  3. RFM69 new driver delay
67 Posts 10 Posters 17.7k Views 8 Watching
  • M mickecarlsson
    You only need repeater fi you have a node far away that can’t reach the gateway, then you add repeater on a node nearer the gateway.
    See here: MySensors Network
    And if the node has repeater defined it must allways have power and no Sleep.
    Sorry, I can’t test the sketch.
    pepsonP
    pepsonP
    pepson
    @mickecarlsson I done next test.
    Updated my Gateway on RPI3 to 2.3.0
    Then also update my nodes to 2.3.0
    One node which i use is to control Switch Relay. It works ok also with Repeater function and also without Repeater function.
    Second node is to control cover by relay. It no working correct also with Reapeater and also without Repeater function. Status is not update in the same time. Sometimes no respod reaction on click button.
    Below i see SWITCH releay SKETCH and also to Cover.
    Please help me.
    Also i need help to convert this sketch for Switch 1xRelay to Switch 2x Releay. ANybody can help me. ?
       Relay with button sketch
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define RFM69_868MH
    #define MY_RFM69_NEW_DRIVER
    // uncomment if we want to manually assign an ID
    #define MY_NODE_ID 2                       // Node id defaults to AUTO (tries to fetch id from controller)
    #define RELAY_ON 0
    #define RELAY_OFF 1
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool uplinkAvailable = true;
    bool state = false;
    bool requestState;
    bool firstStart = true;
    unsigned long oldTime = 0;
    unsigned long newTime = 0;
    void setup(){
      debouncer.interval(5);
      send(msg.set(RELAY_OFF), false);           // notify controller to show off state
    void presentation()  {
      sendSketchInfo("1xRelay & Button-Sypialnia", "2.2.0");
      present(CHILD_ID, S_BINARY);
    void loop(){
          uplinkCheckTime = millis();
         else{
          Serial.println(requestState);
      debouncer.update();
        requestTime();
          oldTime = newTime;
      oldValue = value;
            send(msg.set(state));
    void uplinkCheck() {
        requestTime();
          oldTime = newTime;
      if (firstStart){
        oldTime = time;
        newTime = time;
      else{
      newTime = time;
      Serial.println(time);
    pepsonP 1 Reply Last reply
    • pepsonP pepson
      Please help me.
      #define RFM69_868MH
      #define RELAY_ON 0
      #define RELAY_OFF 1
      int oldValue = 0;
      bool state = false;
      bool requestState;
      void setup(){
      void loop(){
           else{
        debouncer.update();
          requestTime();
            oldTime = newTime;
        oldValue = value;
          requestTime();
            oldTime = newTime;
        if (firstStart){
          oldTime = time;
          newTime = time;
        else{
        newTime = time;
      pepsonP
      pepsonP
      pepson
      //#define MY_RFM69_FREQUENCY RFM69_868MHZ
      #define RFM69_868MH
      //#define MY_RFM69_CSMA_LIMIT_DBM (-85)
      #define MY_NODE_ID 1
      #define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
      #define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
      //#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
      //#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
      //#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
      #define RELAY_UP_PIN 5
      #define RELAY_DOWN_PIN 6
      #define RELAY_ON 0
      #define RELAY_OFF 1
      //#define RELAY_DOWN 1
      //#define RELAY_UP 0
      #define DIRECTION_DOWN 0
      #define DIRECTION_UP 1
      #define SKETCH_NAME "Roleta w sypialni"
      #define SKETCH_VER "2.3"
      #define CHILD_ID_COVER 0   // sensor Id of the sensor child
      #define STATE_UP 100 // 100 is open - up
      #define STATE_DOWN 0 // 0 is closed - down
      //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
      #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
      #define PRESENT_MESSAGE "Rolety dla Home Assistant"
      const int LEVELS = 100; //the number of levels
      float rollTime = 20.0; //the overall rolling time of the shutter
      const bool IS_ACK = false; //is to acknowlage
      static bool initial_state_sent = false;//for hass we need at list one state send at begining
      // debouncing parameters
      int value = 0;
      int oldValueUp = 0;
      int oldValueDown = 0;
      int oldValueStop = 0;
      //static unsigned long last_interrupt_time_up = 0;
      //static unsigned long last_interrupt_time_down = 0;
      //static unsigned long debounce_time = 200;
      Bounce debouncerUp = Bounce();
      Bounce debouncerDown = Bounce();
      Bounce debouncerStop = Bounce();
      // shutter position parameters
      float timeOneLevel = rollTime / LEVELS;
      int requestedShutterLevel = 0;
      int currentShutterLevel = 0;
      unsigned long lastLevelTime = 0;
      bool isMoving = false;
      int directionUpDown;
      bool calibrateDown;
      bool calibrateUp;
      unsigned long calibrationStartTime;
      float calibrationTime = 5.0;
      bool calibratedDown;
      bool calibratedUp;
      enum CoverState {
        STOP,
        UP, // Window covering. Up.
