  3. 💬 Insulated Whole House Fan
mysensorswhole house fan
72 Posts 11 Posters 23.4k Views 11 Watching
  • rechin304R
    rechin304R
    rechin304
    wrote on last edited by rechin304
    #24
    I can confirm that DHT library that is in example do not work with DHT11 and DHT22 in my case, using other (older) library i can see data.
    petewillP 1 Reply Last reply
    • rechin304R rechin304
      petewillP
      petewillP
      petewill
      @rechin304 Sorry, just to make sure I understand, are you saying it works with a DHT22 or not? I may still be on an old library too.
      rechin304R 1 Reply Last reply
      • petewillP petewill
        rechin304R
        rechin304R
        rechin304
        #26
        @petewill
        Works with DHT22 and other library (old one). I could not make it work withe one from example.
        I'm almost ready with build, waiting for final pieces. hope to receive them this week.
        one more ting i noticed is that clock is behind with 2minutes, so i need to check the code again.
        • rechin304R
          rechin304R
          rechin304
          I have an working prototype, see video https://goo.gl/photos/VSQeaevHh7UbbStr9
          Many thanks to @petewill for his work and inspiration.
          I will post final pictures when ready.
          • rechin304R
            rechin304R
            rechin304
            Added new lead screw pitch of 2Mm that decrease open/close time from 3 minutes to 40 sec. see pics https://goo.gl/photos/mQvF1S9FrdNYPpdH9
            buyed from here http://www.ebay.com/itm/322139119923?_trksid=p2057872.m2749.l2649&var=511054006707&ssPageName=STRK%3AMEBIDX%3AIT
            for who is interested.
              petewillP
              petewillP
              petewill
              @rechin304 Awesome! Glad you got it working!!
              L 1 Reply Last reply
                L
                L
                lis610
                @petewill Hi Pete
                Just Start building the system and got an error at sketch verify.
                "exit status 1
                'class Adafruit_ST7735' has no member named 'setFont'"
                • L lis610
                  @petewill Hi Pete
                  "exit status 1
                  petewillP
                  petewillP
                  petewill
                  @lis610 Sorry for the delay. Work has been very busy. I have attached the libraries I'm using. I was able to get it to compile when I just tested. https://drive.google.com/file/d/1wauxHRf5pyqLnBGsfCP8UPJQR1wNdkoF/view?usp=sharing
                  Let me know if you have issues with this.
                  • L
                    L
                    lis610
                    THANK YOU so much for sharing. Most of the errors gone, but one left (using Arduino v.1.8.5; MySensors v 2.3.0):
                    [C:\Users\BEAST\Documents\Arduino\Whole-House-Fan\code\New folder\WholeHouseFan2.0\WholeHouseFan2.0.ino: In function 'void presentation()':
                    WholeHouseFan2.0:197: error: 'TEMP_CHILD_NAME' was not declared in this scope present(TEMP_ID, S_TEMP, TEMP_CHILD_NAME);
                    exit status 1]
                    • L lis610
                      exit status 1]
                      petewillP
                      petewillP
                      petewill
                      @lis610 Sorry about that. I just fixed the code on the build page. Hopefully that will get you up and running :)
                      • L
                        L
                        lis610
                        Thank you. Did you upload the file for download?
                        • L lis610
                          petewillP
                          petewillP
                          petewill
                          @lis610 yes, I uploaded it to the page in the link at the top of this page.
                          • L
                            L
                            lis610
                            Cannot locate file "WholeHouseFan2.0.ino"
                            • L lis610
                              petewillP
                              petewillP
                              petewill
                              wrote on last edited by petewill
                              #37
                              @lis610 Strange. It disappeared. I added it again and just downloaded it so you should be good. Sorry for all the issues!
                              • L
                                L
                                lis610
                                Thank you. The box is ready. Next step connect all hardware. So far no luck with the display (KMR-1.8 SPI). What kind of display model you used in this project.
                                • L lis610
                                  petewillP
                                  petewillP
                                  petewill
                                  @lis610 This is the display I used.
                                  http://www.ebay.com/itm/331443126874?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                  • L
                                    L
                                    lis610
                                    Got the same display. It is working with Adafruit graphicstest example. I did not connect any components just display. If I ran the FAN sketch should be something showing on the display?
                                    Or need to connect everything?
