  2. Announcements
  3. MySensors 2.3.0 released
27 Posts 13 Posters 13.5k Views 15 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    Perfect!!! Thanks for the update!
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • pepsonP
      pepsonP
      pepson
      wrote on last edited by pepson
      Version 2.3.0 has very big problem with communication on radio RFM69HW.
      On version 2.2.0 the same configuration and parameters has no problem. Works perfect.
      Now i can not use 2.3.0 with RFM69HW. Please help and correct this problem.
      I use gateway on RPI3. I updated gateway to 2.3.0 but it no working with nodes with version 2.3.0
      Also problem is when on Gateway and Nodes has the same version 2.3.0
      For me on radio RFM69HW only works correct on version 2.2.0
        mirikbb
        please, how to update version 2.2.0 to 2.3.0 on Raspberry pi?
        Thank you.
        • M mirikbb
          Thank you.
          @mirikbb either delete the MySensors folder and start from the beginning, or do git pull inside the MySensors folder and start from the build step.
          • E
            E
            eric007
            wrote on last edited by eric007
            I set the update, but now i've some issues.
            I can't edit and manage switches anymore:
            as soon i click on edit i have this word "undefined" .and that's all.
            i can't set timers too.
            I tryed this:
            My installation was pretty simple , so i stoped domoticz serveur , removed domoticz folder and proceeded to an fresh install.
            Problems are still present.
            log don't say anything.
            so, anyone have a clue ?
            thank
            Eric.
            here what i get when i click on edit:
            • E eric007
              I tryed this:
              thank
              Eric.
              @eric007 I don't see how MySensors can cause that problem. Looks like something with Domoticz. Have you tried rolling back to the latest stable Domoticz version?
              E 1 Reply Last reply
                E
                E
                eric007
                @mfalkvidd you'r right, i was in a hurry , so i forgoted using my brain!!
                the update was with domoticz and i have to check this way.
                Thank.
                M 2 Replies Last reply
                • E eric007
                  Thank.
                  mirikbb
                  @eric007
                  I have the same problem. It is related to Domoticz update sice today afternoon where some of the sensors started to show like undefined. This has nothing to do with Mysensors 2.3.0 update.
                  • E eric007
                    Thank.
                    mirikbb
                    @eric007
                    The problem is in browser's cache was not refreshed after the update. For Firefox browser clear Cache and Site Data (Options->Privacy&Security->Clear History->Cache+Offline WebSite Data)
                    then reload window. The message "refreshing cache" should appear on Domoticz page, right up side corner.
                    The graphs should then display normally. Without clearing the cache you can see the normal Domoticz graphs in new private Firefox window or other browser.
                    • I
                      I
                      itbeyond
                      Hum I am not sure what the deal is here but I have spent the last two days updating and then removing 2.3.0 from Gateways and Repeaters. It completely trashed my 22 node network. I still have some 2.3.0 nodes running but if I installed 2.3.0 and setup #define MY_REPEATER_FEATURE my nodes would crash within about 30 mins of booting. Also on the gateway the through-put of the radio RF24 died to a crawl. I was trying to OTA my nodes and they were going line by line for about 60mins or more each (MYSController). I simply went back to 2.2.0 on Ethernet Gateway made NO other configuration changes and the nodes flashed in less than a minute each.
                      Since removing 2.3.0 from gateway and repeaters the whole network appears to have stabilised again.
                      • AnticimexA Anticimex
                        Changelog: https://github.com/mysensors/MySensors/releases/tag/2.3.0
                        Thanks to all GitHub users who contributed to this release:
                        d00616
                        flopp999
                        Kartik Arora
                        kvoit
                        Marcelo Aquino
                        Marco Bakera
                        Martin Hjelmare
                        Mikael Falkvidd
                        Miloslav Kazda
                        Patrick Fallberg
                        per1234
                        seeers
                        tekka
                        thucar
                        Tombula
                        pvojP
                        pvojP
                        pvoj
                        wrote on last edited by pvoj
                        Thank you for your great work on this project. It is the best project for most of us to build a cheap and reliable wireless iot network.
                        I am stuck at version 1.5 with my home network. I have several repeaters and even more nodes. I have some quite complex nodes so I decided to make the version update slowly. My system can't be stopped for days.
                        I plan to operate the 1.5 and the 2.3 network parallel and change the nodes one by one.
                        The system runs on Domoticz using a serial gateway. First I will add a new serial gateway (2.3) and I will start to migrate the nodes.
                        Can I keep the node_ids in Domoticz to keep the controller-side scripts unchanged?
                        Can you suggest the best way to migrate everything?
                        tbowmoT 1 Reply Last reply
                        • pepsonP
                          pepsonP
                          pepson
                          With released 2.3.0 is many problem with communication on radio RFM69HW. On 2.2.0 this problem is no available.
                          • pvojP pvoj
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @pvoj Domoticz will reassign internal sensor id's to each sensor it sees on the new gateway.
                            One way could be to use nodered in front of domoticz, and create some basic mysensors dual gateway routing, so domoticz only sees one gateway. I did this when I was running domoticz as controller. (I have now switched completely to nodered).
                              mirikbb
                              please, how to revert from v2.3 to 2.2 on rpi? I started to have a problem with stability/freezing of my raspberry pi 3 after installing v 2.3, and I am not sure if it has something to do with new Mysensors v2.3. I need to elaborate a bit but I don't know how to use Git clone to get older version. I have no skills with git.
                              Many thanx.
                              • M mirikbb
                                Many thanx.
                                @mirikbb you can download all versions from https://www.mysensors.org/download
                                cadetC 1 Reply Last reply
                                  cadetC
                                  cadetC
                                  cadet
                                  Hi
                                  I have MSGW 2.1.0 version on arduino
                                  today I was install RPi3 MSGW 2.3.0
                                  Can I work with sensors 2.1.0 or need to upgrade all ?
                                  Thank you
                                  • cadetC cadet
                                    Hi
                                    Thank you
                                    cadetC
                                    cadetC
                                    cadet
                                    wrote on last edited by cadet
                                    Please modify source !!!!! 2.1.1 2.2.0 2.3.0
                                    anvil 2 years ago
                                    Solved - user error 🙂
                                    Inside the Raspberry Pi setup (file /MySensors/examples_linux/mysgw.cpp), the inclusion mode define must be added:
                                    This is present in the Serial & Ethernet gateway example ino files, just missing from the Raspberry Pi version as it is on GitHub.
                                    With this added, the response to the StartInclusion mode request is then received & everything is fine:
                                    TX(fromController) 0;0;3;0;5;1
                                    RX(fromRaspberryPiGateway) 0;255;3;0;5;1
                                    On the plus side, by working this out I'm a lot more familiar with the workings of MySensors!
                                    Cheers!
                                    • cadetC cadet
                                      anvil 2 years ago
                                      Cheers!
                                      @cadet looks like it is already present: https://github.com/mysensors/MySensors/blob/master/examples_linux/mysgw.cpp#L73
                                      Or am I missing something?
                                        cadetC
                                        cadetC
                                        cadet
                                        @mfalkvidd ok its present
                                        But I spend two days to find it
                                        • F
                                          F
                                          flopp
                                          wrote on last edited by flopp
                                          #23
                                          I finally took my time to update my Serial GW from 2.2.0 to 2.3.0.
                                          Nothing came in from my nodes after I update.
                                          I have nodes with 2.1.1 and 2.2.0.
                                          Is there anything that I should change for update from 2.2.0 to 2.3.0, any settings in config?
                                          Went back to 2.2.0 and immediately data came in from my nodes.
                                          F 1 Reply Last reply
