  3. Irrigation controller
12 Posts 5 Posters 2.9k Views 4 Watching
  • E erik
    Hi!
    I am using the code at https://blog.m.nu/gastblogg-styrning-av-bevattning-balkonglador/ (swedish page) but can't seem to get it to work. The trick is, I have only one sensor.
    Which parts of the code needs to be altered?
    Pasted code:
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    256
    257
    258
    259
    260
    261
    262
    263
    264
    265
    266
    267
    268
    269
    270
    271
    272
    273
    274
    275
    276
    277
    278
    279
    280
    281
    282
    283
    284
    285
    286
    287
    288
    289
    290
    291
    292
    293
    294
    295
    296
    297
    298
    299
    300
    301
    302
    303
    304
    305
    306
    307
    308
    309
    310
    /* **SKETCH BEGINNING**
    * Version 1.0 - Henrik Ekblad
    * Example sketch showing how to control physical relays.
    * This example will remember relay state after power failure.
    * http://www.mysensors.org/build/relay
    //Network
    #define MY_NODE_ID 8 // I have hardcoded the ID
    #define MY_PARENT_NODE_ID 0 // I have hardcoded the gateway
    #define MY_RADIO_NRF24 //What type of radio
    #define MY_RF24_PA_LEVEL RF24_PA_MAX //The radio is one with antenna so we must set this to max
    //Signing makes everything secure. Arduino must be prepared before according to mysensors.org
    #define MY_SIGNING_SOFT
    //Includes
    #include <SI7021.h>
    #include <RunningAverage.h>
    //Define Relay
    #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_3 5 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 3 // Total number of attached relays
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    #define RELEASE "1.4"
    //Define Moisture things
    #define AVERAGES 2 //we use 2 readings to smooth the readings
    #define STABILIZATION_TIME 1000 // Let the sensor stabilize before reading
    //Change direction on moisture could help with corrosion
    byte direction = 0;
    //Moisture sensor pins
    const int SENSOR_ANALOG_PINS[] = {A0, A1}; // Sensor1 is connected to these two pins.
    const int SENSOR_ANALOG_PINS2[] = {A2, A3}; // Sensor2 is connected to these two pins.
    // Child sensor ID's
    #define CHILD_ID_TEMP 5
    #define CHILD_ID_HUM 6
    #define CHILD_ID_MOISTURE 7
    #define CHILD_ID_MOISTURE2 8
    #define CHILD_ID_BUTTON 9
    #define CHILD_ID_BUTTON2 10
    // How many milli seconds between each measurement of temp and humidity
    #define MEASURE_INTERVAL 30000
    // FORCE_TRANSMIT_INTERVAL, the sensor is forced to report all values to the controller
    #define FORCE_TRANSMIT_INTERVAL 2000 // 20minutes
    // TRANSMIT_THRESHOLD tells how much the humidity/remperature should have changed since last time it was transmitted.
    #define HUMI_TRANSMIT_THRESHOLD 1.0
    #define TEMP_TRANSMIT_THRESHOLD 0.2
    #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
    SI7021 humiditySensor;
    // Sensor messages, here I define different channels where the info is sent
    MyMessage msgMoist(CHILD_ID_MOISTURE, V_HUM);
    MyMessage msgMoist2(CHILD_ID_MOISTURE2, V_HUM);
    MyMessage msgButton(CHILD_ID_BUTTON, V_HUM);
    MyMessage msgButton2(CHILD_ID_BUTTON2, V_HUM);
    MyMessage msgR1(RELAY_1, V_STATUS);
    MyMessage msgR2(RELAY_2, V_STATUS);
    // Global settings
    const unsigned long tUpdateMoist = 3600000; // update interval for the moisture sensor1, 1hour
    const unsigned long tUpdateMoist2 = 3600000; //update interval for the moisture sensor2, 1hour
    unsigned long t1; //defining t1
    unsigned long t2; //defining t2
    int measureCount = 0; //defining measureCount
    boolean isMetric = true;
    boolean highfreq = true; //delete, is probably not needed
    boolean transmission_occured = false; //reset so it starts at false
    // Storage of old measurements, reset them all to 0
    float lastTemperature = -100;
    int lastHumidity = -100;
    int oldMoistureLevel = -1;
    int oldMoistureLevel2 = -1;
    int button = -1;
    int button2 = -1;
    void before()
    for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++)
    pinMode(pin, OUTPUT);
    humiditySensor.begin();
