  3. AC-DC at own
AC-DC at own
26 Posts 6 Posters 8.2k Views 8 Watching
  • jeremushkaJ
    jeremushkaJ
    jeremushka
    Thanks. What is the purpose of the inductor at the output of the circuit? why not to use one also after the bridge rectifier?
    axillentA 1 Reply Last reply
    • axillentA axillent
      Everyone is need some kind of power supply for the project. Some time AC-DC is needed.
      From a few years of hobby I did a following list for myself:
      1. list item isolated AC-DC
        1.1 purchased as adapter
        1.2 purchased in separate box
        1.3 purchased to be put on PCB
      2. nonisolated AC-DC
        2.1 soldered capacitor based
        2.2 soldered switching inductor less
        2.3 soldered switching with inductor
      More or less a coprehensive listm, with proc and cons depending of the project.
      I prefer to solder things, but you see that I put all isolated as purchased. It is all about transformers.
      I'm scared about transformers - you need to properly design it, you need to wire it and build.
      Now I can tell that I do not scared any more)
      But to simplify start I ordered transformers build for the 5/12V output at power up to 3W. It is best sutable for most of my applications.
      A testing board was created:
      soldered and tested:
      result of test as expected. at 13V output I coould get 3W of power with moderated heating
      schematic is based on LNK364
      By next step I will order PCB for my DIN Rail LEGO project:
      blaceyB
      blaceyB
      blacey
      @axillent - Nice to see you here again! Well done :+1:
      • blaceyB blacey
        axillentA
        axillentA
        axillent
        @blacey thanks
        sense and drive
        • jeremushkaJ jeremushka
          axillentA
          axillentA
          axillent
          @jeremushka said in AC-DC at own:
          inductor at output is to reduce riple
          on hight voltage side will be better to put filter but there is no place for it
          inductor as such will not bring too much value
          sense and drive
          jeremushkaJ 1 Reply Last reply
            jeremushkaJ
            jeremushkaJ
            jeremushka
            @axillent thank you. it is clear information :) very nice work
              @jeremushka for sure
              schematic is standard, simplified version from datasheet
              D8, D11 and R22 are optional, it is to be able to source power from different sources (for example different phases, or from main power and from generator).
              D12 I'm using 11V to have output at about 12.1V
              jeremushkaJ
              jeremushkaJ
              jeremushka
              @axillent said in AC-DC at own:
              some questions regarding the schematics:
              1. does TVS diode 600W 5V is efficient enough? or absolutely need cut off at 160V such as 600W 160A ?
              2. for the Fuse, a slow fuse 10A is enough i think, isn't it?
                axillentA
                axillentA
                axillent
                TVS need to be for 120-160V in case you supply 230V AC. You can refer to linkswitch designer for your specific needs.
                The purpose of this TVS is to be a snubber because of inductive load. Instead of TVS an RC snubber could be used.
                it is 3Watts supply, 0.5-1A slow fuse is fine
                sense and drive
                jeremushkaJ SuwinS 2 Replies Last reply
                  jeremushkaJ
                  jeremushkaJ
                  jeremushka
                  Thanks for the answer. i will play with this LNK component. never used it before. I am curious to know the performances of it.
                  for your design, you have added others functions on your PCB ? such as DC-DC converter ... etc.. ?
                    axillentA
                    axillentA
                    axillent
                    my DIN desing is universal. it is for the set of different devices with common 12V power
                    dc-dc is used to feed MCU from 12V
                    sense and drive
                    • jeremushkaJ
                      jeremushkaJ
                      jeremushka
                      @axillent, i am designing your board on altium designer. However, i am facing difficulties with the footprint of the transformer. Is it possible to share it or your pcb file?
                        axillentA
                        axillentA
                        axillent
                        @jeremushka I do have this footprint in altium but the library is big. do you know how to export a single element?
                        sense and drive
                          jeremushkaJ
                          jeremushkaJ
                          jeremushka
                          @axillent yes you are right. Same for me.
                          Usually, what i am doing is to create a project library from Schematic. For that, i open the Schematic. Then Design menu => make a schematic library. All the components and footprint of the Schematic will be copied and integrated. If schematic is huge or some components no need to extract, then i remove the one i don't need from the schematic library. At this end, you may have for example only the transformer component and footprint in the schematic library and you can extract this library for dxternal purpose. It is maybe not the best methodology (i don't know) but it works.
                            SuwinS
                            SuwinS
                            Suwin
                            what is the TVS diode that you are using?????
                              #25
                              Regarding the OP, there's an easier way: if every time you throw out some broken, old, or obsolete gizmo or tool you hold on to just its AC-DC power-supply/charger, pretty soon you'll be up to your eyeballs in power-supplies/chargers and have a lot to choose from when you do a project. With a big enough collection, you'll likely find a match for your project straight away. If not, then in all likelihood all you'll need is just a DC-DC converter, which are cheap (as little as $1 or less for some of them), and there's nothing scary about them.
                              Problem is safely solved for very little time and money. Even better, the AC-DC converter component is probably UL listed, which a purely homespun design won't be.
                              • SuwinS
                                SuwinS
                                Suwin
                                @axillent can you post the pcb file of this project????
