  3. 💬 Insulated Whole House Fan
mysensorswhole house fan
72 Posts 11 Posters 23.4k Views 11 Watching
  • L lis610
    I am using 5V power supply and testing sensor with DHT example. DHT is working with MEGA power by 3.3 or 5 v. Maybe it is not working because of Pro Mini 8MHz?
    petewillP
    petewillP
    petewill
    @lis610 It should work at 8MHz. Have you double checked the wiring? Did you try with the default sketch in the DHT library? What are the debug messages saying?
    • L lis610
      chisightC
      chisightC
      chisight
      @lis610 DHT22 being a "one wire" protocol, are timing dependent. Make sure that you have defined #define F_CPU 8000000L or have selected the 8mhz option in the newer versions of the IDE. If #define F_CPU gives you an error, you have to do it in the IDE.
      Are you using the Adafruit DHT library? Which version? To double check that your CPU frequency is correct, create a new sketch with the following:
        pinMode(13, OUTPUT);
        digitalWrite(13,HIGH);
        delay(10000);
        digitalWrite(13,LOW);
        delay(10000);
      Then time the speed of the blinks. it should be 10 seconds on and 10 seconds off. if you're getting 20 seconds on and 20 seconds off, your F_CPU is wrong.
      See me on IRC at ircs://freenode:6697/##nodered and ircs://freenode:6697/#mysensors
      • L
        L
        lis610
        Thank you, guys.
        Got the DHT working! Next step connect motor and fan, fingers crossed :)
        chisightC 1 Reply Last reply
        • L lis610
          Thank you, guys.
          chisightC
          chisightC
          chisight
          @lis610 you can't just leave us hanging and say "it's working", tell us what the problem was. Was it wiring, was it the 8mhz, was it a wrong library setting, was it a bad sensor? What did you do to make it work? The next person will want to know because they could have the same issue and it teaches the rest of us which troubleshooting tips are working.
          • L
            L
            lis610
            In the beginning, I connected the DHT sensor to Pro Mini A0 and separate power supply (5V) and ran DHT Example sketch and eading was "nan". Want to mention that all other wires (FAN setup ) attached to Pro Mini as well. Then I disconnect Pro Mini from setup and connect DHT to it (GND, VCC, and A0) got numbers by running DHT Example. Connect everything together (motor, display, radio) and connect DHT to Pro Mini (GND, VCC, and A0) turn on and got zeros for Temp and Hum. Got frustrated and left for a walk. When I come back, Temp: 85 and Hum 52. I was not patient enough. It takes 5 to 6 min for Temp to show on display. I also tried to connect DHT VCC to the external power supply 3.3 and 5 V, but leave GND connected to Pro Mini and it works.
            • L
              L
              lis610
              Finish! Thank you for all your help!
              0_1533177411968_91c3b0fa-87ff-4514-811c-ffa101bbad98-image.png ![alt text](image url)
              petewillP 1 Reply Last reply
              • L lis610
                petewillP
                petewillP
                petewill
                @lis610 Awesome! Congratulations and great job for not giving up. That was a lot to tackle for a first project! Nice enclosure to house everything. Looks way cleaner than mine :)
                • L
                  L
                  lis610
                  Can you add additional code; Close the cover if Fan does not start and display error that fan has no power. Thank you.
                  • L
                    L
                    lis610
                    Display. I used old case from iPod. Sprayed a little red paint and top it with black. Push button at the bottom of the case.0_1533511027712_IMG_4216.JPG
                    • L lis610
                      chisightC
                      chisightC
                      chisight
                      Looks great @lis610 !
                      • L
                        L
                        lis610
                        I am using RCWL-0516 Microwave Radar Sensor for on/off the display. This sensor is very sensitive. I just want to activate the display in a close range. Any suggestions?
                        chisightC T H 3 Replies Last reply
                        • L lis610
                          chisightC
                          chisightC
                          chisight
                          @lis610 said in 💬 Insulated Whole House Fan:
                          RCWL-0516
                          https://www.rogerclark.net/investigating-a-rcwl-9196-rcwl-0516-radar-motion-detector-modules/ shows some possible ways to read something other than a digital output of motion at 5 to 7 meters.
                          It doesn't look like there is a simple way to just make it less sensitive.
                          • L lis610
                            tsjoender
                            You could try the XYC-WB-DC radar sensor. This one allows the sensitivity to be adjusted by changing a resitor value. Here's a Youtube video about it:
                            https://www.youtube.com/watch?v=41rf6NbuhBs
                            I'm waiting for mine to come in from China, so no first hand experience yet on how these sensors work.
                            • L lis610
                              H
                              H
                              hard-shovel
                              wrote on last edited by hard-shovel
                              #72
                              @lis610 I have found with a 499K resistor the range is reduced to about 1.2m in a ABS box.
                              With a 1Mohm it was about 3m, I do not have many high value SMD resistors to experiment with but the lower the value the lower the range.
                              Just tried with a 333K and it operates about 0.8m in free air.
