  3. AC-DC at own
AC-DC at own
26 Posts 6 Posters 7.6k Views 8 Watching
  • A Offline
    A Offline
    axillent
    Everyone is need some kind of power supply for the project. Some time AC-DC is needed.
    From a few years of hobby I did a following list for myself:
    1. list item isolated AC-DC
      1.1 purchased as adapter
      1.2 purchased in separate box
      1.3 purchased to be put on PCB
    2. nonisolated AC-DC
      2.1 soldered capacitor based
      2.2 soldered switching inductor less
      2.3 soldered switching with inductor
    More or less a coprehensive listm, with proc and cons depending of the project.
    I prefer to solder things, but you see that I put all isolated as purchased. It is all about transformers.
    I'm scared about transformers - you need to properly design it, you need to wire it and build.
    Now I can tell that I do not scared any more)
    But to simplify start I ordered transformers build for the 5/12V output at power up to 3W. It is best sutable for most of my applications.
    A testing board was created:
    soldered and tested:
    result of test as expected. at 13V output I coould get 3W of power with moderated heating
    schematic is based on LNK364
    By next step I will order PCB for my DIN Rail LEGO project:
    sense and drive
    K B 2 Replies Last reply
    • A axillent
      K Offline
      K Offline
      Koresh
      @axillent greate work ! It is very hard to order transformers... My congratulations! Can you share the pcb for the review :) ?
      A 2 Replies Last reply
      • K Koresh
        A Offline
        A Offline
        axillent
        @koresh do you mean test pcb?
        sense and drive
        K 1 Reply Last reply
        • A axillent
          K Offline
          K Offline
          Koresh
          @axillent No, I just want to look at it.
          A 1 Reply Last reply
          • K Koresh
            A Offline
            A Offline
            axillent
            @koresh pcb picture is presented. Please clarify what else you want to see. All is open
            sense and drive
            • K Koresh
              A Offline
              A Offline
              axillent
              @koresh transformers is not a big deal but selection is very limited. I only found one item with reasonable pricing and sutable parameters. You can find it on ali by name EE10-A1
              sense and drive
              • A axillent
                K Offline
                K Offline
                Koresh
                @axillent I can't see the gerbers or sources of the latest board (din shape). I've seen your transformers on ali. It is perfect. I need auxiliary coil for my projects so I should place custom order on the factory.
                • K Koresh
                  A Offline
                  A Offline
                  axillent
                  @koresh if you need gerber let me know, i will download. I need to note that DIN is designed for a particular design of the cover
                  Share please where it is possible to order customized transformers.
                  I do have all things to build transformers myself. It is an alternative way
                  sense and drive
                  • A Offline
                    A Offline
                    axillent
                    ready
                    1_1534706270488_Фото 19.08.2018, 22 02 28.jpg 0_1534706270488_Фото 19.08.2018, 22 02 22.jpg
                    sense and drive
                    • jeremushkaJ Offline
                      jeremushkaJ Offline
                      jeremushka
                      @axillent said in AC-DC at own:
                      EE10-A1
                      Congratulations! It can replace the HLK-PM01 that we are using a lot here. Is it possible for you to share the schematics ?
                      • jeremushkaJ jeremushka
                        EE10-A1
                        A Offline
                        A Offline
                        axillent
                        @jeremushka for sure
                        schematic is standard, simplified version from datasheet
                        D8, D11 and R22 are optional, it is to be able to source power from different sources (for example different phases, or from main power and from generator).
                        D12 I'm using 11V to have output at about 12.1V
                        sense and drive
                        jeremushkaJ 1 Reply Last reply
                          jeremushkaJ Offline
                          jeremushka
                          Thanks. What is the purpose of the inductor at the output of the circuit? why not to use one also after the bridge rectifier?
                          • A axillent
                            B Offline
                            B Offline
                            blacey
                            @axillent - Nice to see you here again! Well done :+1:
                            • B blacey
                              A Offline
                              A Offline
                              axillent
                              @blacey thanks
                              sense and drive
                                A Offline
                                A Offline
                                axillent
                                @jeremushka said in AC-DC at own:
                                inductor at output is to reduce riple
                                on hight voltage side will be better to put filter but there is no place for it
                                inductor as such will not bring too much value
                                sense and drive
                                • A axillent
                                  jeremushkaJ Offline
                                  jeremushkaJ Offline
                                  jeremushka
                                  @axillent thank you. it is clear information :) very nice work
                                  • A axillent
                                    jeremushkaJ Offline
                                    jeremushkaJ Offline
                                    jeremushka
                                    some questions regarding the schematics:
                                    1. does TVS diode 600W 5V is efficient enough? or absolutely need cut off at 160V such as 600W 160A ?
                                    2. for the Fuse, a slow fuse 10A is enough i think, isn't it?
                                      A Offline
                                      A Offline
                                      axillent
                                      TVS need to be for 120-160V in case you supply 230V AC. You can refer to linkswitch designer for your specific needs.
                                      The purpose of this TVS is to be a snubber because of inductive load. Instead of TVS an RC snubber could be used.
                                      it is 3Watts supply, 0.5-1A slow fuse is fine
                                      sense and drive
                                      jeremushkaJ SuwinS 2 Replies Last reply
                                      • A axillent
                                        jeremushkaJ Offline
                                        jeremushkaJ Offline
                                        jeremushka
                                        Thanks for the answer. i will play with this LNK component. never used it before. I am curious to know the performances of it.
                                        for your design, you have added others functions on your PCB ? such as DC-DC converter ... etc.. ?
                                          A Offline
                                          A Offline
                                          axillent
                                          my DIN desing is universal. it is for the set of different devices with common 12V power
                                          dc-dc is used to feed MCU from 12V
                                          sense and drive
