  3. Is the 32-bit ATSAML10 the ATMEGA328P killer that we've been waiting for?
26 Posts 8 Posters 6.5k Views 9 Watching
    Thanks for pointing that out. :)
    Unfortunately, I see no indication of any Arduino support for it on github, so I guess it's largely moot. As near as I can tell, 32 bit Arduino(ish) options at present are just Arduino Zero, Arduino Due, nRF52, and I guess quite a large number of STM32 boards (https://github.com/stm32duino/Arduino_Core_STM32). Is there anything else, or is that the full set?
    Of the STM32 boards, the three STM32L0 boards would be the low power boards. For instance, the STM32L031K6 board has:
    Ultra-low-power platform
    1.65 V to 3.6 V power supply
    -40 to 125 °C temperature range
    0.25 μA Standby mode (2 wakeup pins)
    0.38 μA Stop mode (16 wakeup lines)
    0.68 μA Stop mode + RTC + 8 KB RAM retention
    Down to 76 μA/MHz in Run mode
    5 μs wakeup time (from Flash memory)
    41 μA 12-bit ADC conversion (at 10ksps)
    which actually sounds like it beats the ATSAML10, at least in terms of power consumption (https://www.st.com/en/microcontrollers/stm32l031k6.html).
    • MiKaM
      MiKaM
      MiKa
      SAMD21G18A is also option for next level of mysensors support ;)
      Check moteino M0 on lowpowerlab site
      • nagelcN
        nagelcN
        nagelc
        I have some STM32L1 chips in my basement which I got and promptly figured out the F1 had arduino support but not the L1. I see that the L1 is supported now. Gonna have to dig those back out.
        It would be interesting to drop it onto this board:
        https://www.openhardware.io/view/590/STM32-Sensor-V3
        NeverDieN F 3 Replies Last reply
        • nagelcN nagelc
          @nagelc Just how Arduino compatible are they? Is it fairly transparent, or do you end up studying the datasheet a lot to workaround incompatibilities?
          nagelcN 1 Reply Last reply
          • nagelcN nagelc
            F
            F
            freynder
            wrote on last edited by freynder
            @nagelc That would be interesting. Remember also that MySensors currently only supports STM32F1 without sleep mode. I'm running a modified version with sleep support, but since I could not make it generic enough, I never submitted it as an enhancement (can be found here: github, 2.2.0 only)
            I still have a few prototype boards available but don't have enough time to progress much in the near future. If you would like a few boards (PCB only, not fully assembled) for experimenting and testing I can send you a few provided shipping costs permit it. I would love to see them better supported. Drop me a PM if interested.
              It looks as though the entire line-up of the STML0 series is ultra low power when it comes to standby current.
              I think I'll be ordering the Discovery board: https://www.digikey.com/product-detail/en/STM32L0538-DISCO/497-14709-ND/4866483/?itemSeq=270107875 to get familiar with these chips.
              [Edit: Well, maybe I'll try the nucleo board instead (https://www.digikey.com/product-detail/en/stmicroelectronics/NUCLEO-L053R8/497-14710-ND/4866484), since it is supported by the stm32duino library. ]
                nagelcN
                nagelcN
                nagelc
                @neverdie Found my STM32L1 chips -- L151C8T6R. Looks like the STM32duino folks have some support for the L152, but don't list the L151, so I'm out of luck with these for now. The L0 and L4 seem to be more supported.
                • F freynder
                  nagelcN
                  nagelcN
                  nagelc
                  @freynder I found MySensors after messing around with Moteino's, so I really like the idea of this board. The RFM69 let me cover my house without repeaters and just worked. Now, the NRF5 series is so amazing, but I admit my personal prejudice -- I keep wishing for something similar for the RFM world.
                  • nagelcN nagelc
                    F
                    F
                    freynder
                    @nagelc said in Is the 32-bit ATSAML10 the ATMEGA328P killer that we've been waiting for?:
                    Are you referring to the official STM32 core provided by STM (github)?
                    AFAIK, MySensors currently only works with the unofficial one from Roger Clark (github) which is much more limited as far as supported mcu families go (good F1 support and limited F4).
