  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 116.9k Views 41 Watching
  • M mvader
    @user2684 in the sensebender sketch we turn on digital pin 7 to provide power to the LDR to read it.
    i have many sensors in my house and would rather not re-wire all of them.
    how can i add this cleanly in nodemgr to make it work as before?
    pinMode(7, OUTPUT); // “power pin” for Light Sensor
    digitalWrite(7, LOW); // switch power off
    U
    U
    user2684
    @mvader thanks for the feedback, I've added this issue on Github so to fix this in the next dev release https://github.com/mysensors/NodeManager/issues/344
    • U user2684
      mvader
      wrote on last edited by mvader
      #156
      @user2684 said in 💬 NodeManager:
      Thanks!! here is the setup and loop part from the sketch
      setup
      loop
        digitalWrite(7, HIGH); // switch power on to LDR
        sendLight(forceTransmit);
        digitalWrite(7, LOW); // switch power off to LDR
      and the function
       * Sends Ambient Light Sensor information
       * Parameters
      void sendLight(bool force) // Get light level
        if (force) lastLightLevel = -1;
        int rlightLevel =  analogRead(LIGHT_PIN);
        int lightLevel =  (analogRead(LIGHT_PIN) / 10.23) ;
         gw.send(msgLight.set(lightLevel));
          lastLightLevel = lightLevel;
      • C
        C
        cpl_ir
        Hi, I am starting with MySensors and I read about the NodeManager. But I have a problem with starting with the nodemanager. I tried to make a node with a BMP280 sensor and a NRF24. Every time I tried I got the following error message
        when compiling (nodemanager actual version, arduino IDE1.8.5). Even no other sensor works.
        What is the reason, can anyone help me?
        Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
        "C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc-ar" rcs  "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\core\core.a" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\core\main.cpp.o"
        "C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc-ar" rcs  "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\core\core.a" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\core\new.cpp.o"
        Archiving built core (caching) in: C:\Users\RADFE~1\AppData\Local\Temp\arduino_cache_196944\core\core_arduino_avr_nano_cpu_atmega328_2c22347d3c992515700a8fa0ae8526cf.a
        "C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539/NodeManager.ino.elf" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\sketch\NodeManager.ino.cpp.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\libraries\SPI\SPI.cpp.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\libraries\Wire\Wire.cpp.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\libraries\Wire\utility\twi.c.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539\libraries\Adafruit_BMP280_Library-master\Adafruit_BMP280.cpp.o" "C:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539/core\core.a" "-LC:\Users\RADFE~1\AppData\Local\Temp\arduino_build_123539" -lm
        C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `receive(MyMessage const&)':
        C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:433: undefined reference to `NodeManager::receive(MyMessage const&)'
        C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `loop':
        C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:426: undefined reference to `NodeManager::loop()'
        C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `setup':
        C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:420: undefined reference to `NodeManager::setup()'
        C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `presentation()':
        C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:414: undefined reference to `NodeManager::presentation()'
        C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `before()':
        C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:408: undefined reference to `NodeManager::before()'
        C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `__static_initialization_and_destruction_0':
        C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:313: undefined reference to `NodeManager::NodeManager(int)'
        C:\Users\RADFE~1\AppData\Local\Temp\arduino_modified_sketch_106015/NodeManager.ino:351: undefined reference to `SensorBMP280::SensorBMP280(NodeManager&, int)'
        C:\Users\RADFE~1\AppData\Local\Temp\cc796L4N.ltrans1.ltrans.o: In function `_GLOBAL__sub_D__Z6hwInitv':
        C:\Users\Radfedfdf\Documents\Arduino\libraries\NodeManager_Library/NodeManagerLibrary.h:564: undefined reference to `vtable for Sensor'
        Mehrere Bibliotheken wurden für "Adafruit_BMP280.h" gefunden
         Benutzt: C:\Users\Radfedfdf\Documents\Arduino\libraries\Adafruit_BMP280_Library-master
         Nicht benutzt: C:\Users\Radfedfdf\Documents\Arduino\libraries\Adafruit_BMP280_Library
        Bibliothek NodeManager_Library im Ordner: C:\Users\Radfedfdf\Documents\Arduino\libraries\NodeManager_Library (legacy) wird verwendet
        Bibliothek MySensors in Version 2.2.0 im Ordner: C:\Users\Radfedfdf\Documents\Arduino\libraries\MySensors  wird verwendet
        Bibliothek SPI in Version 1.0 im Ordner: C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\SPI  wird verwendet
        Bibliothek Wire in Version 1.0 im Ordner: C:\Users\Radfedfdf\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\Wire  wird verwendet
        Bibliothek Adafruit_Unified_Sensor in Version 1.0.2 im Ordner: C:\Users\Radfedfdf\Documents\Arduino\libraries\Adafruit_Unified_Sensor  wird verwendet
        Bibliothek Adafruit_BMP280_Library-master in Version 1.0.2 im Ordner: C:\Users\Radfedfdf\Documents\Arduino\libraries\Adafruit_BMP280_Library-master  wird verwendet
        Ungültige Bibliothek C:\Users\Radfedfdf\Documents\Arduino\libraries\NodeManager_mod in C:\Users\Radfedfdf\Documents\Arduino\libraries\NodeManager_mod gefunden
        exit status 1
        Fehler beim Kompilieren für das Board Arduino Nano.