    isMetric = getControllerConfig().isMetric;
    Serial.print(F("isMetric: ")); Serial.println(isMetric);
    raHum.clear();
    t1=millis();
    t2=millis();
    //sendTempHumidityMeasurements(true);
    sendMoistureMeasurements();
    sendMoistureMeasurements2();
    delay(250);
    for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++)
    pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
    digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
    for (int j = 0; j < N_ELEMENTS(SENSOR_ANALOG_PINS2); j++)
    pinMode(SENSOR_ANALOG_PINS2[j], OUTPUT);
    digitalWrite(SENSOR_ANALOG_PINS2[j], LOW);
    sendSketchInfo("RelayTempHumMoist", "1.0");
    present(sensor, S_BINARY,"Relays");
    present(CHILD_ID_TEMP,S_TEMP,"Temperature");
    present(CHILD_ID_HUM,S_HUM,"Humidity");
    present(CHILD_ID_MOISTURE, S_HUM,"Moisture");
    present(CHILD_ID_MOISTURE2, S_HUM,"Moisture2");
    present(CHILD_ID_BUTTON, S_HUM,"Button");
    present(CHILD_ID_BUTTON2, S_HUM,"Button2");
    measureCount ++;
    bool forceTransmit = false;
    if (measureCount > FORCE_TRANSMIT_INTERVAL)
    forceTransmit = true;
    measureCount = 0;
    Serial.print(F("inne i loopen :"));
    if ((millis() - t1) > tUpdateMoist) sendMoistureMeasurements();
    if ((millis() - t2) > tUpdateMoist2) sendMoistureMeasurements2();
    void sendTempHumidityMeasurements(bool force)
    wait(MEASURE_INTERVAL);
    bool tx = force;
    raHum.addValue(data.humidityPercent);
    float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
    Serial.print(F("TempDiff :"));Serial.println(diffTemp);
    Serial.print(F("HumDiff :"));Serial.println(diffHum);
    if (isnan(diffHum)) tx = true;
    if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
    if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
    if (tx)
    measureCount = 0;
    float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
    Serial.print("T: ");Serial.println(temperature);
    Serial.print("H: ");Serial.println(humidity);
    send(msgTemp.set(temperature,1));
    send(msgHum.set(humidity));
    lastHumidity = humidity;
    transmission_occured = true;
    void sendMoistureMeasurements()
    pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP); // Power on the sensor
    analogRead(SENSOR_ANALOG_PINS[direction]);// Read once to let the ADC capacitor start charging
    sleep(STABILIZATION_TIME);
    int moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
    // Turn off the sensor to conserve battery and minimize corrosion
    direction = (direction + 1) % 2; // Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
    // Always send moisture information so the controller sees that the node is alive
    // Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
    // See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
    if (oldMoistureLevel == -1)
    { // First reading, save value
    if (button == 1)
    send(msgButton.set((moistureLevel + oldMoistureLevel + 0.5) / 2 / 10.23, 1));
    t1 = millis();
    Serial.print(F("inne i button :"));
    if (button == 0)
    send(msgMoist.set((moistureLevel + oldMoistureLevel + 0.5) / 2 / 10.23, 1));
    t1 = millis();
    button = 0;
    void sendMoistureMeasurements2()
    pinMode(SENSOR_ANALOG_PINS2[direction], INPUT_PULLUP); // Power on the sensor
    analogRead(SENSOR_ANALOG_PINS2[direction]);// Read once to let the ADC capacitor start charging
    int moistureLevel2 = (1023 - analogRead(SENSOR_ANALOG_PINS2[direction]));
    pinMode(SENSOR_ANALOG_PINS2[direction], OUTPUT);
    digitalWrite(SENSOR_ANALOG_PINS2[direction], LOW);
    if (oldMoistureLevel2 == -1)
    oldMoistureLevel2 = moistureLevel2;
    if (button2 == 1)
    send(msgButton2.set((moistureLevel2 + oldMoistureLevel2 + 0.5) / 2 / 10.23, 1));
    t2 = millis();
    Serial.print(F("inne i button2 :"));
    if (button2 == 0)
    send(msgMoist2.set((moistureLevel2 + oldMoistureLevel2 + 0.5) / 2 / 10.23, 1));
    t2 = millis();
    button2 = 0;
    // Here I can send messages to the node.
    if (message.type==V_STATUS)
    // Change relay state
    // Store state in eeprom
    if (message.type==V_TRIPPED)
    button = 1;
    button2 = 1;
    **SKETCH END** */
    Thanks in advance.
