  3. MySensors Smart Watch
10 Posts 3 Posters 3.8k Views 6 Watching
  • alowhumA
    alowhumA
    alowhum
    After a bit of discussion in the nRF5 thread, it might be useful to create a thread specifically focussed on the subject of re-purposing cheap nRF5 smart watches to use as MySensors nodes.
    Why would I want a MySensors smart watch?
    • If you want a power sipping node with an oled screen and a few sensors.. well you just described a smart watch.
    • From a privacy perspective, most smart watches are horribly designed. A MySensors smart watch could offer the advantages of a smart watch without all the cloud connections and bluetooth tracking risks.
    • It's cool.
    What has been done?
    Surprisingly, quite a bit. Have a look here:
    https://github.com/micooke/arduino-nRF5-smartwatches/
    https://github.com/curtpw/nRF5x-device-reverse-engineering
    https://github.com/goran-mahovlic/nRF51_ID107_libs
    https://github.com/goran-mahovlic/openwatch
    What should I look out for?
    • The holy grail would be a smart watch that can be updated via DFU over the air. That way you don't have to open it, which often destroys any waterproofing. Of course this only matters if you want to actually use it as a watch and not, say, as a small tabletop display.
    • In some of these cheap devices the heart rate and/or blood pressure devices are very poor quality, meaning you will get eratic results.
    • Currently you may need a JLink or Black Magic Probe debugger to gain control over these devices.
    Discussion
    There is a chat here
    Popular devices
    • ID107HR - It's an older NRF51, but the advantage is that the screen has been mapped, the pads are clear, and it can be opened with a small screwdriver. It's your best bet.
    • ID107HR Plus - NRF52 version. The screen doesn't seem to be mapped yet. It's glued shut, and incredibly difficult to open.
    Getting started
    • Get or make a Black Magic probe.
    • Buy an ID107HR (€15 at Gearbest)
    1. Install sandeep's git from https://github.com/sandeepmistry/arduino-nRF5. Do refer to instructions at the bottom of the git to install as a development core (supports Black Magic Probe), i.e. clone/copy repo into 'Arduino/hardware/sandeepmistry/nRF5' folder.
    2. Install ARM Cortex support by installing SAMD boards via Arduino Board Manager interface.
    3. Overwrite the variants files located in your 'Arduino/hardware/sandeepmistry/nRF5/variants/Generic' folder' using the files from https://github.com/rogerclarkmelbourne/arduino-nRF5-customised/tree/master/variants/ID107HR_smartwatch.
    4. Install Goran's git from https://github.com/goran-mahovlic/nRF51_ID107_libs and load up the example sketch of 'SmartyV2ClockOledAcc.ino'.
    5. Select the Board 'Generic nRF51' from the 'Nordic Semiconductor nRF5 Boards' menu. Select the 'Black Magic Probe (GDB)' from the programmer menu. Compile/upload.
    dbemowskD 1 Reply Last reply
    • alowhumA alowhum
      • It's cool.
      What has been done?
      Discussion
      Popular devices
      Getting started
      dbemowskD
      dbemowskD
      @alowhum Do you have any specific brands/models that would work, especially with the Black Magic Probe?
      • alowhumA
        alowhumA
        alowhum
        @alowhum said in MySensors Smart Watch:
        I haven't tried anything myself yet. The ID107HR is your best best. There's a useful guide here.
        • alowhumA
          alowhumA
          alowhum
          My ID107 has arrived. To open the ID107 you will need a tiny star-shaped 6-corner screwdriver. I've successfully opened it and closed it again, no problems there.
          My first goal will be to create an image of the old firmware. But unfortunately I don't have any spare time to work on it right now.
          • alowhumA
            alowhumA
            alowhum
            One of the 2018 Hack-A-Day finalists is a smart watch using the NRF5.
            https://hackaday.io/project/144350-hacking-wearables-for-mental-health-and-more
            They are using it for medical research.
            Here's a video:
            https://www.youtube.com/embed/SmW4Qo9lZ2A
            • alowhumA
              alowhumA
              alowhum
              And it seems there are now watches that can be updated over the air!
              SMA-Q2
              X9-Pro
              More at
              https://wiki.hackerspace.pl/projects:sma-q2
              • alowhumA
                alowhumA
                alowhum
                The ID107HR can also be updated over the air apparently.
                https://github.com/najnesnaj/ota-dfu-smartband
                • alowhumA
                  alowhumA
                  alowhum
                  Pine is making an open source smart watch running on an NRF52:
                  https://www.cnx-software.com/2019/09/15/pinetime-smartwatch-companion-pinephone/
                  Nca78N 1 Reply Last reply
                  • alowhumA alowhum
                    Interesting, the chinese version is using an nrf52832 too so I guess they will not make too many hardware changes if they want to keep the cost reasonable, adding a better capacitive sensor sound like a great improvement.
                    I would bet that the screen is one of the ST7789 IPS LCD that are cheap (2$) on AliExpress and have a really great quality. I'm quite tempted to buy the Chinese watch now :)
                    I'm very tempted to buy the chinese version right away now :)
                    • alowhumA
                      alowhumA
                      alowhum
                      Has anyone bought a PineTime by chance? They are really progressing quickly, with OTA support and everything.
                      12.5k
