  3. Domoticz
  4. Domotiocz + Rain gauge
61 Posts 12 Posters 45.5k Views 12 Watching
  • HilltanH
    HilltanH
    Hilltan
    Thanks @TheoL, I will give it a try.
    • HilltanH
      HilltanH
      Hilltan
      Finally I get it to run with a light sensor (BH1750), temp/hum sensor (DHT22), and the rain tipping sensor. But there are some problems:
      Domoticz seems not to want to divide the DHT sensor in to two, one humidity and one temperature. What I get in Domoticz is one WTGR800 (temp/hum) and one LaCrosse TX3 (temp). Have played around with the code a little bit, just ending up with one WTGT800 (temp/hum) and one LaCrosse TX3 (temp or humidity).
      The rain sensor gets fault impulse from time to time, the sensor got trigged without that the sensor have been set off?
      Overall your @TheoL Threshhold util is a very nice tool to work with, but the DHT sensor is not that easy to deal with I think…
        Include libraries used by the sketch
      #include "ThresholdUtil.h"
      #include <math.h>
      #include <Time.h>
      #include <BH1750.h>
      #include "DHT.h"
      DHT dht;
      #define DHT 0
      #define BUCKET_PIN 3                  // The Arduino pin to which the bucket is attached. We need an interrupt pin (2 or 3 on the Uno and the Pro Mini)
      #define SKETCH_INFO "Outside weather" // The name of the sketch as presented to the gateway
      #define SKETCH_VERSION "1.0"          // The version of the sketch as presented to the gateway
      #define CHILD_ID_RAIN_LOG 4           // The child id of the rain gauge
      #define MS_WAIT 100                   // short delay used to give the NRF24L01+ antenna some time to recover from the last data sending
      #define bucketSize 0.3                // I've used a MI-SOL Rain Guage which has a bucket size of 0.3 mm
      #define LIGHTLEVEL_SENSOR_CHILD_ID 0
      #define LIGHTLEVEL_SENSOR_ID 3
      #define CHILD_ID_TEMP 5
      #define DHT_TEMP 6
      #define CHILD_ID_HUMIDITY 7
      #define DHT_HUM 9
      #define DHT_DATA_PIN 8
      MyMessage lightLevelMsg(LIGHTLEVEL_SENSOR_CHILD_ID, V_LIGHT_LEVEL);
      MyMessage msgHum( CHILD_ID_HUMIDITY, V_HUM );
      MyMessage msgTemp( CHILD_ID_TEMP, V_TEMP );
      MyMessage msgRain( CHILD_ID_RAIN_LOG, V_RAIN );
      MyMessage lastCounterMsg( CHILD_ID_RAIN_LOG, V_VAR1 );
      BH1750 lightSensor;
      float hwRainVolume = 0;           // Current rainvolume calculated in hardware.
      unsigned long hwPulseCounter = 0; // Pulsecount recieved from GW
      boolean pcReceived = false;       // If we have recieved the pulscount from GW or not
      unsigned long lastTipTime = millis(); // TS of when the bucket tip has been detected for the last time
      volatile unsigned long wasTippedCounter; // Queue for storing the tipped counter as been set by the interrupt handler.