        DOWN, // Window covering. Down.
      static int coverState = STOP;
      MyMessage msgUp(CHILD_ID_COVER, V_UP);
      MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
      MyMessage msgStop(CHILD_ID_COVER, V_STOP);
      MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
      //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
      void sendState() {
        // Send current state and status to gateway.
      //  send(msgUp.set(coverState == UP));
      //  send(msgDown.set(coverState == DOWN));
      //  send(msgStop.set(coverState == STOP));
        send(msgPercentage.set(currentShutterLevel));
      void shuttersUp(void) {
        #ifdef MY_DEBUG
        Serial.println("Shutters going up");
        if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
          digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
          wait(50);
        digitalWrite(RELAY_UP_PIN, RELAY_ON);
        directionUpDown = DIRECTION_UP;
        isMoving = true;
        coverState = UP;
        sendState();
      void shuttersDown(void) {
        #ifdef MY_DEBUG
        Serial.println("Shutters going down");
        if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
          digitalWrite(RELAY_UP_PIN, RELAY_OFF);
          wait(50);
        digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
        directionUpDown = DIRECTION_DOWN;
        isMoving = true;
        coverState = DOWN;
        sendState();
      void shuttersHalt(void) {
      #ifdef MY_DEBUG
        Serial.println("Shutters halted");
        isMoving = false;
        requestedShutterLevel = currentShutterLevel;
      #ifdef MY_DEBUG
        Serial.println("saving state to: ");
        Serial.println(String(currentShutterLevel));
        saveState(CHILD_ID_COVER, currentShutterLevel);
        coverState = STOP;
        sendState();
      void changeShuttersLevel(int level) {
        int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
        if (isMoving && dir != directionUpDown) {
          shuttersHalt();
        requestedShutterLevel = level;
      void initShutters() {
      #ifdef MY_DEBUG
        Serial.println("Init Cover");
        shuttersUp();
        wait((rollTime + timeOneLevel * LEVELS) * 1000);
        currentShutterLevel = STATE_UP;
      #ifdef MY_DEBUG
        Serial.println("recieved incomming message");
        Serial.println("Recieved message for sensor: ");
        Serial.println(String(message.sensor));
        Serial.println("Recieved message with type: ");
        Serial.println(String(message.type));
        if (message.sensor == CHILD_ID_COVER) {
          switch (message.type) {
            case V_UP:
              //Serial.println(", New status: V_UP");
              changeShuttersLevel(STATE_UP);
              //state = UP;
              //sendState();
            case V_DOWN:
              //Serial.println(", New status: V_DOWN");
              changeShuttersLevel(STATE_DOWN);
              //state = DOWN;
              //sendState();
            case V_STOP:
              //Serial.println(", New status: V_STOP");
              shuttersHalt();
              //state = IDLE;
              //sendState();
            case V_PERCENTAGE:
              //Serial.println(", New status: V_PERCENTAGE");
              //          if (!initial_state_sent) {
              //            #ifdef MY_DEBUG
              //            Serial.println("Receiving initial value from controller");
              //            #endif
              //            initial_state_sent = true;
              int per = message.getInt();
              if (per > STATE_UP) {
                per = STATE_UP;
              changeShuttersLevel(per);
              //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
              //sendState();
      else if (message.sensor ==  CHILD_ID_SET) {
          if (message.type == V_VAR1) {
            #ifdef MY_DEBUG
            Serial.println(", New status: V_VAR1, with payload: ");
            String strRollTime = message.getString();
            rollTime = strRollTime.toFloat();
            #ifdef MY_DEBUG
            Serial.println("rolltime value: ");
            Serial.println(String(rollTime));
            saveState(CHILD_ID_SET, rollTime);
      #ifdef MY_DEBUG
        Serial.println("exiting incoming message");
        return;
      void before() {
        // Setup the button
        pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
        // Activate internal pull-up
      //  digitalWrite(BUTTON_UP_PIN, HIGH);
        //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
        pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