        U 1 Reply Last reply
        • C cpl_ir
          exit status 1
          U
          U
          user2684
          @cpl_ir super weird, looks like the linker cannot find NodeManager's object file. Are you sure all NodeManager's files are within the same directory? NodeManager cannot be installed as a standard Arduino's library but all the files need to be in the same directory of your main sketch. Thanks!
          • ArthurDentedA
            ArthurDentedA
            ArthurDented
            Hello, I have been experimenting with the door sensor example and have configured to wake up every hour to send a battery voltage (V_VOLTAGE)
            It will also wake whenever the interrupt state on the switch pin changes. I noticed that when the node wakes up with an interrupt it seems to send three events:
            I_POST_SLEEP_NOTIFICATION
            V_TRIPPED (this is the important one)
            I_PRE_SLEEP_NOTIFICATION
            this is all good, however for my application it would be useful if it were to also send a V_VOLTAGE battery measurement along with the V_TRIPPED event.
            I'm not yet completely familiar with how the nodemanager sketch links together, but is it possible for the sensor readings for all sensors to be sent on an interrupt from any other sensor so I can make use of the radio as much as possible?
            • ArthurDentedA ArthurDented
              U
              U
              user2684
              @arthurdented the I_POST_SLEEP_NOTIFICATION and I_PRE_SLEEP_NOTIFICATION are due to smart sleep which is on by default. Regarding the V_VOLTAGE I think what it comes closer to your need would be a SensorBattery configured with a very short reporting interval but regardless, when an interrupt occurs, no sensors other than the one associated with the interrupt would execute their main function. For your specific use case you can try changing or tweaking the condition at this line to make it working in the way you need: https://github.com/mysensors/NodeManager/blob/master/NodeManagerLibrary.ino#L4700
              • Felix HaverkampF
                Felix HaverkampF
                Felix Haverkamp
                wrote on last edited by Felix Haverkamp
                #161
                can anyone explain me the signal node? i get this values with setReportIntervalSeconds(1);
                271860 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                272947 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                274033 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                275120 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                276206 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                277293 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                278378 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                279468 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                280554 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967259
                281641 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967259
                282728 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967259
                283812 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967259
                284898 TSF:MSG:SEND,1-1-0-0,s=202,c=1,t=37,pt=5,l=4,sg=0,ft=0,st=OK:4294967260
                • Felix HaverkampF
                  Felix HaverkampF
                  Felix Haverkamp
                  is there a possibilty to only send values if the value has changed?
                  • Felix HaverkampF Felix Haverkamp
                    U
                    U
                    user2684
                    @felix-haverkamp the signal node is supposed to send the RSSI when the radio supports it. What you are looking at is a v1.7 bug, fixed in the dev branch of v1.8. If you want an easy fix without the need to upgrade, just remove the uint32_t cast at line 5017 of NodeManagerLibrary.ino (https://github.com/mysensors/NodeManager/blob/master/NodeManagerLibrary.ino#L5017).
