  3. 5v vs. 3.3v Pro Mini battery powered nodes
35 Posts 7 Posters 9.7k Views 6 Watching
  • M mhkid
    @zboblamont - interesting thought on the pump pressure switch. It's not a dedicated water supply. I'm in an irrigation district and the line is pressurized by their pump which is pumping from a canal. It does go down at times and then one of my neighbors or I have to call and alert them to come out and get it going. Yes you would think they would have some sort of alarm on their system but apparently they don't. I use the water for watering lawn, pasture, and just added the filtering so I could water my animals. I may end up with more than one flow meter so I can measure water consumption in each pen. These are show animals and water consumption is important as it relates to nutrition and weight gain.
    zboblamontZ
    zboblamontZ
    zboblamont
    @mhkid Ok, so the pressure monitoring is to alert for pump supply failure, a refurbed single pump pressure controller could easily control a submarine dive klaxon on a big battery, or maybe just trip an Arduino interrupt to radio in, as not sure 3am 130dB klaxon alarms would go down too well with the chickens let alone the family...
    For meters, I would seriously reconsider the notion of using a turbine meter, they MUST be powered continuously.
    Standard apartment meters with a K10 pulse output (every 10 litres) might cost 30-50 GBP depending on where you buy them, the meter will continue to register even if you lost all power, the turbine will not. A box/cupboard to house the meter and however many others you envisage manifolding off will protect them, insulated if you experience frosts, in a heated room in you get -20s...
    If you need to get down to 1 litre pulses, they are less common but not silly money unless going for Class D or Magflow...
    So getting back to your OP, you only need one voltage for the Arduino if you ditch the turbine idea...
    As the Limerick Man explained to the motorist asking directions to Dublin... "Well I wouldn't start from here..."
    https://www.amazon.co.uk/15mm-Water-Meter-Pulse-Output/dp/B0078NMBX6
    • M mhkid
      What are the thoughts on running 5v vs 3.3v pro mini's for battery powered nodes? For sensors that need 5v are you running a 3.3v and stepping up to 5v or running a 5v and stepping down for the radio? Also for 5v pro mini's are you running 4AA batteries or doing a 9v battery or something else?
      tochinet
      @mhkid For battery powered sensors, you should always try to go 3V3. And if necessary change the model of sensor. At 3V3 the consumption is lower as well, so you win twice the energy (very roughly). Your device should also sleep continuously between the sensor captures. It can become tricky. But I used a DHT22+328p+TI CC RF sensor powered by 3V3 on a single AA cell and up-converter for 5 years now, and I only need to recharge it every 4-6 month.
        MaAh
        A video here https://www.youtube.com/watch?v=kEkD4SLMX8Y on some different ways to power the Pro Mini
        • alexsh1A
          alexsh1A
          alexsh1
          There are no thoughts. Just get 3.3v pro mini.
          Generally speaking for any low consumption (battery driven nodes), try to get rid of 5v devices (chips or sensors). I have moved completely to 3.3v almost without regulators with exception of the solar /supercap node.
          • alexsh1A alexsh1
            mhkid
            @alexsh1 like I said of course it would be preferred to use the 3v sensors but that's not always possible. My question is more about what are people doing when they are using a battery powered node with a 5v sensor.
            alexsh1A 1 Reply Last reply
            • T tochinet
              mhkid
              @tochinet Do have diagrams, pictures and sketches you've posted?
              • M MaAh
                mhkid
                @maah This video doesn't show different ways to power an arduino it's talking about power consumption. I'm already removing the regulator, LED and sleeping it. I'm more asking about battery powered nodes with sensors than are more than 3.3v. How are people feeding 5v to these sensors?
                • M mhkid
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @mhkid replace the sensor. If you cannot replace the sensor, you have several options:
                  1. use 5v pro mini + 3xAA batteries + 5v sensor.
                    This is going to be a very power hungry setup.