      //  digitalWrite(BUTTON_DOWN_PIN, HIGH);
        //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
      //  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
      //  digitalWrite(BUTTON_STOP_PIN, HIGH);
        debouncerUp.attach(BUTTON_UP_PIN);
        debouncerUp.interval(5);
        debouncerDown.attach(BUTTON_DOWN_PIN);
        debouncerDown.interval(5);
      //  debouncerStop.attach(BUTTON_STOP_PIN);
      //  debouncerStop.interval(5);
        pinMode(RELAY_UP_PIN, OUTPUT);
        pinMode(RELAY_DOWN_PIN, OUTPUT);
        sendSketchInfo(SKETCH_NAME, SKETCH_VER);
        present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
        // present(CHILD_ID_SET, S_CUSTOM);
      void setup(void) {
        //set up roll time if the saved value is not 255
        #ifdef MY_DEBUG
        Serial.println("getting rolltime from eeprom: ");
        float tmpRollTime = loadState(CHILD_ID_SET);
        if (tmpRollTime != 0xff) {
          rollTime = tmpRollTime;
        #ifdef MY_DEBUG
        int state = loadState(CHILD_ID_COVER);
        #ifdef MY_DEBUG
        Serial.println("getting state from eeprom: ");
        Serial.println(String(state));
      //  if (state == 0xff) {
      //    initShutters();
      //  } else {
          currentShutterLevel = state;
          requestedShutterLevel = state;
      void loop(void) {
      #ifdef MY_DEBUG
          Serial.println("Sending initial value");
          sendState();
         // send(msgCode.set('20.0'));
          //    #ifdef MY_DEBUG
          //    Serial.println("Requesting initial value from controller");
          //    #endif
          //    request(CHILD_ID_COVER, V_PERCENTAGE);
          //    wait(2000, C_SET, V_PERCENTAGE);
        debouncerUp.update();
        value = debouncerUp.read();
        if (value == 0 && value != oldValueUp) {
          if(isMoving){
            shuttersHalt();
          else{
          calibrateUp = false;
          calibratedUp = false;
          //state = UP;
          //sendState();
        oldValueUp = value;
        debouncerDown.update();
        value = debouncerDown.read();
        if (value == 0 && value != oldValueDown) {
          if(isMoving){
            shuttersHalt();
          else{
          calibrateDown = false;
          calibratedDown = false;
          //state = DOWN;
          //sendState();
        oldValueDown = value;
      /*  debouncerStop.update();
        value = debouncerStop.read();
        if (value == 0 && value != oldValueStop) {
          shuttersHalt();
          //state = IDLE;
          //sendState();
        oldValueStop = value;
        if(currentShutterLevel != 100)
        if(currentShutterLevel != 0)
        if (isMoving)
          unsigned long _now = millis();
          if (_now - lastLevelTime >= timeOneLevel * 1000) {
            if (directionUpDown == DIRECTION_UP) {
              currentShutterLevel += 1;
              currentShutterLevel -= 1;
            currentShutterLevel = constrain(currentShutterLevel, 0, 100);
            #ifdef MY_DEBUG
            Serial.println(String(requestedShutterLevel));
            lastLevelTime = millis();
          if (currentShutterLevel == requestedShutterLevel)
            if(currentShutterLevel == 0 && !calibratedDown)
              if(calibrateDown == false)
                calibrateDown = true;
                calibrationStartTime = _now;
                if(calibratedDown == false)
                  if (_now - calibrationStartTime >= calibrationTime * 1000)
                   calibratedDown = true;
            else if (currentShutterLevel == 100 && !calibratedUp)
              if(calibrateUp == false)
                calibrateUp = true;
                if(calibratedUp == false)
                   calibratedUp = true;
              shuttersHalt();
          if (requestedShutterLevel != currentShutterLevel)
            if (requestedShutterLevel > currentShutterLevel) {
              shuttersUp();
            else {
              shuttersDown();
      • pepsonP pepson
        #define RFM69_868MH
        #define RELAY_ON 0
        #define RELAY_OFF 1
        int value = 0;
        int oldValueUp = 0;
        bool calibrateDown;
        bool calibrateUp;
        bool calibratedUp;
        enum CoverState {
          STOP,
        void sendState() {
          #ifdef MY_DEBUG
            wait(50);
          isMoving = true;
          coverState = UP;
          sendState();
          #ifdef MY_DEBUG
            wait(50);
          isMoving = true;
          coverState = DOWN;
          sendState();
        #ifdef MY_DEBUG
          isMoving = false;
        #ifdef MY_DEBUG
          coverState = STOP;
