  3. SMD Reflow Oven / PID
23 Posts 6 Posters 9.3k Views 2 Watching
    @toyman said in nRF5 action!:
    I didn't have good enough technique dispensing manually directly from a solder paste syringe,
    what did you have issues with?
    It was very hard to extrude it, so I always seemed to either underextrude or overstrude. I found it very hard to get the right amount exactly where it should go by just manually pressing the plunger on the solder paste syringe that the material came in.
    Toyman
    @neverdie
    two hypothesis:
    a) old paste
    b) wrong needle gauge
    I use Mechanic XG paste, works perfect
    • T Toyman
      @neverdie
      two hypothesis:
      a) old paste
      @toyman said in SMD Reflow Oven / PID:
      Mechanic XG paste
      This? https://www.ebay.com/itm/New-Mechanic-XG-Z40-10cc-Syringe-Solder-Paste-Flux-Sn63-Pb37-25-45um-10cc-US/202242405146?hash=item2f1696331a:g:WsMAAOSwu4BV1Ds8:sc:USPSFirstClass!78726!US!-1
        Mechanic XG paste
        Toyman
        wrote on last edited by Toyman
        @neverdie yes, although I use the one in small cans and reload small amount into 1 ml syringe (with proper gauge needle!)
        https://www.aliexpress.com/item/Original-Low-temperature-soldering-Paste-Flux-MECHANIC-B80-60g-Solder-tin-paste-Sn42-Bi58-For-Hakko/32878574326.html?spm=2114.search0204.3.1.51224cc6X3Qstz&s=p&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_10543_5722615_10696_10084_10083_10618_10307_10301_5722715_10059_100031_10103_10624_10623_10622_5722515_10621_10620,searchweb201603_55,ppcSwitch_5_ppcChannel&priceBeautifyAB=0
        This bottle contains all the needles conviniently cut
        https://www.aliexpress.com/item/50ml-Empty-E-liquid-Plastic-Rosin-Flux-Alcohol-Bottle-For-Dispenser-Rosin-Solder-Flux-Paste-11/32810052820.html?spm=2114.search0204.3.14.37687b2184NHbx&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_10543_5722615_10696_10084_10083_10618_10307_10301_5722715_10059_100031_10103_10624_10623_10622_5722515_10621_10620-10620,searchweb201603_55,ppcSwitch_5_ppcChannel&algo_expid=47557fe8-25e4-4763-96f0-5831fc4e628f-1&algo_pvid=47557fe8-25e4-4763-96f0-5831fc4e628f&priceBeautifyAB=0
        • T Toyman
          @toyman What about the syringes? Do you have a link for those as well?
          I suppose a syringe gun might be handy, if no stepper motor operated one is available:
          https://www.aliexpress.com/item/New-Arrival-Manual-Syringe-Gun-Dispenser-10cc-Glue-Dispensing-Gun/32555533165.html?spm=2114.search0604.8.44.58b37fcbKvXPej&priceBeautifyAB=0
            Toyman
            @neverdie c'mon, you don't need any special syringe. Ordinary BD will do
            Regarding the motor operated one, I actually printed out a full set of 3d parts for the motor oerated syringe but never assembled as there is no need.
            If I ever decide to automate the process, I'll make an air driven station with 2 valves. Mechanic solder syringes are supposed to be used with this type of dispensers.
            • Nca78N
              So I gave it a try today with a solder paste syringe from AliExpress (not perempted like the paste I got from my local shop before). I used a normal syringe pusher (after removing the rubber end) and it went relatively smoothly with a green colored needle (don't know the diameter). I guess I'll try the small syringe technique as it must be easier to have regular flow, but it was good enough.
              Without much training I managed to solder my ESP32 module (and 2 buttons) to the adapter board. I used my small 10*10cm hotplate, remotely following the reflow profile for this solder type and all connections are good.
              T NeverDieN 2 Replies Last reply
              • Nca78N Nca78
                Toyman
                @nca78 said in SMD Reflow Oven / PID:
                interesting. Do you use an ordinary kitchen hotplate?
                Nca78N 1 Reply Last reply
                • T Toyman
                  No, it's made for SMD, it's the same than this one but another brand (and color, much better looking in white :D ). I was looking on AliExpress but saw a local shop was selling some. Cheaper than AliExpress and only 2$ for 48h delivery to my doorstep :)
                  It's much better than a kitchen hotplate as temperature is relatively accurate and doesn't seem to vary too much between centre and periphery thanks to the thickness of the metal plate. The only problem is at the end, it's extremely slow to cool down and it's easy to burn yourself on the unprotected plate. Body also gets pretty hot after some time so I need to put it on a silicon soldering mat to protect my desk.
                  Result of the first manual test is good enough, I'll test next week with stencil-applied solder paste if DHL is not messing too much with the customs.
                  https://www.aliexpress.com/item/JF-956S-Heating-Platform-Preheating-Station-Screen-Repair-Special-Heating-Units-220V-Mobile-maintenance-tools/32815514695.html
                  • Nca78N Nca78
                    To approximate the reflow profile, did you manually adjust the temperatures by hand while looking at a clock or something?
                      @neverdie said in SMD Reflow Oven / PID:
                      Yes. That's why I say "remotely" :)
                      Not very convenient but still much faster than soldering all the pads by hand.