                                    • L lis610
                                      petewillP
                                      petewillP
                                      petewill
                                      @lis610 is #define TFT_DISPLAY_ON uncommented? Also, you will at least need the radio attached so the MySensors code can fully load (you can also setup defines to proceed without connecting to gateway but I don't remember them off the top of my head). I don't remember if there are any other dependencies since it as been so long since I built this.
                                      • L
                                        L
                                        lis610
                                        Please help
                                        Display is working with Adafruit graphicstest example pins:
                                        #define TFT_CS 10 #define TFT_RST 9 #define TFT_DC 8# define TFT_SCLK 13 #define TFT_MOSI 11
                                        I did try the same pins in FAN sketch -nothing on display
                                        Tryed pin# from FAN sketch on Adafruit graphicstest- nothing on display.
                                        Nothing come up
                                        I did connect to the radio. Got something from MY_DUBUG not sure is it good or bad:
                                        624893 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                                        626903 !TSM:FPAR:NO REPLY
                                        626905 TSM:FPAR
                                        626941 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        628951 !TSM:FPAR:NO REPLY
                                        628953 TSM:FPAR
                                        628989 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        630999 !TSM:FPAR:NO REPLY
                                        631001 TSM:FPAR
                                        631037 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        633047 !TSM:FPAR:FAIL
                                        633049 TSM:FAIL:CNT=7
                                        633051 TSM:FAIL:DIS
                                        633053 TSF:TDI:TSL
                                        693057 TSM:FAIL:RE-INIT
                                        693059 TSM:INIT
                                        693067 TSM:INIT:TSP OK
                                        693069 TSF:SID:OK,ID=5
                                        693071 TSM:FPAR
                                        693108 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        693432 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                        693438 TSF:MSG:FPAR OK,ID=0,D=1
                                        695117 TSM:FPAR:OK
                                        695119 TSM:ID
                                        695119 TSM:ID:OK
                                        695121 TSM:UPL
                                        695160 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        697171 TSM:UPL
                                        697178 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
                                        699187 TSM:UPL
                                        699224 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        701233 TSM:UPL
                                        • L lis610
                                          Please help
                                          Nothing come up
                                          626905 TSM:FPAR
                                          628953 TSM:FPAR
                                          631001 TSM:FPAR
                                          633051 TSM:FAIL:DIS
                                          633053 TSF:TDI:TSL
                                          693059 TSM:INIT
                                          693071 TSM:FPAR
                                          695117 TSM:FPAR:OK
                                          695119 TSM:ID
                                          695119 TSM:ID:OK
                                          695121 TSM:UPL
                                          697171 TSM:UPL
                                          699187 TSM:UPL
                                          701233 TSM:UPL
                                          petewillP
                                          petewillP
                                          petewill
                                          @lis610 It looks like it's having issues communicating with your gateway. Here is a link to the log parser. You can use this in the future to check out your logs.
                                          https://www.mysensors.org/build/parser?log=624893 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D1%2Cst%3DOK%3A 626903 !TSM%3AFPAR%3ANO REPLY 626905 TSM%3AFPAR 626941 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 628951 !TSM%3AFPAR%3ANO REPLY 628953 TSM%3AFPAR 628989 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 630999 !TSM%3AFPAR%3ANO REPLY 631001 TSM%3AFPAR 631037 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 633047 !TSM%3AFPAR%3AFAIL 633049 TSM%3AFAIL%3ACNT%3D7 633051 TSM%3AFAIL%3ADIS 633053 TSF%3ATDI%3ATSL 693057 TSM%3AFAIL%3ARE-INIT 693059 TSM%3AINIT 693067 TSM%3AINIT%3ATSP OK 693069 TSF%3ASID%3AOK%2CID%3D5 693071 TSM%3AFPAR 693108 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 693432 TSF%3AMSG%3AREAD%2C0-0-5%2Cs%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A0 693438 TSF%3AMSG%3AFPAR OK%2CID%3D0%2CD%3D1 695117 TSM%3AFPAR%3AOK 695119 TSM%3AID 695119 TSM%3AID%3AOK 695121 TSM%3AUPL 695160 !TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DNACK%3A1 697171 TSM%3AUPL 697178 TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D1%2Cst%3DOK%3A1 699187 TSM%3AUPL 699224 !TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DNACK%3A1 701233 TSM%3AUPL
                                          Also, did you comment/uncomment the proper defines as noted above and in the code comments?
                                          Try adding this line before #include <MySensors.h>
                                          #define MY_TRANSPORT_WAIT_READY_MS 4000 //This will allow the sensor to function if it can't find the gateway when it first starts up