                    To send the values only if the value has changed, you need first of all to turn FEATURE_CONDITIONAL_REPORT on, then you can use setValueDelta() and setForceUpdateMinutes() of the Child class to achieve what you are looking for
                    Felix HaverkampF 1 Reply Last reply
                    • U user2684
                      Felix HaverkampF
                      Felix HaverkampF
                      Felix Haverkamp
                      #164
                      @user2684
                      thx, that is what was what i am looking for.
                      • Felix HaverkampF
                        Felix HaverkampF
                        Felix Haverkamp
                        @user2684
                        FEATURE_CONDITIONAL_REPORT & setValueDelta()
                        would be nice for other users to document this function. With this i am able to only send values to the gateway when its changed. Using it for a Light Sensor and dont need the value every 10 seconds and not every 10 Minutes....
                        Just when it changes (1 second) and only when it changes.
                          @user2684
                          U
                          U
                          user2684
                          @felix-haverkamp if you set setValueDelta() to e.g. 0.1 or 0.01, then the sensor will not report if the value has not changed, if I have understood correctly your point. setValueDelta() will set the minimum difference (+ or -) that the new value should have in order to be reported. Let me know I've misunderstood something. Thanks
                          • Felix HaverkampF
                            Felix HaverkampF
                            Felix Haverkamp
                            @user2684 i just mean, we have to put this is the documentation.
                            currently i have a strange problem:
                            the Motion Sensors doesnt reset. I checked with my old Motion sketch and everything is fine.
                            Only sends the Value "1".
                            11132 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                            16513 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                            26243 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                              U
                              U
                              user2684
                              @felix-haverkamp got it, thanks, I've opened this issue https://github.com/mysensors/NodeManager/issues/366.
                              Regarding the sensor motion, weird, by default should attach to CHANGE interrupt so to intercept both. Any chance to share NodeManager's debug log as well? Thanks
                              • U user2684
                                Felix HaverkampF
                                Felix HaverkampF
                                Felix Haverkamp
                                @user2684
                                i think conditional report is the problem:
                                #define FEATURE_CONDITIONAL_REPORT ON
                                without it works fine.
                                • U
                                  U
                                  user2684
                                  Every new version of NodeManager, I try to review and hopefully improve its architecture. This time looked like a simple and quick task but eventually ended up in a complete and deep review of the code. Many many many things have changed with the main objective to better integrate with the MySensors library and simplify the life of users willing to contribute or to add support for new sensors.
                                  The new file structure (with a dedicated file for each supported sensor) and the way the package is delivered (as an arduino library now) go into this direction. There are also included a good amount of new features but still in most of the cases, resulting a smaller code.
                                  All the details are available at https://github.com/mysensors/NodeManager/pull/391 which will be merged into the development branch shortly.
                                  Due to the many changes, if anybody would be willing to give it a try and report any bug, would be really great. Thanks!
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    Just wanted to say that NodeManager is awesome. I can't believe I only now really had a better look at what it is. I always thought it was some kind of software you had to install, and that it was used by professionals to manage complicated sensor nets.
                                    For the last few months I've been thinking "wouldn't it be useful if there was some kind of beginner friendly web interface where you could select which devices you want, and then it creates the code for you". This is so close to that. Thank you for this incredible work!
                                    • alowhumA alowhum
                                      U
                                      U
                                      user2684
                                      @alowhum many thanks for the feedback, really appreciated!
                                      • J
                                        J
                                        Jiri Hron
                                        Is it possible to "force" send SensorDoor value regularly?
                                        I am using magnetic sensor together with interrupt feature but when sensor status is change too fast before main loop is finished, sensor value remains in wrong state until magnetic sensor value is physically changed again.
                                        So I would like to set that SensorDoor value will be set regularly like e.g. temperature sensors values. I tried to add:
                                        door.setReportIntervalMinutes(5);
                                        But it does not work in this case. Value is not reported based on this interval. Only way how to get SensorDoor value back to right state is physically change its value (open/close magnetic sensors).
                                        Btw Nodemanager is really awsome. Great work!
