden
                 Benutzt: C:\Users\Radfedfdf\Documents\Arduino\libraries\Adafruit_BMP280_Library-master
                 Nicht benutzt: C:\Users\Radfedfdf\Documents\Arduino\libraries\Adafruit_BMP280_Library
                Bibliothek NodeManager_Library im Ordner: C:\Users\Radfedfdf\Documents\Arduino\libraries\NodeManager_Library (legacy) wird verwendet
                Bibliothek MySensors in Version 2.2.0 im Ordner: C:\Users\Radfedfdf\Documents\Arduino\libraries\MySensors  wird verwendet
                Bibliothek SPI in Version 1.0 im Ordner: C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\SPI  wird verwendet
                Bibliothek Wire in Version 1.0 im Ordner: C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\Wire  wird verwendet
                Bibliothek Adafruit_Unified_Sensor in Version 1.0.2 im Ordner: C:\Users\Radfedfdf\Documents\Arduino\libraries\Adafruit_Unified_Sensor  wird verwendet
                Bibliothek Adafruit_BMP280_Library-master in Version 1.0.2 im Ordner: C:\Users\Radfedfdf\Documents\Arduino\libraries\Adafruit_BMP280_Library-master  wird verwendet
                Ungültige Bibliothek C:\Users\Radfedfdf\Documents\Arduino\libraries\NodeManager_mod in C:\Users\Radfedfdf\Documents\Arduino\libraries\NodeManager_mod gefunden
                exit status 1
                Fehler beim Kompilieren für das Board Arduino Nano.
                • C cpl_ir
                  exit status 1
                  U
                  U
                  user2684
                  @cpl_ir super weird, looks like the linker cannot find NodeManager's object file. Are you sure all NodeManager's files are within the same directory? NodeManager cannot be installed as a standard Arduino's library but all the files need to be in the same directory of your main sketch. Thanks!
                  • ArthurDentedA
                    ArthurDentedA
                    ArthurDented
                    Hello, I have been experimenting with the door sensor example and have configured to wake up every hour to send a battery voltage (V_VOLTAGE)
                    It will also wake whenever the interrupt state on the switch pin changes. I noticed that when the node wakes up with an interrupt it seems to send three events:
                    I_POST_SLEEP_NOTIFICATION
                    V_TRIPPED (this is the important one)
                    I_PRE_SLEEP_NOTIFICATION
                    this is all good, however for my application it would be useful if it were to also send a V_VOLTAGE battery measurement along with the V_TRIPPED event.
                    I'm not yet completely familiar with how the nodemanager sketch links together, but is it possible for the sensor readings for all sensors to be sent on an interrupt from any other sensor so I can make use of the radio as much as possible?
                    • ArthurDentedA ArthurDented
                      U
                      U
                      user2684
                      @arthurdented the I_POST_SLEEP_NOTIFICATION and I_PRE_SLEEP_NOTIFICATION are due to smart sleep which is on by default. Regarding the V_VOLTAGE I think what it comes closer to your need would be a SensorBattery configured with a very short reporting interval but regardless, when an interrupt occurs, no sensors other than the one associated with the interrupt would execute their main function. For your specific use case you can try changing or tweaking the condition at this line to make it working in the way you need: https://github.com/mysensors/NodeManager/blob/master/NodeManagerLibrary.ino#L4700
                      • Felix HaverkampF
                        Felix HaverkampF
                        Felix Haverkamp
                        wrote on last edited by Felix Haverkamp
                        #161
                        can anyone explain me the signal node? i get this values with setReportIntervalSeconds(1);
                        271860 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        272947 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        274033 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        275120 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        276206 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        277293 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        278378 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        279468 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        280554 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967259
                        281641 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967259
                        282728 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967259
                        283812 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967259
                        284898 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                        • Felix HaverkampF
                          Felix HaverkampF
                          Felix Haverkamp
                          is there a possibilty to only send values if the value has changed?
                          • Felix HaverkampF Felix Haverkamp
                            U
                            U
                            user2684
                            @felix-haverkamp the signal node is supposed to send the RSSI when the radio supports it. What you are looking at is a v1.7 bug, fixed in the dev branch of v1.8. If you want an easy fix without the need to upgrade, just remove the uint32_t cast at line 5017 of NodeManagerLibrary.ino (https://github.com/mysensors/NodeManager/blob/master/NodeManagerLibrary.ino#L5017).
                            To send the values only if the value has changed, you need first of all to turn FEATURE_CONDITIONAL_REPORT on, then you can use setValueDelta() and setForceUpdateMinutes() of the Child class to achieve what you are looking for
                            Felix HaverkampF 1 Reply Last reply
                            • U user2684
                              Felix HaverkampF
                              Felix HaverkampF
                              Felix Haverkamp
                              #164
                              @user2684
                              thx, that is what was what i am looking for.
                              • Felix HaverkampF
                                Felix HaverkampF
                                Felix Haverkamp
                                @user2684
                                FEATURE_CONDITIONAL_REPORT & setValueDelta()
                                would be nice for other users to document this function. With this i am able to only send values to the gateway when its changed. Using it for a Light Sensor and dont need the value every 10 seconds and not every 10 Minutes....
                                Just when it changes (1 second) and only when it changes.
                                  @user2684
                                  U
                                  U
                                  user2684
                                  @felix-haverkamp if you set setValueDelta() to e.g. 0.1 or 0.01, then the sensor will not report if the value has not changed, if I have understood correctly your point. setValueDelta() will set the minimum difference (+ or -) that the new value should have in order to be reported. Let me know I've misunderstood something. Thanks
                                  • Felix HaverkampF
                                    Felix HaverkampF
                                    Felix Haverkamp
                                    @user2684 i just mean, we have to put this is the documentation.
                                    currently i have a strange problem:
                                    the Motion Sensors doesnt reset. I checked with my old Motion sketch and everything is fine.
                                    Only sends the Value "1".
                                    11132 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                                    16513 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                                    26243 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                                      U
                                      U
                                      user2684
                                      @felix-haverkamp got it, thanks, I've opened this issue https://github.com/mysensors/NodeManager/issues/366.
                                      Regarding the sensor motion, weird, by default should attach to CHANGE interrupt so to intercept both. Any chance to share NodeManager's debug log as well? Thanks
                                      • U user2684
                                        Felix HaverkampF
                                        Felix HaverkampF
                                        Felix Haverkamp
                                        @user2684
                                        i think conditional report is the problem:
                                        #define FEATURE_CONDITIONAL_REPORT ON
                                        without it works fine.
                                        • U
                                          U
                                          user2684
                                          Every new version of NodeManager, I try to review and hopefully improve its architecture. This time looked like a simple and quick task but eventually ended up in a complete and deep review of the code. Many many many things have changed with the main objective to better integrate with the MySensors library and simplify the life of users willing to contribute or to add support for new sensors.
                                          The new file structure (with a dedicated file for each supported sensor) and the way the package is delivered (as an arduino library now) go into this direction. There are also included a good amount of new features but still in most of the cases, resulting a smaller code.
                                          All the details are available at https://github.com/mysensors/NodeManager/pull/391 which will be merged into the development branch shortly.
                                          Due to the many changes, if anybody would be willing to give it a try and report any bug, would be really great. Thanks!
