  3. AC-DC at own
AC-DC at own
26 Posts 6 Posters 8.2k Views 8 Watching
  • KoreshK Koresh
    @axillent greate work ! It is very hard to order transformers... My congratulations! Can you share the pcb for the review :) ?
    axillentA
    axillentA
    axillent
    @koresh do you mean test pcb?
    sense and drive
    KoreshK 1 Reply Last reply
    • axillentA axillent
      KoreshK
      KoreshK
      Koresh
      @axillent No, I just want to look at it.
      axillentA 1 Reply Last reply
      • KoreshK Koresh
        axillentA
        axillentA
        axillent
        @koresh pcb picture is presented. Please clarify what else you want to see. All is open
        sense and drive
        • KoreshK Koresh
          axillentA
          axillentA
          axillent
          @koresh transformers is not a big deal but selection is very limited. I only found one item with reasonable pricing and sutable parameters. You can find it on ali by name EE10-A1
          sense and drive
            KoreshK
            KoreshK
            Koresh
            @axillent I can't see the gerbers or sources of the latest board (din shape). I've seen your transformers on ali. It is perfect. I need auxiliary coil for my projects so I should place custom order on the factory.
            • KoreshK Koresh
              axillentA
              axillentA
              axillent
              @koresh if you need gerber let me know, i will download. I need to note that DIN is designed for a particular design of the cover
              Share please where it is possible to order customized transformers.
              I do have all things to build transformers myself. It is an alternative way
              sense and drive
              • axillentA
                axillentA
                axillent
                ready
                1_1534706270488_Фото 19.08.2018, 22 02 28.jpg 0_1534706270488_Фото 19.08.2018, 22 02 22.jpg
                sense and drive
                • jeremushkaJ
                  jeremushkaJ
                  jeremushka
                  @axillent said in AC-DC at own:
                  EE10-A1
                  Congratulations! It can replace the HLK-PM01 that we are using a lot here. Is it possible for you to share the schematics ?
                  • jeremushkaJ jeremushka
                    EE10-A1
                    axillentA
                    axillentA
                    axillent
                    @jeremushka for sure
                    schematic is standard, simplified version from datasheet
                    D8, D11 and R22 are optional, it is to be able to source power from different sources (for example different phases, or from main power and from generator).
                    D12 I'm using 11V to have output at about 12.1V
                    sense and drive
                    jeremushkaJ 1 Reply Last reply
                    • jeremushkaJ
                      jeremushkaJ
                      jeremushka
                      Thanks. What is the purpose of the inductor at the output of the circuit? why not to use one also after the bridge rectifier?
                        Everyone is need some kind of power supply for the project. Some time AC-DC is needed.
                        From a few years of hobby I did a following list for myself:
                        1. list item isolated AC-DC
                          1.1 purchased as adapter
                          1.2 purchased in separate box
                          1.3 purchased to be put on PCB
                        2. nonisolated AC-DC
                          2.1 soldered capacitor based
                          2.2 soldered switching inductor less
                          2.3 soldered switching with inductor
                        More or less a coprehensive listm, with proc and cons depending of the project.
                        I prefer to solder things, but you see that I put all isolated as purchased. It is all about transformers.
                        I'm scared about transformers - you need to properly design it, you need to wire it and build.
                        Now I can tell that I do not scared any more)
                        But to simplify start I ordered transformers build for the 5/12V output at power up to 3W. It is best sutable for most of my applications.
                        A testing board was created:
                        soldered and tested:
                        result of test as expected. at 13V output I coould get 3W of power with moderated heating
                        schematic is based on LNK364
                        By next step I will order PCB for my DIN Rail LEGO project:
                        blaceyB
                        blaceyB
                        blacey
                        @axillent - Nice to see you here again! Well done :+1:
                        • blaceyB blacey
                          axillentA
                          axillentA
                          axillent
                          @blacey thanks
                          sense and drive
                            axillentA
                            axillentA
                            axillent
                            @jeremushka said in AC-DC at own:
                            inductor at output is to reduce riple
                            on hight voltage side will be better to put filter but there is no place for it
                            inductor as such will not bring too much value
                            sense and drive
                              jeremushkaJ
                              jeremushkaJ
                              jeremushka
                              @axillent thank you. it is clear information :) very nice work
                                jeremushkaJ
                                jeremushkaJ
                                jeremushka
                                some questions regarding the schematics:
                                1. does TVS diode 600W 5V is efficient enough? or absolutely need cut off at 160V such as 600W 160A ?
                                2. for the Fuse, a slow fuse 10A is enough i think, isn't it?
                                  axillentA
                                  axillentA
                                  axillent
                                  TVS need to be for 120-160V in case you supply 230V AC. You can refer to linkswitch designer for your specific needs.
                                  The purpose of this TVS is to be a snubber because of inductive load. Instead of TVS an RC snubber could be used.
                                  it is 3Watts supply, 0.5-1A slow fuse is fine
                                  sense and drive
                                  jeremushkaJ SuwinS 2 Replies Last reply
                                    jeremushkaJ
                                    jeremushkaJ
                                    jeremushka
                                    Thanks for the answer. i will play with this LNK component. never used it before. I am curious to know the performances of it.
                                    for your design, you have added others functions on your PCB ? such as DC-DC converter ... etc.. ?
                                      axillentA
                                      axillentA
                                      axillent
                                      my DIN desing is universal. it is for the set of different devices with common 12V power
                                      dc-dc is used to feed MCU from 12V
                                      sense and drive
                                      • jeremushkaJ
                                        jeremushkaJ
                                        jeremushka
                                        @axillent, i am designing your board on altium designer. However, i am facing difficulties with the footprint of the transformer. Is it possible to share it or your pcb file?
                                          axillentA
                                          axillentA
                                          axillent
                                          @jeremushka I do have this footprint in altium but the library is big. do you know how to export a single element?
                                          sense and drive