          sendState();
            shuttersHalt();
        #ifdef MY_DEBUG
          shuttersUp();
        #ifdef MY_DEBUG
              case V_UP:
                //state = UP;
                //sendState();
              case V_DOWN:
                //state = DOWN;
                //sendState();
              case V_STOP:
                shuttersHalt();
                //state = IDLE;
                //sendState();
              case V_PERCENTAGE:
                //            #ifdef MY_DEBUG
                //            #endif
                  per = STATE_UP;
                //sendState();
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
        #ifdef MY_DEBUG
          return;
        void before() {
          // Setup the button
        void setup(void) {
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
        //    initShutters();
        //  } else {
        void loop(void) {
        #ifdef MY_DEBUG
            sendState();
            //    #ifdef MY_DEBUG
            //    #endif
            if(isMoving){
              shuttersHalt();
            else{
            //state = UP;
            //sendState();
          oldValueUp = value;
            if(isMoving){
              shuttersHalt();
            else{
            //state = DOWN;
            //sendState();
            shuttersHalt();
            //state = IDLE;
            //sendState();
          if (isMoving)
              #ifdef MY_DEBUG
                  calibrateUp = true;
                shuttersHalt();
                shuttersUp();
              else {
                shuttersDown();
        pepsonP
        pepsonP
        pepson
        Finally
        In my opinion on MySensors 2.2.0 all my sketches (switch relay and cover ) works better. With no problem. NO PROBLEM.
        Cover works perfect and switch works perfect without any timeout and delay. ANd all node works without REPEATER.
        My opinion is that in version 2.3.0 something not working correct with radio RFM69HW.
        Maybe for sensors which send data from time to time is ok , but for cover which transfer data when cover is roll, it is problem... and gateway can not recived all data when node send position cover. Maybe developer read this thread and can do any changes to correct it.
        scalzS S 2 Replies Last reply
        • M mickecarlsson
          pepsonP
          pepsonP
          pepson
          @mickecarlsson
          ANd tell me how you connect Gateway to your Domoticz Controller ? What path to usb or serial you setup in Domoticz ?
          • pepsonP pepson
            Finally
            #53
            @pepson said in RFM69 new driver delay:
            Like I said, we will take a look as soon as we get time. For the moment, busy (at least on my side). And we're a few, using rfm69.
            So if 2.2 fixes your issue, it can be a good idea.
            • scalzS scalz
              pepsonP
              pepsonP
              pepson
              @scalz
              Ok thanks. WAiting for info... and good info for me will be that problem with RFM69HW on version 2.3.0 will be resolve and i can update to this version. Now i must come back to version 2.2.0
                If you don't need specific features in 2.3, then stick to 2.2 that works well.
                • pepsonP pepson
                  Finally
                  sineverba
                  Finally
                  RFM69W / HW user here. I can confirm that V 2.3.0 on both nodes and PI has some broken. My nodes, stable for 3+ months, with new version they have issues. In detail, they cannot get ACK. In my sketch, I check for ACK when transmitting, to force the watchdog or no. NO ACK received (1 every 20/30) :(
                  And my nodes are "perfect". LifePo4 or AA, someone feeded directly, RPI3 with 2.5a... And I repeat, no issues in 3+ months from switching from NRF to RFM.
                    mickecarlsson
                    This is my generic temperature/humidity/battery level sketch that I use. I have upgraded all my nodes and gateway to 2.3.0 yesterday and I don't have any issue whatsoever :-)
                     * This is a sketch I use to measure temperature, humidity and battery level on
                     * my Easy/Newbie PCB for MySensors (rev 9)
                     * Hardware used:
                     * Easy/Newbie PCB for MySensors
                     * BME280 (I only use temperature and humidity, all code for barometic pressure removed)
                    #define   MY_SPLASH_SCREEN_DISABLED  // This saves a couple of bytes
                    #include <Wire.h>       // Enables the Wire communication protocol.
