  3. Sensor taking the status of a blinking led of an alarm system
19 Posts 6 Posters 8.1k Views 3 Watching
  • M Meister_Petz
    Many Thanks for the code, I will start to play around asap ;-)
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @Meister_Petz
    OK, just check the edit... so it is not banging away at your gateway!!!
      Meister_Petz
      wrote on last edited by Meister_Petz
      btw, thats was my working apporach before:
      is there a nice way to add code? Do I really have to add 4 spaces before every line?
      • daulagariD
        daulagariD
        daulagari
        Yes, that is the way to format code.
        But ... knowing some tools there is no need to do it by hand. In vi/vim:
        :%s/^/    /
        hekH 1 Reply Last reply
        • daulagariD daulagari
          :%s/^/    /
          wrote on last edited by hek
          @daulagari
          or just surround code-block with 3 backtick-characters. This character ----> `
          #include <hehe.h>
          printf();
          • M Meister_Petz
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @Meister_Petz
            or in your arduino editor, just grab all the code (CTRL+A) and then increase indent twice... on my mack it is (COMMAND+ ]) That moves all the code right four spaces... see below:
              Meister_Petz
              MANY THANKS!
              That is what I did until now without Millis and interupts,...
              In this code I determine blinks by the difference between 2 following readings. Is there a better way?
              And I simplified the message sent to the gateway quite a bit. Do I produce any errors with this?
                /* Small sketch to determine the State of a Olympia Protect Alarmsystem
                0. When UNARMED   : LED off - DISPLAY off
                1. When ARMED     : LED blinks
                2. When ACTIVATING: LED blinks - DISPLAY blinks (check if before State was ARMED)
                3. When TRIGGERED : LED blinks - DISPLAY blinks (check if before State was ARMED)
                #define CHILD_ID 3
                const int phCell1Pin = 0; // Photocell 1 on PIN 0 - Display
                const int phCell2Pin = 1; // Photocell 2 on PIN 1 - LED
                const int phCell1Sensitivity = 100; // sets the minimum difference between two readings to determine blinking of Display
                const int phCell2Sensitivity = 100; // sets the minimum difference between two readings to determine blinking of LED
                const int sleepTime = 7000; // 7 Sec. between Reading Cycles
                int armingTime = 30; // Seconds set until arming is done
                int DisplayState = 0;
                int LEDState = 0;
                int AlarmSystemState = 4; // (0 = Off, 1 = On, 2 = Activating, 3 = Triggered)
                int AlarmSystemStateOld = 0;
                int myRound1[10] = {0,0,0,0,0,0,0,0,0,0}; // Array to store Readings
                int myRound2[10] = {0,0,0,0,0,0,0,0,0,0}; // Array to store Readings
                int goSleep = 0;
                int i = 0;
                int i1 = 0;
                int i2 = 0;
                void setup(void) {
                  gw.begin();
                  gw.present(CHILD_ID, S_DOOR);
                void loop(void) {
                     if (i < 10){ // 10 Readings
                       myRound1[i] = analogRead(phCell1Pin); // read Photosensor Display
                       //Serial.print("Display PhCell:"); Serial.println(myRound1[i]);
                       myRound2[i] = analogRead(phCell2Pin); // read Photosensor LED
                       //Serial.print("LED     PhCell:"); Serial.println(myRound2[i]);
                       if (i > 0){ // compare 2 following readings
                         // Display
                         if ((myRound1[i] - myRound1[i-1]) > phCell1Sensitivity){i1++;}
                         if ((myRound1[i-1] - myRound1[i]) > phCell1Sensitivity){i1++;}
                         // LED
                         if ((myRound2[i] - myRound2[i-1]) > phCell2Sensitivity){i2++;}
                         if ((myRound2[i-1] - myRound2[i]) > phCell2Sensitivity){i2++;}
                       i++;
                       // Display
                       if (i1 > 2){ // if there are more than 3 Readings which are assumed blinks - set DisplayState to blink
                         DisplayState = 1; //Serial.println("Display blinkt - State 1");
                         DisplayState = 0; // Serial.println("Display dunkel - State 0");
                       //LED
                       if (i2 > 2){ // if there are more than 3 Readings which are assumed blinks - set LEDState to blink
                         LEDState = 1; //Serial.println("LED blinkt - State 1");
                         LEDState = 0; // Serial.println("LED dunkel - State 0");
                       goSleep = 1; // now transmit if necessary and wait before starting again
                       // Reset
                       i = 0;
                       i1 = 0;
                       i2 = 0;
                     // send to Sleep
                     if (goSleep == 1){
                       if (DisplayState == 0 && LEDState == 0){
                         AlarmSystemState = 0; // OFF
                       } else if (DisplayState == 0 && LEDState == 1){
                         AlarmSystemState = 1; // ON
                       } else if (DisplayState == 1 && LEDState == 1 && AlarmSystemStateOld == 0){
                         AlarmSystemState = 2; // Actviating
                         //delay(70000); // wait 70 Seconds until Activating is done
                       } else if (DisplayState == 1 && LEDState == 1 && AlarmSystemStateOld == 1){
                         AlarmSystemState = 3; // TRIGGERED
                        AlarmSystemState = AlarmSystemStateOld;
                       // Send State change to Gateway
                       //Serial.print("AlarmSystemState Änderung:");Serial.println(AlarmSystemState);
                       gw.send(msg.set(AlarmSystemState));
                       if (AlarmSystemState == 2){ // Delay until Arming is done before next read
                         armingTime = (armingTime * 1000)+1000;
                         delay(armingTime);
                       AlarmSystemStateOld = AlarmSystemState;
                       delay(sleepTime);
                       goSleep = 0;
                       delay(575);
              • T
                Tibus
                @BulldogLowell said:
                if you need it to run on battery, then you may not want to bother with sleep, since you are looking for the non-occurrence of something.
                the interrupt method will wake the MCU every time the led flashes...
                you could start with code like this (untested):
                why not use sleep. Yes it will wake the MCU every time the led flashes but it 'll consume less power when it sleep. you can go from 7ma to 10ua when it sleep. Even for one seconds it's a benefit no?
                • brettzky84B
                  brettzky84B
                  brettzky84
                  Why not measure when there is voltage to the led??? Much more reliable and simple
                  • T Tibus
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @Tibus said:
                    why not use sleep.
                    you are correct, of course. I look at it as a two step approach:
                    1. get it to work
                    2. get it to work better than before
                      Meister_Petz
                      @Tibus
                      I agree about sleeping. But for one thing I don't have the slightest clue how working with interupts works (yet) and the Arduino is hook on the power of the Alarmsystem ;-)
                      BTW my Alarmsystem Powersupply produces 6V. Would it make more sense to use a 5V Step Down Regulator and give power to pin 27 (5V) than 6V to PIN 30 (VIN)?
                      Many Thanks
                      Petz
                      • M Meister_Petz
                        @Tibus
                        Many Thanks
                        Petz
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @Meister_Petz
                        Pro-Mini? I'd just take the 6V to the RAW pin.
                        6V to Vin on a nano.
                          Meister_Petz
                          Nano - so VIN! Thanks!