      byte lastHour;                    // Stores the hour used for checking if time needs to be synchronized
        sendSketchInfo( SKETCH_INFO, SKETCH_VERSION );
        wait( MS_WAIT );
        present(LIGHTLEVEL_SENSOR_CHILD_ID, S_LIGHT_LEVEL, "Light level" );
        wait( MS_WAIT );
        present( CHILD_ID_HUMIDITY, S_HUM, "Outside Humidity" );
        wait( MS_WAIT );
        present( CHILD_ID_TEMP, S_TEMP, "Outside Temperature" );
        wait( MS_WAIT );
        present( CHILD_ID_RAIN_LOG, S_RAIN, "Rain fall" );
        wait( MS_WAIT );
        unsigned long functionTimeout = millis();
        while ( pcReceived == false && millis() - functionTimeout < 30000UL ) {
          request( CHILD_ID_RAIN_LOG, V_VAR1);
          Serial.println(F("Getting pulse count"));
          Serial.println(F("."));
          wait( 1000 );
        attachInterrupt( digitalPinToInterrupt( BUCKET_PIN ), sensorTipped, LOW ); //FALLING );  // depending on location of the hall effect sensor may need CHANGE
        Serial.begin( 115200 );
        pinMode( BUCKET_PIN, INPUT_PULLUP );
        lightSensor.begin();
        registerThresholdedSensor( LIGHTLEVEL_SENSOR_CHILD_ID,  LIGHTLEVEL_SENSOR_ID,  LIGHTLEVEL_SENSOR,  20,  30, 20 ); // read every 5 sec and report at least every 5 minute ändrat 300 till 20
        registerThresholdedSensor( CHILD_ID_TEMP, DHT_TEMP, TEMPERATURE_SENSOR, 0.5, 30, 20 ); // every 30 seconds report at least every 10 minutes
        registerThresholdedSensor( CHILD_ID_HUMIDITY, DHT_HUM, HUMIDTY_SENSOR, 1.0, 60, 10 ); // every 60 seconds
        dht.setup( DHT_DATA_PIN ); // data pin 8
        delay( dht.getMinimumSamplingPeriod() );
        while ( timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL ) {
          requestTime();
          Serial.println(F("Getting Time"));
          wait( 1000 );
        lastHour = hour();
        Sends the value of the rain gauge to the Gateway.
      void sendRainVolumeData() {
        float hwRainVolume = hwPulseCounter * bucketSize;
        Serial.print( "Tipped " );
        Serial.print( hwPulseCounter );
        Serial.println( " times." );
        Serial.print( "Rain fall is " );
        Serial.print( hwRainVolume, 1 );
        Serial.println( " mm." );
        send( msgRain.set( (float)hwRainVolume, 1 ) );
        wait( MS_WAIT );
        send( lastCounterMsg.set( hwPulseCounter ) );
        wait( MS_WAIT );
        if ( wasTippedCounter != hwPulseCounter ) {
          hwPulseCounter = wasTippedCounter;
          sendRainVolumeData();
        byte currentHour = hour();
        if (currentHour != lastHour) {
          Serial.println( "Resyncing hour" );
          requestTime(); // sync the time every hour
          wait( MS_WAIT );
          lastHour = currentHour;
          sendRainVolumeData(); // Send heart beat
      checkThresholdedSensors( readSensorValue, updatedSensorValue );
      void sensorTipped() {
        unsigned long thisTipTime = millis();
        if (thisTipTime - lastTipTime > 100UL) {
          wasTippedCounter++;
        lastTipTime = thisTipTime;
      float dhtHumidity;
      void readSensorValue( uint8_t aSensorId, ThreshHoldedSensorType aType, float *value ) {
        switch ( aSensorId ) {
          case LIGHTLEVEL_SENSOR_ID:
            if ( aType == LIGHTLEVEL_SENSOR ) {
              *value = lightSensor.readLightLevel();
            case DHT_TEMP:
            if ( aType == TEMPERATURE_SENSOR ) {
              *value = dht.getTemperature();
            case DHT_HUM:
            if ( aType == HUMIDTY_SENSOR ) {
              *value = dht.getHumidity();
      void updatedSensorValue( uint8_t child_id, uint8_t sensor_id, ThreshHoldedSensorType sensor_type, float value ) {
        switch ( child_id ) {
          case LIGHTLEVEL_SENSOR_CHILD_ID:
            Serial.print( "Light level " );
            Serial.print( value, 0 );
            Serial.println( "%" );
            send( lightLevelMsg.set( value, 5 ) );
            wait( MS_WAIT );
          case CHILD_ID_TEMP:
            Serial.print( "Temperatur " );
            Serial.print( "C" );
            send( msgTemp.set( value, 1 ) );
            wait( MS_WAIT );
          case CHILD_ID_HUMIDITY:
            Serial.print( "HUMIDITY " );
            Serial.print( "%" );
            send( msgHum.set( value, 1 ) );
            wait( MS_WAIT );
      void receiveTime(unsigned long time) {
        Serial.println( F("Time received..."));
        setTime(time);
        char theTime[6];