                    // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code,
                    // written originally by Embedded Adventures.
                    // https://github.com/embeddedadventures/BME280
                    #include <BME280_MOD-1022.h>
                    // Internal battery measurement https://github.com/Yveaux/arduino_vcc
                    #include <Vcc.h>
                    // Change all text variables here, no need to hunt them down in the sketch
                    // For sendSketchInfo()
                    #define SKETCH_NAME       "Generic Temeperature/Humidity"
                    #define SKETCH_VERSION    "1.13"
                    // For present()
                    #define PRESENT_TEMP_TEXT "Temperature Generic"
                    #define PRESENT_HUM_TEXT  "Humidity Generic"
                    #define PRESENT_BAT_TEXT  "Batteri Test-3"
                    // Battery measurements
                    const float VccMin        = 1.8*1.0;  // Min Vcc level, in Volts. Example for 2xAA Alkaline.
                    const float VccMax        = 2.0*1.5;  // Max Vcc level, in Volts. Example for 2xAA Alkaline.
                    Vcc vcc(VccCorrection);
                    // VARIABLES YOU CAN CHANGE
                    // Send temperature only if it has changed? 1 = Yes 0 = No.
                    #define COMPARE_TEMP 0
                    // Set this value to the minimum change in temperature to measure.
                    // BME280 has +-0.5 degrees precision, so it really doesn't matter that much.
                    float tempThreshold = 0.5;
                    // Send temperature only if changed? 1 = Yes 0 = No.
                    #define COMPARE_HUM 0
                    // Set this value to the minimum change in humidity to measure.
                    // BME280 has +-3% relative humidity precision, so it really doesn't matter that much.
                    float humThreshold = 0.5;
                    #define TEMP_CHILD_ID       1
                    #define HUM_CHILD_ID        2
                    #define VOLTAGE_CHILD_ID    3
                    float lastTemperature = -1;   // Store previous measurement
                    float lastHumidity =    -1;   // Stores the previous measurement
                    bool reportRSSI = false;      // true = send RSSI to controller
                    int sendBattery = 6;          // report battery level only after 6 loops = 6*4 minutes = 24 minutes
                    // Placeholder for batteryloop, set to one above sendBattery so that we get a report on startup
                    int batteryLoop = sendBattery + 1;
                    // Time between send (in milliseconds), in this case, 4 minutes.
                    unsigned long FOUR_MINUTE_SEND_FREQUENCY = 4 * 60000;
                    // MYSENSORS COMMUNICATION VARIABLES
                    MyMessage temperatureMsg(TEMP_CHILD_ID, V_TEMP);
                    MyMessage humidityMsg(HUM_CHILD_ID, V_HUM);
                    MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
                    #ifdef MY_DEBUG
                      Wire.begin(); // For the BME280 sensor
                    #ifdef MY_DEBUG
                      Serial.println(F("Starting ..."));
                      // Present the sensors to the gateway and controller
                      present(TEMP_CHILD_ID, S_TEMP, PRESENT_TEMP_TEXT);
                      present(HUM_CHILD_ID, S_HUM, PRESENT_HUM_TEXT);
                      present(VOLTAGE_CHILD_ID, S_MULTIMETER, PRESENT_BAT_TEXT);
                    #ifdef MY_DEBUG
                      Serial.println(F("Read BME280 and report it's values."));
                      GetTemperatureHumidity();                 // Get temperature and humidity
                      if(batteryLoop > sendBattery) {           // Is the batteryLoop higher than sendBattery?
                    #ifdef MY_DEBUG
                        Serial.println(F("Read the battery voltage and report it."));
                        MeasureBattery();                      // Measure and report battery level
                        batteryLoop = 0;                       // Reset batteryLoop count
                    #ifdef MY_DEBUG
                      Serial.print(F("Go to sleep for: "));
                      Serial.print(FOUR_MINUTE_SEND_FREQUENCY / 60000);
                      Serial.println(F(" minutes."));
                      batteryLoop++;                           // Increase batteryLoop before we sleep.
                      sleep(FOUR_MINUTE_SEND_FREQUENCY);       // Sleep for 4 minutes
                    * GetTemperatureHumidity()
                    * Routine for measuring temperature and humidity
                    * Generic one that fits my need
                    void GetTemperatureHumidity()
                    #ifdef MY_DEBUG
                      Serial.println("");
                      Serial.println(F("BME280 - Requesting new data from sensor module."));
                      BME280.readCompensationParams();            // Need to read the NVM compensation parameters.
