  3. 💬 Insulated Whole House Fan
mysensorswhole house fan
72 Posts 11 Posters 23.4k Views 11 Watching
  • rechin304R rechin304
    This is the output that i get. Maybe you can understand why. And this is a clean example. Anyone have make temp DHT11 to work in version2 ?
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=27)
    TSM:FPAR
    TSP:MSG:SEND 27-27-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSP:MSG:READ 25-25-27 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=25, dist=1)
    TSP:MSG:PAR OK (ID=25, dist=2)
    TSP:MSG:READ 0-0-27 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=27)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-27 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    TSP:MSG:SEND 27-27-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
    TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
    TSP:MSG:READ 0-0-27 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    TSP:MSG:READ 0-0-27 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:TemperatureAndHumidity
    TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
    TSP:MSG:SEND 27-27-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 27-27-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
    Request registration...
    TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-27 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=27, parent=0, distance=1, registration=1```
    If i get the sensor out i get this
    Failed reading temperature from DHT!
    Failed reading humidity from DHT
    petewillP
    petewillP
    petewill
    @rechin304 Something is most likely wrong with your wiring or the sensor. I am using a DHT22 without any issues in my rain gauge which is on 2.0 (I'm using the most recent beta release). Try connecting a 4.7k resistor between the data pin and power on the DHT like this.
    0_1478303148400_upload-1d245d6b-aad9-4841-8307-485c9caf5056
    • enloE
      enloE
      enlo
      @petewill wow, your screen case looks amazing! Is that acryl glass? Did you build that yourself too?
      petewillP 1 Reply Last reply
      • enloE enlo
        petewillP
        petewillP
        petewill
        @enlo Thanks. Yeah, it's acrylic glass (Plexiglas). It was a pain to use though as I couldn't clean off the paint very well. My next project I'm working on I'm going to try to use regular glass.
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR:OK
          TSM:ID
          TSM:UPL
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          Node registration=1
          flyswiftlyF
          flyswiftlyF
          flyswiftly
          @rechin304 said:
          dht.setup(DHT_DATA_PIN);
          For what it's worth, I just went through a very long debug session trying to get a simple dht11 based sensor built and working. For reasons I don't even pretend to understand, the one thing I changed that allows it to work is changing the 'sleep' command in this section of the setup function to a 'wait' command.
          rechin304R 1 Reply Last reply
          • flyswiftlyF flyswiftly
            rechin304R
            rechin304R
            rechin304
            @flyswiftly thanks for trying,
            in my case still i do not see any data. What library do you use ? The one from MySensorsArduinoExamples-master.zip ?
            flyswiftlyF 1 Reply Last reply
              flyswiftlyF
              flyswiftlyF
              flyswiftly
              @rechin304
              Actually, no. It turns out when I looked through my IDE that I am using the prior version of the DHT library. That did also force me to comment out the read sensor line just to make it compile. Maybe the combination of the two changes is what does the trick. I hadn't made those changes together, so I missed the possible significance of this change:
              //  dht.readSensor(true);
              Running a diff on both the library you point out and the one I'm using shows that adding that bool to the readSendor function is the only code difference.
                @rechin304
                rechin304R
                rechin304R
                rechin304
                @flyswiftly
                I also did that try an older version library for DHT and receive data. So conclusion is that on current (latest) DHT library for DHT11 is not working. Now I'm on a business trip to China for a week and With this chance i will buy there DHT 22 to be sure. I will be back in a week with conclusion.
                • rechin304R
                  rechin304R
                  rechin304
                  wrote on last edited by rechin304
                  #24
                  I can confirm that DHT library that is in example do not work with DHT11 and DHT22 in my case, using other (older) library i can see data.
                    petewillP
                    petewillP
                    petewill
                    @rechin304 Sorry, just to make sure I understand, are you saying it works with a DHT22 or not? I may still be on an old library too.
                    • petewillP petewill
                      rechin304R
                      rechin304R
                      rechin304
                      #26
                      @petewill
                      Works with DHT22 and other library (old one). I could not make it work withe one from example.
                      I'm almost ready with build, waiting for final pieces. hope to receive them this week.
                      one more ting i noticed is that clock is behind with 2minutes, so i need to check the code again.
                      • rechin304R
                        rechin304R
                        rechin304
                        I have an working prototype, see video https://goo.gl/photos/VSQeaevHh7UbbStr9
                        Many thanks to @petewill for his work and inspiration.
                        I will post final pictures when ready.
                        • rechin304R
                          rechin304R
                          rechin304
                          Added new lead screw pitch of 2Mm that decrease open/close time from 3 minutes to 40 sec. see pics https://goo.gl/photos/mQvF1S9FrdNYPpdH9
                          buyed from here http://www.ebay.com/itm/322139119923?_trksid=p2057872.m2749.l2649&var=511054006707&ssPageName=STRK%3AMEBIDX%3AIT
                          for who is interested.
                            petewillP
                            petewillP
                            petewill
                            @rechin304 Awesome! Glad you got it working!!
                            L 1 Reply Last reply
                              L
                              L
                              lis610
                              @petewill Hi Pete
                              Just Start building the system and got an error at sketch verify.
                              "exit status 1
                              'class Adafruit_ST7735' has no member named 'setFont'"
                              • L lis610
                                @petewill Hi Pete
                                "exit status 1
                                petewillP
                                petewillP
                                petewill
                                @lis610 Sorry for the delay. Work has been very busy. I have attached the libraries I'm using. I was able to get it to compile when I just tested. https://drive.google.com/file/d/1wauxHRf5pyqLnBGsfCP8UPJQR1wNdkoF/view?usp=sharing
                                Let me know if you have issues with this.
                                • L
                                  L
                                  lis610
                                  THANK YOU so much for sharing. Most of the errors gone, but one left (using Arduino v.1.8.5; MySensors v 2.3.0):
                                  [C:\Users\BEAST\Documents\Arduino\Whole-House-Fan\code\New folder\WholeHouseFan2.0\WholeHouseFan2.0.ino: In function 'void presentation()':
                                  WholeHouseFan2.0:197: error: 'TEMP_CHILD_NAME' was not declared in this scope present(TEMP_ID, S_TEMP, TEMP_CHILD_NAME);
                                  exit status 1]
                                  • L lis610
                                    exit status 1]
                                    petewillP
                                    petewillP
                                    petewill
                                    @lis610 Sorry about that. I just fixed the code on the build page. Hopefully that will get you up and running :)
                                    • L
                                      L
                                      lis610
                                      Thank you. Did you upload the file for download?
                                      • L lis610
                                        petewillP
                                        petewillP
                                        petewill
                                        @lis610 yes, I uploaded it to the page in the link at the top of this page.
                                        • L
                                          L
                                          lis610
                                          Cannot locate file "WholeHouseFan2.0.ino"