        sprintf(theTime, "%d:%2d", hour(), minute());
        Serial.println(theTime);
        if ( message.sensor == CHILD_ID_RAIN_LOG && message.type == V_VAR1) { // We only expect pulse count values from the gateway
          hwPulseCounter = message.getULong();
          wasTippedCounter = hwPulseCounter;
          pcReceived = true;
          Serial.print("Received last pulse count from gw: ");
          Serial.println(hwPulseCounter);
      There are probably strange things in the sketch, I am new to this ;)
      AWIA 1 Reply Last reply
      • HilltanH Hilltan
        #include <math.h>
        #include <Time.h>
        #include <BH1750.h>
        #include "DHT.h"
        DHT dht;
        #define DHT 0
        #define DHT_TEMP 6
        #define DHT_HUM 9
        BH1750 lightSensor;
          wait( MS_WAIT );
          wait( MS_WAIT );
          wait( MS_WAIT );
          wait( MS_WAIT );
          wait( MS_WAIT );
            wait( 1000 );
            requestTime();
            wait( 1000 );
          lastHour = hour();
          wait( MS_WAIT );
          wait( MS_WAIT );
            wait( MS_WAIT );
            wasTippedCounter++;
        float dhtHumidity;
              case DHT_TEMP:
              case DHT_HUM:
              wait( MS_WAIT );
            case CHILD_ID_TEMP:
              wait( MS_WAIT );
              wait( MS_WAIT );
          setTime(time);
          char theTime[6];
            pcReceived = true;
        AWIA
        AWIA
        AWI
        @Hilltan it is a Domoticz 'feature' to combine temperature, humidity and barometric sensors. There is a method to separate them if you have (or pretend to have) multiple sensors of the same type. This is done by presenting the one you want to combine right after each other.
        In your case I would just keep it...
        • sundberg84S sundberg84
          This is my rainsensor/tipping bucket for MySensors that works with Domoticz.
          It uses 2xAA as power source, a Pro Mini 3.3v with a 0.9 to 3.3 booster.
          The bucket has a magnet which triggeras a reed switch which triggers an interrupt pin.
          I also use battery sensing with voltage divider.
          #define MY_NODE_ID 7
          // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
          #define DIGITAL_INPUT_SENSOR 3                  // The reed switch you attached.  (Only 2 and 3 generates interrupt!)
          #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
          #define CHILD_ID 1                              // Id of the sensor child
          #define SKETCH_NAME "Rain Gauge"                // Change to a fancy name you like
          #define SKETCH_VERSION "1.1"                    // Your version
          unsigned long SLEEP_TIME = 18*60000;            // Sleep time (in milliseconds).
          //unsigned long SLEEP_TIME = 20000;             // use this instead for debug
          int hwPulseCounter = 0;                         // Pulsecount recieved from GW
          float fullCounter = 0;                           // Counts when to send counter
          float bucketSize = 0.5;                           // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
          boolean reedState;                              // Current state the reedswitch is in
          boolean oldReedState;                           // Old state (last state) of the reedswitch
          unsigned long lastSend =0;                      // Time we last tried to fetch counter.
          MyMessage volumeMsg(CHILD_ID,V_RAIN);
          MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
            // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
            present(CHILD_ID, S_RAIN);
            pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);  // sets the reed sensor digital pin as input
            reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
            oldReedState = reedState; // Set startup position for reedswitch
            Serial.println("Startup completed");
          unsigned long currentTime = millis();
              //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
              if (!pcReceived && (currentTime - lastSend > 5000)) {
                request(CHILD_ID, V_VAR1);
                lastSend=currentTime;
                return;
              if (!pcReceived) {
                return;
          //Read if the bucket tipped over
          boolean tipped = oldReedState != reedState;
              //BUCKET TIPS!