                      // Normal mode for regular automatic samples
                      BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
                      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
                      BME280.writeOversamplingPressure(os16x);    // pressure x16
                      BME280.writeOversamplingTemperature(os8x);  // temperature x8
                      BME280.writeOversamplingHumidity(os8x);     // humidity x8
                      BME280.writeMode(smNormal);
                    #ifdef MY_DEBUG
                      Serial.println(F("Getting new values"));
                      while (BME280.isMeasuring()) {              // Wait for BME280 to fininsh reading data
                    #ifdef MY_DEBUG
                        Serial.println("Measuring...");
                        delay(50);
                      Serial.println("Done!");
                      // Read out the data - must do this before calling the getxxxxx routines
                      BME280.readMeasurements();
                      float temperature = BME280.getTemperatureMostAccurate();  // Get the temperature first.
                      float humidity = BME280.getHumidityMostAccurate();        // Get the humidity.
                    #ifdef MY_DEBUG
                      Serial.print(F("BME280 - Temperature = "));
                      Serial.print(temperature);
                      Serial.println(" °C");
                      Serial.print(F("BME280 - Humidity = "));
                      Serial.print(humidity);
                      Serial.println(F(" %"));
                      // Now, let's send the measurements to the gateway.
                      // Send temperature if the temperature difference bigger than the threshold
                      if (COMPARE_TEMP == 1 && abs(temperature - lastTemperature) < tempThreshold) {
                    #ifdef MY_DEBUG
                        Serial.print(temperature - lastTemperature);
                        Serial.println(F(" Temperature difference too small, don't send it to gateway."));
                    #ifdef MY_DEBUG
                          Serial.println(F("Sending new temperature to the gateway."));
                          send(temperatureMsg.set(temperature, 1));
                          lastTemperature = temperature; // Save temperatures for compare in the next round.
                      // Send humidity if the humidity difference is bigger than the threshold.
                      if (COMPARE_TEMP == 1 && abs(humidity - lastHumidity) < humThreshold) {
                    #ifdef MY_DEBUG
                        Serial.print(humidity - lastHumidity);
                        Serial.println(F(" Humidity difference too small, don't send it to the gateway."));
                    #ifdef MY_DEBUG
                        Serial.println(F("BME280 - Sending the new humidity to the gateway."));
                        send(humidityMsg.set(humidity, 1));
                        lastHumidity = humidity; // Save new humidity to be able to compare in the next round.
                    #ifdef MY_DEBUG
                      Serial.println(F("BME280 - Measurement complete. Putting sensor to sleep."));
                      BME280.writeMode(smSleep);  // set the BME280to sleep mode, save battery
                    } // End of GetTemperatureHumidity
                    * MeasureBattery()
                    * Routine for measuring battery level
                    * NOTE: You need to calibrate the measurement to get correct readings
                    void MeasureBattery()
                      float Vbat = vcc.Read_Volts();
                      int batteryPercent = static_cast<int>(vcc.Read_Perc(VccMin, VccMax));
                    #ifdef MY_DEBUG
                      Serial.print(F("Battery percent: "));
                      Serial.print(batteryPercent);
                      Serial.println(" %");
                      Serial.print(F("Battery Voltage: "));
                      Serial.print(Vbat);
                      Serial.println(F(" Volts"));
                        send(voltageMsg.set(Vbat,2)); //send battery in Volt 2 decimal places
                    • pepsonP pepson
                      @mickecarlsson
                      Can you share me your all sketches ? Thanks
                      And tell me how you have connected Gateway to RPI3? By ethernet or by serial ? Because i see in your building Gateway that you dont use parameter ETHERNET on port 5003
                      And anybody has any contact to developer @tekka007 ?
                      This is info what show in debug on version 2.3.0 gateway and also node on version 2.3.0
                      pi@hassbian:~/MySensors $ sudo /usr/local/bin/mysgw
                      Jun 22 17:22:49 INFO  Starting gateway...
