  3. Nemaxx smoke alarm WL2
4 Posts 2 Posters 2.4k Views 2 Watching
  • F Offline
    F Offline
    freynder
    I just wanted to share my findings so far for this smoke detector I'm currently working on in case somebody is interested.
    I bought 5 of them for ~40 EUR a year ago from amazon.de . They use a 9V battery + 3x 1.5V AA batteries. They are able to network over 433Mhz; if 1 alarm is triggered, they will all sound alarm. Amazon link is below:
    https://www.amazon.de/Nemaxx-Funkrauchmelder-Rauchmelder-Brandmelder-koppelbar/dp/B00EZCMFPC/ref=sr_1_2?ie=UTF8&qid=1529688708&sr=8-2&keywords=nemaxx%2Bwl2&th=1
    I did a quick analysis of the PCB and here are the findings:
    • 9V battery powers the smoke detector and piezzo alarm part.
    • 3x 1.5V AA batteries powers a seperate MCU + flash memory through a 3.3V LDO regulator.
    • The MCU seems responsible for user interface (buttons and leds) and communications. It integrates with the smoke detector part.
    • MCU chip is em78p156el
    • When the alarm is activated, pin P64 is pulled low for the duration of the alarm.
    This makes it pretty easy to turn into a MySensors device. There is already a power source + LDO regulator with 3.3V output. Detecting the alarm activating / deactivating is very straightforward using the P64 pin.
    I'm only hesitating if I should use the LDO regulator outputs directly or rather add my own.
    S 1 Reply Last reply
    • F freynder
      @freynder nice work. I have these as well and the 3xaa runs out pretty fast for me so a good hack to give it a longer life would be interesting.
      • F Offline
        F Offline
        freynder
        @sundberg84 Interestingly, the 9V battery ran out on me after a year. I'm now replacing it with an amazon basics battery. So far all 5 still have their 3xAA's running. How long before yours run out?
        • F freynder
          @freynder it is different. I don't know if they try to connect to each other and if some having issues with that it drains the battery.
          12.1k