              if (tipped==true) {
              Serial.println("The bucket has tipped over...");
              hwRainVolume = hwRainVolume + bucketSize;
              send(volumeMsg.set((float)hwRainVolume,1));
              wait(1000);
              fullCounter = fullCounter + bucketSize;
                //Count so we send the counter for every 1mm
                if(fullCounter >= 1){
                hwPulseCounter++;
                send(lastCounterMsg.set(hwPulseCounter));
                wait(1000);
                fullCounter = 0;
              if (tipped==false) {
               //No bucket tipped over last sleep-period, check battery then...
               batM();
          sleep(INTERRUPT, CHANGE, SLEEP_TIME);
          //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
          //Read if we have a incoming message.
          void receive(const MyMessage &msg) {
              if (msg.type==V_VAR1) {
              hwPulseCounter = msg.getULong();
              hwRainVolume = hwPulseCounter;
              pcReceived = true;
          void batM(){  //The battery calculations
             delay(500);
             // Battery monitoring reading
             delay(500);
             // Calculate the battery in %
             if (batLoop > 1) {
               batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
             if (batteryPcnt > 100) {
               batteryPcnt=100;
                 batLoop = 0;
               //Sends 1 per hour as a heartbeat.
               batLoop++;
          Matt
          @sundberg84 sorry I know this is an old thread but hoping you can remember how you wrote this code.I have changed it to suit MYS 2.1 as below. I have also added battery level as a separate child ID so I can watch performance over time. Aside from these simple changes the code is all yours from the start of this post. It is built on v8 of your board, controller/GW is latest domoticz beta running on a PI2 using NRFs.
          I have a couple of questions though. I am curious as to why bucketSize needs to be 1, 0.5, 0.25, 0.2 or 0.1 as per your comments and I suspect that when I calibrate my gauge it wont be any of these.
          I am testing at the moment without the gauge. When I earth D3 it actually reports as TWO bucket tips and the volume goes up by 0.5 twice. I dont think this is a bounce issue due to the many wait(1000) functions in your code. Would you know why this is? I have tried changing CHANGE to FALLING in the sleep function. I have a simple reed switch gague.
          Which leads to my third question. Are all the wait times necessary? Could they be much less? I wonder if I will miss bucket tips because of these during heavy rain...
          Many many thanks,
          Matt
          #define CHILD_ID_BAT 2                          // Id of BAT
          MyMessage msgBat(CHILD_ID_BAT, V_VOLTAGE);
            present(CHILD_ID_BAT, S_MULTIMETER);
            delay(500);                                    // Allow time for radio if power used as reset
                return;
              if (!pcReceived) {
                return;
              //BUCKET TIPS!
              if (tipped==true) {
              wait(1000);
                hwPulseCounter++;
                wait(1000);
                fullCounter = 0;
               batM();
          sleep(INTERRUPT, FALLING, SLEEP_TIME);
              pcReceived = true;
             delay(500);
             delay(500);
             if (batLoop > 1) {
               batteryPcnt=100;
                 send(msgBat.set(Vbat, 4));
                 batLoop = 0;
               batLoop++;
          • M Matt
            Many many thanks,
            Matt
                  return;
                if (!pcReceived) {
                  return;
                //BUCKET TIPS!
                if (tipped==true) {
                wait(1000);
                  hwPulseCounter++;
                  wait(1000);
                  fullCounter = 0;
                 batM();
                pcReceived = true;
               delay(500);
               delay(500);
               if (batLoop > 1) {
                 batteryPcnt=100;
                   batLoop = 0;
                 batLoop++;
            sundberg84S
            sundberg84S
            #55
            @Matt said in Domotiocz + Rain gauge:
            OK :) Lets see what I can do...
            Its because of this calculaction and that Domoticz uses 1mm counter:
                  hwPulseCounter++;
                  wait(1000);
                  fullCounter = 0;
            If the bucketsize is set to say 0,3mm it will not add up to a full 1 and the code is lost. (0,3+0,3+0,3+0,3 = 1.2) and 0,2 is lost. Im sure you can code this better (code is not my strong side!!!)