                      Jun 22 17:22:49 INFO  Protocol version - 2.3.0
                      Jun 22 17:22:49 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
                      Jun 22 17:22:49 DEBUG TSF:LRT:OK
                      Jun 22 17:22:49 DEBUG TSM:INIT
                      Jun 22 17:22:49 DEBUG TSF:WUR:MS=0
                      Jun 22 17:22:49 DEBUG TSM:INIT:TSP OK
                      Jun 22 17:22:49 DEBUG TSM:INIT:GW MODE
                      Jun 22 17:22:49 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                      Jun 22 17:22:49 DEBUG MCO:REG:NOT NEEDED
                      Jun 22 17:22:49 DEBUG Listening for connections on 0.0.0.0:5003
                      Jun 22 17:22:49 DEBUG MCO:BGN:STP
                      Jun 22 17:22:49 DEBUG MCO:BGN:INIT OK,TSP=1
                      Jun 22 17:22:54 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      Jun 22 17:22:54 DEBUG TSF:MSG:BC
                      Jun 22 17:22:54 DEBUG TSF:MSG:FPAR REQ,ID=2
                      Jun 22 17:22:54 DEBUG TSF:CKU:OK,FCTRL
                      Jun 22 17:22:54 DEBUG TSF:MSG:GWL OK
                      Jun 22 17:22:54 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=O                 K:0
                      Jun 22 17:22:56 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Jun 22 17:22:56 DEBUG TSF:MSG:PINGED,ID=2,HP=1
                      Jun 22 17:22:57 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=                 OK:1
                      Jun 22 17:22:57 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      Jun 22 17:22:58 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=                 OK:0100
                      Jun 22 17:22:59 DEBUG TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                      Jun 22 17:23:00 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=25,sg=0:1xRelay &                  Button-Sypialni
                      Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=5,sg=0:2.2.0
                      Jun 22 17:23:04 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                      Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                      Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      Jun 22 17:23:06 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                      Jun 22 17:23:07 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                      Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                      Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                      Jun 22 17:23:09 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                      mickecarlsson
                      I use Ethernet to connect to my Domoticz.
                      The reason that you don't see my configuration for ETHERNET or PORT is because they are default when you configure.
                      If you look at the file Makefile.inc you will see the build options. In my case the file looks like this:
                      SOC=BCM2837
                      CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RFM69 -DMY_RFM69_NEW_DRIVER -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_RFM69_FREQUENCY=RFM69_868MHZ -DMY_IS_RFM69HW
                      LDFLAGS=-pthread
                      PREFIX=/usr/local
                      CC=gcc
                      CXX=g++
                      BUILDDIR=build
                      BINDIR=bin
                      GATEWAY_DIR=/usr/local/bin
                      INIT_SYSTEM=systemd
                      SPI_DRIVER=BCM
                      So in my case I have these defines:
                      MY_RADIO_RFM69
                      MY_RFM69_NEW_DRIVER
                      MY_GATEWAY_LINUX
                      MY_DEBUG
                      LINUX_SPI_BCM
                      MY_IS_RFM69HW
                      • M mickecarlsson
                         * Hardware used:
                        #include <Vcc.h>
                        // For present()
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                          Serial.println("");
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                            delay(50);
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        #ifdef MY_DEBUG
                        * MeasureBattery()
                        #ifdef MY_DEBUG
                          Serial.print(Vbat);
                        pepsonP
                        pepsonP
                        pepson
                        @mickecarlsson
                        You dont have issue becuase temp/hum send data from time to time every defined time.
                        My sketch with relay also looks that works ok.
                        But problem is on sketch with relay to control covers. WHen cover roll node send still data and it is problem...
                        This is my opinion.
