  3. Make node look for new/better parent without restarting
8 Posts 4 Posters 2.3k Views 4 Watching
  • H
    H
    Henrik Nielsen
    Hi
    In my MySensors network I have a ESP8288 MQTT gateway and two repeaters and a number of sensor nodes. One of these are a button-node that I like to move around in my house. This means that sometimes I move it from one end of the house to the other, so it can no longer connect to the parent node it used to use. I know how to request an acknowledgement in the send method so I can resend the button-press-message, but is there a way to "give up" a parent node after a number of failed transmissions, and broadcast for a new one?
    I know I can do this by pulling the battery and restarting the node, but I'd rather it just do it by itself :)
    mfalkviddM berkseoB 2 Replies Last reply
    • H Henrik Nielsen
      Hi
      @henrik-nielsen welcome to the forum!
      I am not sure, but I think calling transportCheckUplink(true) before sending the message will verify connection to the gateway, and establish new parent if needed. Could you try it?
      • H
        H
        Henrik Nielsen
        It sort of works, I get a ping and a missing pong:
        (254 is button node, 252 is repeater I turned off after the button node was started up)
        64442 TSF:PNG:SEND,TO=252
        64479 !TSF:MSG:SEND,254-254-252-252,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
        66488 TSF:CKU:FAIL
        But no looking for a new parent.
        I tried calling some functions I thought sounded like they would help me, without really knowing. I guess it is not functions that a user like me really should use?:
        if ( !transportCheckUplink() ) {
          stParentTransition();
          while ( isTransportSearchingParent() ) {
            stParentUpdate();
        This starts what appears to be a new parent search, but it never completes:
        151171 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        153180 !TSM:FPAR:NO REPLY
        153182 TSM:FPAR
        153219 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        155228 !TSM:FPAR:NO REPLY
        155230 TSM:FPAR
        155267 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        157276 !TSM:FPAR:NO REPLY
        157278 TSM:FPAR
        157315 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        159324 !TSM:FPAR:FAIL
        159326 TSM:FAIL:CNT=7
        159328 TSM:FAIL:DIS
        159330 TSF:TDI:TSL
        161333 !TSM:FPAR:NO REPLY
        161335 TSM:FPAR
        At this point I have started my repeater again, and I think it should also find either the gateway or another node.
        • H Henrik Nielsen
          66488 TSF:CKU:FAIL
              stParentUpdate();
          153182 TSM:FPAR
          155230 TSM:FPAR
          157278 TSM:FPAR
          159328 TSM:FAIL:DIS
          159330 TSF:TDI:TSL
          161335 TSM:FPAR
          @henrik-nielsen nice work. I am not sure about the internal functions. Pinging @tekka, maybe he can assist.
          • H
            H
            Henrik Nielsen
            I guess another way would be like this:
               asm volatile ("  jmp 0"); // CRASH, BURN AND RESET
            It does the trick ... though it really bothers my developer-heart ;)
            tekkaT 1 Reply Last reply
            • H Henrik Nielsen
              tekkaT
              tekkaT
              tekka
              @henrik-nielsen By default, a new parent it searched after 5 (regular node) or 10 (repeater) failed uplink transmissions - alternatively, you can be more restrictive, by setting MY_TRANSPORT_MAX_TX_FAILURES to anything smaller.
              • H Henrik Nielsen
                Hi
                berkseoB
                berkseoB
                berkseo
                @henrik-nielsen said in Make node look for new/better parent without restarting:
                It's part of my code, ... roughly so
                void check_parent() {
                  _transportSM.findingParentNode = true;
                  CORE_DEBUG(PSTR("MyS: SEND FIND PARENT REQUEST, WAIT RESPONSE\n"));
                  tx_led ();
                  _sendRoute(build(_msg, 255, NODE_SENSOR_ID, 3, 7).set(""));
                  wait(2000, 3, 8);
                  if (_msg.sensor == 255) {
                    if (mGetCommand(_msg) == 3) {
                      if (_msg.type == 8) {
                        Ack_FP = 1;
                        CORE_DEBUG(PSTR("MyS: PARENT RESPONSE FOUND\n"));
                  if (Ack_FP == 1) {
                    CORE_DEBUG(PSTR("MyS: FIND PARENT PROCESS\n"));
                    rx_led ();
                    Ack_FP = 0;
                    transportSwitchSM(stParent);
                    flag_nogateway_mode = 0;
                    flag_find_parent_process = 1;
                    CORE_DEBUG(PSTR("MyS: STANDART TRANSPORT MODE IS RESTORED\n"));
                    bc_led ();
                    _transportSM.findingParentNode = false;
                    CORE_DEBUG(PSTR("MyS: PARENT RESPONSE NOT FOUND\n"));
                    _transportSM.failedUplinkTransmissions = 0;
                    fp_timer = millis();
                • H
                  H
                  Henrik Nielsen
                  Sorry I haven't gotten back to you, been a busy week.
                  The MY_TRANSPORT_MAX_TX_FAILURES seems to do the job perfectly, I adjusted it down to 1 for the node, and resend the message a couple of times if it fails.
                  Thank you for your support :)
                  Also thanks to berkseo, your code also works for me, but I do prefer the built in way now that I know of it. Less code for me to write and maintain :)