    Cheers,
    Erik
    AnticimexA
    AnticimexA
    Anticimex
    @erik the sketch enables signing. As per the comment, that require the node to be personalized. Have you done that? And configured the gateway accordingly? If you don't want or don't plan to use signing, comment those flags.
    To the blogger (if he reads this): please be more clear on the implications of using security when posting online.
    E 1 Reply Last reply
    • AnticimexA Anticimex
      E
      E
      erik
      @anticimex @mfalkvidd thanks for the replies.
      You mean line 41-43? I'm quite new to this, so even though I have bought and attached a wifi device I plan to start simple. A single sensor and water pump, no signing nor gateway. I do have a raspberry pi available, but haven't bought the required pi radio module from what I understand is required.
      AnticimexA 1 Reply Last reply
      • E erik
        AnticimexA
        AnticimexA
        Anticimex
        @erik everything starting with "MY_SIGNING".
        Running a mysensors node without gateway? I don't think that is possible. The gateway is the interface to whateger controller you use/plan to use.
          E
          E
          erik
          @anticimex gotcha. But the article says that if you want to run without a gateway, just skip the wifi part? Am I missing something here?
          • E erik
            AnticimexA
            AnticimexA
            Anticimex
            @erik I don't know. I am suspicious of the article since it shows a sketch that enables and enforces signing, but does not mention signing at all, so I don't know how many other assumptions are implicitly hidden in the article.
            As far as I know, a atmega328p device has no wifi capability, so it has to use one of the other radios (nrf24, rfm69, etc) to communicate its data to a receiver. That receiver is designated gateway.
            The only other way I can think of is running sensors directly on the gateway and have the gateway then communicate the sensor data using the gateway protocol in whatever transport the gateway has (which might be wifi).
            • alowhumA
              alowhumA
              alowhum
              @erik said in Irrigation controller:
              I don't know if it's useful to you, but here's my sketch. I use it to connect 6 analog capacitive sensors to one Arduino Nano, and also attach 6 LED's (or solenoid valves!) to 6 digital outputs.
              So for example, if plant number 5 is thirsty (<30% moisture), then solenoid 5 will open to give it some water.
               * This node can measure the moisture of 6 different plants. It uses the cheap 'capacitive analog
               * moisture sensor' that you can get for about 3 dollars an Aliexpress or eBay. For example:
               * https://www.aliexpress.com/item/Analog-Capacitive-Soil-Moisture-Sensor-V1-2-Corrosion-Resistant-Z09-Drop-ship/32858273308.html
               * Each plant' moisture value can also be responded to individually, either by turning on an LED (wire that to the plan, and you can see which one is thirsty) or, if you want, per-plant automated irrigation by connecting a little solenoid..
               * Todo: Allow the controller to set the threshold values for each plant individually. Unfortunately, Domoticz doesn't support this yet :-(
              //#define MY_SIGNING_SIMPLE_PASSWD "changeme"           // Useful if your MySensors network is encrypted.
              #define MY_SPLASH_SCREEN_DISABLED                       // saves a little memory.
              //#define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE          // saves a little memory.
              //#define MY_NODE_ID 60                                 // Optional. Sets fixed id with controller.
              //#define MY_PARENT_NODE_ID 0                           // Optional. Sets fixed id for controller.
              //#define MY_PARENT_NODE_IS_STATIC                      // Optional. Sets fixed id for controller.
              #define MY_TRANSPORT_WAIT_READY_MS 10000                // try connecting to the gateway for 10 seconds. Otherwise just continue.
              //#define MY_RADIO_NRF5_ESB
              //#define MY_RADIO_RFM95
              #define MY_RF24_PA_LEVEL RF24_PA_LOW                    // Low power radio setting works better with cheap Chinese radios.
              #define NUMBEROFSENSORS 6                               // How many sensors are connected?
              #define DRYNESSTHRESHOLD 45                             // minimum moisture level that is still ok. A lower value will trigger LED/irrigation.
              #define SLEEPTIME 60                                    // sleep time between the sending of data (in SECONDS). Maximum is 254 seconds. Change "byte" to "int" further down in the code if you want more time between sending updates.
              unsigned long lastTimeChecked = 0;                      // used by the measurement timer.