                                        • faustiF
                                          faustiF
                                          fausti
                                          wrote on last edited by fausti
                                          #174
                                          Hi, I need some advice for my following problem..:
                                          Situation: Arduino ist connected to an raspberry gateway with openhab -> works just fine.
                                          To the arduino I have connected a PIR on 3 and a photoresistor (LDR) with an 10k resistor on A0 -> works just fine.
                                          On first boot (after connecting etc.) the arduino sends motion status + LDR value. But after that first msg. only the motion (tripped) is send.
                                          What I want: I want that the arduino sleeps until there is an interrupt comming from the PIR and then sends the motion status+light value (LDR) and then sleeps again 4ever until the next interrupt.
                                          Problem: As I said, it only sends the light value only once.. and then never again. On the arduino debug I can see, that only motion is send:
                                          NodeManager v1.7
                                          LIB V=2.3.0 R=N E=X T=N A=A S=S B=-
                                          LDR I=1 P=16 T=23
                                          MOTION I=2 P=1 T=16
                                          RADIO...OK
                                          PRES I=1 T=16 D=LDR
                                          PRES I=2 T=1 D=MOTION
                                          READY
                                          MY I=5 M=255
                                          INT P=3, V=0
                                          INT P=3 M=1
                                          INT P=2 M=255
                                          MOTION I=2 P=3 V=0
                                          SEND D=0 I=2 C=0 T=16 S= I=0 F=0.00
                                          LDR I=1 V=352 %=34 <-- first an last time LDR sends it's value
                                          SEND D=0 I=1 C=0 T=23 S= I=0 F=0.00
                                          INT P=3, V=1
                                          MOTION I=2 P=3 V=1
                                          INT P=3, V=0
                                          MOTION I=2 P=3 V=0
                                          Hope you can help me :grimacing: many thanks in advance :-)
                                          // General settings
                                          #define SKETCH_NAME "Test2"
                                          #define SKETCH_VERSION "1.0"
                                          // NRF24 radio settings
                                          #define MY_SIGNING_SIMPLE_PASSWD "xxx"
                                          #define MY_ENCRYPTION_SIMPLE_PASSWD "xxx"
                                          #define MY_RF24_CHANNEL (124)
                                          // Advanced settings
                                          #define MY_BAUD_RATE 9600
                                          //#define MY_SMART_SLEEP_WAIT_DURATION_MS 500
                                           * NodeManager modules for supported sensors
                                          #define USE_ANALOG_INPUT
                                          #define USE_INTERRUPT
                                           * NodeManager built-in features
                                          // Enable/disable NodeManager's features
                                          #define FEATURE_DEBUG ON
                                          #define FEATURE_POWER_MANAGER OFF
                                          #define FEATURE_INTERRUPTS ON
                                          #define FEATURE_CONDITIONAL_REPORT OFF
                                          #define FEATURE_EEPROM OFF
                                          #define FEATURE_SLEEP ON
                                          #define FEATURE_RECEIVE OFF
                                          #define FEATURE_TIME OFF
                                          #define FEATURE_RTC OFF
                                          #define FEATURE_SD OFF
                                          #define FEATURE_HOOKING OFF
                                           * Load NodeManager Library
                                          #include "NodeManagerLibrary.h"
                                          NodeManager node;
                                           * Add your sensors below
                                          // Attached sensors
                                          SensorLDR ldr(node,A0);
                                          //SensorInterrupt interrupt(node,3);
                                          SensorMotion motion(node,3);
                                           * Main Sketch
                                          // before
                                          void before() {
                                            Serial.begin(MY_BAUD_RATE);
                                            * Configure your sensors below
                                            node.setReportIntervalSeconds(10);
                                            node.setSleepSeconds(60);
                                            * Configure your sensors above
                                            node.before();
                                          // presentation
                                            node.presentation();
                                          // setup
                                            node.setup();
                                          // loop
                                            node.loop();
                                          #if FEATURE_RECEIVE == ON
                                          // receive
                                            node.receive(message);
                                          #if FEATURE_TIME == ON
                                          // receiveTime
                                            node.receiveTime(ts);
                                          faustiF 1 Reply Last reply