                    A nice overview of cores can be found here.
                    YveauxY nagelcN 2 Replies Last reply
                    • F freynder
                      @freynder said in Is the 32-bit ATSAML10 the ATMEGA328P killer that we've been waiting for?:
                      I'm using Blue Pills with stm32duino (https://github.com/stm32duino/Arduino_Core_STM32) and MySensors without problems.
                      Stm32duino also supports a number of STM32L variants.
                      F 1 Reply Last reply
                      • YveauxY Yveaux
                        F
                        F
                        freynder
                        @yveaux I stand corrected. I just tried compiling an example sketch and indeed no errors. Last time I tried I had compilation errors, but that may have been due to other factors then.
                        • F freynder
                          nagelcN
                          nagelcN
                          nagelc
                          @freynder Yes. I had a Blue Pill with RFM69 working from stm32duino, but it has been a while.
                            It seems that blue pills are now cheaper than pro mini's: https://www.aliexpress.com/item/STM32F103C8T6-ARM-STM32-Minimum-System-Development-Board-Module-For-arduino-DIY-KIT-Sensing-Evaluation-for-Skiller/32839140960.html?spm=2114.search0604.3.21.5f1f5d6f9DVrT6&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10344_10068_10130_5724113_10342_10547_10343_5724713_10546_10340_10341_10548_315_10545_10696_5724013_10084_531_10083_10618_5724313_10307_5724213_10059_100031_10103_5725013_10624_10623_10622_10621_10620_5724913,searchweb201603_55,ppcSwitch_7&algo_expid=39b863cc-b9e0-40b1-b7ad-1e800e717f83-6&algo_pvid=39b863cc-b9e0-40b1-b7ad-1e800e717f83&priceBeautifyAB=0
                            You can even put a USB bootloader onto them.
                            gohanG F 2 Replies Last reply
                              @neverdie so will it be able to run mysensors also in sleep mode? I got lost with all those chip codes
                                F
                                F
                                freynder
                                @neverdie said in Is the 32-bit ATSAML10 the ATMEGA328P killer that we've been waiting for?:
                                plus debug using Black Magic Probe or stlink + OpenOCD
                                • F freynder
                                  F
                                  F
                                  freynder
                                  I'm revisiting this as I tried to compile a sketch today using the official STM32 core (https://github.com/stm32duino/Arduino_Core_STM32 v1.3)
                                  I realize now I tested with the wrong core as it is a bit confusing in Arduino IDE. Please see the screenshot below which boards menu should be selected (highlighted the selected board).
                                  0_1535733869475_scrshot.png image url)
                                  When I select this core, the sketch will not compile because the ARDUINO_ARCH_STM32F1 flag is not set.
                                  @Yveaux and @nagelc : can you confirm you actually used this core? The core named "STM32 Boards (stm32duino.com)" is Roger Clarks core, not the official STM32 core one. Easily confused as the github user name for the official STM32 core is stm32duino.
                                  nagelcN YveauxY 2 Replies Last reply
                                  • F freynder
                                    nagelcN
                                    nagelcN
                                    nagelc
                                    @freynder I have changed computers since then, but I suspect you are right. I found it through the STM32duino site, but it didn't look like your screen shot. I don't recall seeing "series" after STM32F103. I can double check when I get home next week.
                                    • F freynder
                                      #23
                                      @freynder This is the one I used on the pills:
                                      And the boards I've got installed:
                                      • YveauxY Yveaux
                                        F
                                        F
                                        freynder
                                        @yveaux and @scalz
                                        Thanks for confirming. So only Clark's core is supported at the moment.
                                        It would be interesting to support the official STM32 core as they provide low power functions. I will do some experiments.
                                          #25
                                          Do any of the STM32's have anything similar to the Nordic nRF52's PPI (Programmable Peripheral Interconnect)? I assumed they would, but I just now went looking for it in the datasheet and didn't find it. Maybe STM32's call it something else? Or do they just not have anything similar? I thought it was a rather cool feature of the nRF52.
                                          H 1 Reply Last reply