                        • M mickecarlsson
                          SOC=BCM2837
                          LDFLAGS=-pthread
                          PREFIX=/usr/local
                          CC=gcc
                          CXX=g++
                          BUILDDIR=build
                          BINDIR=bin
                          INIT_SYSTEM=systemd
                          SPI_DRIVER=BCM
                          MY_RADIO_RFM69
                          MY_RFM69_NEW_DRIVER
                          MY_GATEWAY_LINUX
                          MY_DEBUG
                          LINUX_SPI_BCM
                          MY_IS_RFM69HW
                          pepsonP
                          pepsonP
                          pepson
                          wrote on last edited by pepson
                          #60
                          @mickecarlsson said in RFM69 new driver delay:
                          LDFLAGS=-pthread
                          Tell me you have BME280 this :
                          https://www.aliexpress.com/item/3In1-BME280-GY-BME280-Digital-Sensor-SPI-I2C-Humidity-Temperature-and-Barometric-Pressure-Sensor-Module-1/32847825408.html?spm=2114.search0104.3.1.6d76301deOqjBT&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_5722615_10696_10084_10083_10618_10304_10307_10820_10301_10821_5722715_10843_10059_306_100031_10103_10624_10623_10622_5722515_10621_10620,searchweb201603_1,ppcSwitch_5&algo_expid=8f90a51c-aded-4f24-a909-68e32bf05b4b-0&algo_pvid=8f90a51c-aded-4f24-a909-68e32bf05b4b&priceBeautifyAB=0
                          My defined is the same:
                          SOC=BCM2837
                          CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RFM69 -DMY_RFM69_NEW_DRIVER -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_DEFAULT_TX_LED_PIN=18 -DMY_DEFAULT_RX_LED_PIN=16 -DMY_DEFAULT_ERR_LED_PIN=12 -DMY_PORT=5003 -DMY_IS_RFM69HW -DMY_RFM69_FREQUENCY=RFM69_868MHZ
                          LDFLAGS=-pthread
                          PREFIX=/usr/local
                          CC=gcc
                          CXX=g++
                          BUILDDIR=build
                          BINDIR=bin
                          INIT_SYSTEM=systemd
                          SPI_DRIVER=BCM
                            #61
                            @pepson
                            just to know, when you get this issue, do you send to one shutter only? (because i see you're sending each %, each 200ms). Well we have already did a stress test in the past, one packet each 50-70ms with a dozen of nodes and it worked but that was with a local unoffcial lib, and not with rpi as gw.
                            I don't remember if buffer has been implemented in regular branch, for rfm69 (but I think so). And it should work like you said it works with 2.2
                            We'll be able retry some stress tests, unfortunately not on rpi as gw (not using this setup), I'm not sure but maybe only marceloaqno may be using rpi with rfm69 (not sure), and we're a very few rfm69 users. Let us check if it's a general problem or rpi as gw only.
                            Sorry for disturbance ;)
                            • scalzS scalz
                              @pepson
                              pepsonP
                              pepsonP
                              pepson
                              @scalz
                              Hmmm
                              I am not advanced user. This sketch i found on github from other user. I can change sometinh in sketch to test it ? Can you help me what change in sketch to test ?
                                #63
                                @pepson
                                no idea if it will help you, but what i meant is sending less msg .
                                I think i recognize some parts of this sketch, not sure :)
                                So, in your sketch, here you can see it sends at each %
                                  if (isMoving)
                                      #ifdef MY_DEBUG
                                try to change this last line, by:
                                if (currentShutterLevel % 5 == 0) send(msgPercentage.set(currentShutterLevel)); // change 5 by 10 if you want to send each 10% for example
                                no worry about shutter level update in controller, because when it will stop it will send its level (with sendstate in shutterhalt).
                                As your settings in top of sketch is 20sec for a complete roll, then it should send each second instead of 200ms previously (except if you did some calibration), and if i'm not wrong, I quickly read it!
                                • scalzS scalz
                                  @pepson
                                    if (isMoving)
                                        #ifdef MY_DEBUG
                                  pepsonP
                                  pepsonP
                                  pepson
                                  @scalz
                                  Sorry but i dont know what line chage with this your line
                                  if (currentShutterLevel % 5 == 0) send(msgPercentage.set(currentShutterLevel)); // change 5 by 10 if you want to send each 10% for example```
                                    #65
                                    @pepson
                                    I extracted a part of your sketch above. change the last line of the extract
                                    • scalzS scalz
                                      @pepson
                                      pepsonP
                                      pepsonP
                                      pepson
                                      #66
                                      @scalz
                                      Should looks like this ?
                                      if (isMoving)
                                            #ifdef MY_DEBUG
                                      • pepsonP pepson
                                        @scalz
                                        if (isMoving)
                                              #ifdef MY_DEBUG
                                        pepsonP
                                        pepsonP
                                        pepson
                                        Ok tested as show in previus post. And the same problem. Maybe a little better. But maybe no...
                                        On 2.2.0 is a very very better.