              MyMessage msg(0, V_LEVEL);                              // used to send data to the gateway
              void before()
                for (byte i = 3; i < NUMBEROFSENSORS + 3; i++){             // Set the LED (or irrigation vales) to their initial position. Because Mysensors uses pin 2, we use pin 3 till 8 as output.
                  pinMode(i, OUTPUT);
                  digitalWrite(i, LOW);
                // send the sketch version information to the gateway and Controller
                sendSketchInfo(F("Plant Sensorium"), F("1.0"));
                // present the sensors
                for (byte i=0; i<NUMBEROFSENSORS ; i++) {
                  present(i, S_MOISTURE); // the last i gives the controller a name, in this case the number of the sensor.
                delay(1000);
                Serial.println(F("Hello world. Warming up the sensors (15 seconds).")); // to avoid weird measurements
                delay(15000);
                static byte measurementCounter = 0;                     // Counts the measurements. Internally the node measures once per second.
                if (millis() - lastTimeChecked > 1000) {
                  lastTimeChecked = millis();
                  Serial.println(F("__________"));
                  for (int i=0; i<NUMBEROFSENSORS; i++) {               // loop over all the sensors.
                    byte shiftedDigitalPin = i + 3;
                    int16_t moistureLevel = (1023-analogRead(i))/10.23;
                    Serial.print(i);
                    Serial.print(F(" mosture level: "));
                    Serial.println(moistureLevel);
                    if(digitalRead(shiftedDigitalPin) == HIGH){                         // outputs the LED/irrigation status via serial. This code can be removed.
                      Serial.print(F("- currently watering until "));
                      Serial.println(DRYNESSTHRESHOLD + 10);
                    if (moistureLevel < DRYNESSTHRESHOLD){              // if the plant doesn' have enough water, turn on the LED/water.
                      Serial.print(F("- moisture level is below "));
                      Serial.println(DRYNESSTHRESHOLD);
                      digitalWrite(shiftedDigitalPin, HIGH);
                    }else if (moistureLevel >= DRYNESSTHRESHOLD + 10){   // turn of the water/led if the plant is wet enough.
                      digitalWrite(shiftedDigitalPin, LOW);
                    if(measurementCounter < NUMBEROFSENSORS){           // During the first 6 seconds the script will send updated data.
                      if(measurementCounter == i){                      // it sends sensor 0 at second 0. Sensor 1 at second 1, etc. This keeps the radio happy.
                        Serial.println(F("- sending data."));
                        send(msg.setSensor(i).set(moistureLevel));
                    if(measurementCounter > SLEEPTIME){ // If enough time has passed, the counter is reset, and new data is sent.
                    }else{
                      measurementCounter++;
              • TmasterT
                TmasterT
                Tmaster
                Erik .if you dont have a gateway or mysensors implemented in your house yet,you should do someting simple.that schetch its crazy for a new start person.
                Some relays that fire by time its enouf. Wifi part that you want provably its realy Wi-Fi,not mysensors conection that its an wireless protocol,(not wifi). We are deep in summer,its not time to make a new irrigation controller from 0 and tryit😋
                i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                • E
                  E
                  erik
                  @Anticimex well the article spawned my interest but not sure at all about assumptions or similar. I kind of just tried to find relevant parts on AliExpress based on the article and started building. I have bought a nrf24 card to connect. How can I modify the code then to just skip the signing and wifi connectivity for now, just to see if this works?
                  @alowhum nice. How do you define which sensors are connected where? Do I need more code than that? Other libraries (doesn't seem so?).
                  @Tmaster not sure what you are saying here, are the wifi sensors not using Wifi?
                  I bought this module: https://www.aliexpress.com/item/nrf24l0-PA-VER2-0-small-size-of-the-module-high-power-wireless-module-long-distance/32458371131.html and attach it through the socket adapter (which turns 3.3V to 5V) https://www.aliexpress.com/item/1pcs-New-Socket-Adapter-plate-Board-for-8Pin-NRF24L01-Wireless-Transceive-module-51/32656317260.html . The Wifi antenna itself I grabbed from an old router I had laying around. Then attached the module according to the article; VCC to a ”5V” block and pin GND to ”5V GND”. The others were connected: CE to 9, CSN to 10, MOSI to 11, MISO to 12 and SCK to 13.
                  Anyway, that is the Wifi module and of course I am interested in getting that to work as well (perhaps with my raspberry pi?), but the immediate goal is to get it to work at all.
                  Appreciate the help people :)
                  • E erik
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @erik to disable signing in the sketch, I already gave you the answer above.
                    • E
                      E
                      erik
                      @Anticimex just tried this, doesn't seem to work.
                      What is the easiest way to debug this? How can I verify that all the components work?