                  2. use 3.3v pro mini + level shifter + 3xAA batteries + 5v sensor
                    Again this setup now ideal - you have to drop voltage from 5v to 3.3v
                  I still have several old 5v sensors I used with Arduino Uno. I am just not using them any longer with one exceptions when a node is powered from mains.
                  • alexsh1A alexsh1
                    mhkid
                    wrote on last edited by mhkid
                    #23
                    @alexsh1 Which sensor should I replace the water pressure sensor with?
                    https://www.amazon.com/dp/B00RCPDCQU/ref=twister_B00RCPDQOI?_encoding=UTF8&psc=1&tag=wwwmysensorso-20
                    zboblamontZ alexsh1A 2 Replies Last reply
                    • M mhkid
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      #24
                      @mhkid IF the objective is only to detect supply pressure failure rather than monitor pressure over time for process reasons, why not use a pressure switch set between max supply pressure and Zero? Your processor sleeps until the switch detects a fall in pressure and wakens the processor to call home ?
                      https://www.ebay.com/itm/1-8-QPM11-NC-Pressure-Switch-Wire-External-Thread-Nozzle-Adjustable/272843081265?hash=item3f86b70631:g:iJcAAOSwKnVZtrP~ Perhaps ?
                      There are undoubtedly plenty of other alternatives, on the expensive side there is always RS etc....
                      • M mhkid
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @mhkid I cannot see the consumption. Do you have the datasheet?
                        Most likely this is not a battery friendly sensor. In this case you stil can use it via a step up converter and TPL5110, which will switchit off completely while sleeping
                        • alexsh1A alexsh1
                          #26
                          @alexsh1 it is a mechanical switch, just like a button or reed switch.
                          https://www.google.nl/url?sa=t&source=web&rct=j&url=http://www.cneni.com/cn/file.asp%3FFilename%3Dupload/products/download/2009_10_29_16_27_30_150570.pdf&ved=2ahUKEwjZgbb605LcAhWG-qQKHXHjC6YQFjAOegQIABAB&usg=AOvVaw2MqIOPIURwEs_sa7VMGGoi
                          @zboblamont nice find :+1:
                          • YveauxY Yveaux
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @yveaux Maximum operating current - 500mA. It depends how often the pressure is going to change, but one can pretty much forget about batteries as the source of power.
                              mhkid
                              Thanks for all the suggestions and replies. I'll take all the info, weigh the options and then report back on what I end up doing.
                              • M mhkid
                                alexsh1A
                                alexsh1A
                                alexsh1
                                #29
                                @mhkid Another option for you is using TPL5110 module:
                                https://www.adafruit.com/product/3435
                                I have just received one today and going to tinker with it.
                                To me it seems like a good idea to have a powerful sensors with Arduino on batteries.
                                • alexsh1A alexsh1
                                  mhkid
                                  @alexsh1 - Thanks for the suggestion. I'll be curious to hear what you think of the TPL5110.
                                  • alexsh1A alexsh1
                                    @alexsh1 look at the schematic; it is just a mechanical switch with 2 wires. It can probably only carry 500ma max.
                                    • YveauxY Yveaux
                                      zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @yveaux Are you sure you are not talking at crossed purposes about different devices? The device @mhkid was originally referring to is the one with the 5v supply requirement, Circuit hopefully below.
                                      ![alt text](0_1531239680875_7236a740-cfd0-4c19-8588-6b03d7b5ffd9-image.png image url)
                                      The one I suggested as a low pressure alarm actuator was a variable pressure switch, which may be the one you are referring to...
                                      • zboblamontZ zboblamont
                                        @zboblamont Mine is a lot simpler :laughing:
                                        @alexsh1 Mea culpa, too many crosslinked discussions; apparently I lost track.
                                        Still, I like your sensor better @zboblamont
                                        • YveauxY Yveaux
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @yveaux My suggestion is very simple. If there is a device which consumes more than > 5-50uA sleeping on a battery powered node, it has to be completely disconnected while sleeping. This is where TPL5110 comes in. Obviously if an interrupt is used it does not work