            Do you have a pulldown/up resistor to avoid the pin floats?
            Its a matter of code and what bucket you have. Some wait() are for debounce and stabilising power for radio and readings. I would not change those but I always aim for the high numbers to be sure(wait(1000); = really high!!). Try!
            Other wait() could depend on what kind of bucket you use - im sorry to say, but all you can do is try!
                    hwPulseCounter++;
                    wait(1000);
                    fullCounter = 0;
              Matt
              @sundberg84
              Thankyou very much for your reply.
              It seems strange that domoticz would only accept 1mm pulses I wonder if this has changed... In any case it should be easy to save the 'lost' volume and add it to the next bucket in code...
              The internal pullup is switched on in code so reed switch pin won't be floating. Will have a fiddle round with your code today.
              Will also try to calibrate by gauge today will be easy to see max tipping speed and can adjust wait times accordingly...
              Thanks again,
              Matt
              • M Matt
                @sundberg84
                Thanks again,
                Matt
                sundberg84S
                sundberg84S
                @Matt - Let me know if I can help you anything-
                • HilltanH
                  HilltanH
                  Hilltan
                  I need could need some help/advice to get my rain gauge to show correct values, as per today my rain gauge shows to low values. The rain gauge that I use is this one: Rain gauge
                  I use Domoticz V 3.8153 with Mysensors V2.1.1 and have bucket size 0,3. Anyone that have experience with this rain gauge and what bucket size to use for correct values or is there something with my code that creates problems?
                  This it my sketch that I am usning:
                  #define MY_NODE_ID 5
                  #include <math.h>
                  #include <Time.h>
                  #include "DHT.h"
                  DHT dht;
                  #define DHT 0
                  #define SKETCH_INFO "Rain,Temp&Hum" // The name of the sketch as presented to the gateway
                  #define DHT_TEMP 6
                  #define DHT_HUM 9
                  #define DHT_DATA_PIN 5
                    wait( MS_WAIT );
                    wait( MS_WAIT );
                    wait( MS_WAIT );
                    wait( MS_WAIT );
                      wait( 1000 );
                    attachInterrupt( digitalPinToInterrupt( BUCKET_PIN ), sensorTipped, LOW ); //FALLING );  // depending on location of the hall effect sensor may need CHANGE, LOW or HIGE
                    registerThresholdedSensor( CHILD_ID_TEMP, DHT_TEMP, TEMPERATURE_SENSOR, 0.5, 60, 8 ); // Change of value +/-0,5 , every 60 seconds report, and force report every 8 minutes
                    registerThresholdedSensor( CHILD_ID_HUMIDITY, DHT_HUM, HUMIDTY_SENSOR, 1.0, 60, 8 ); // Change of value +/- 1, every 60 seconds report, and force report every 8 minutes
                      requestTime();
                      wait( 1000 );
                    lastHour = hour();
                    wait( MS_WAIT );
                    wait( MS_WAIT );
                      wait( MS_WAIT );
                      wasTippedCounter++;
                  float dhtHumidity;
                        case DHT_TEMP:
                        case DHT_HUM:
                        case CHILD_ID_TEMP:
                        wait( MS_WAIT );
                        wait( MS_WAIT );
                    setTime(time);
                    char theTime[6];
                      pcReceived = true;
                  • J
                    J
                    JCH
                    Hi
                    I am using this sketch on my battery powered rain gauge but have noticed the gauge never resets, how are you managing this? i am using Vera as a controller
                    • J JCH
                      Hi
                      sundberg84S
                      sundberg84S
                      @jch I made this just because the standard sketch didn't work with domoticz. The example sketch should work with Vera. It's been a long time now since I made this so thing might changed.
                      • J
                        J
                        JCH
                        Ok thanks for the reply.... I was only wanting to use your sketch as my node is battery powered and the mysensors example uses a lot of power as it doesn't sleep.
                        I will try and modify it.
