  3. Concept of a flexible but simple smart network
25 Posts 6 Posters 7.3k Views 4 Watching
    If you can find a way to make a "router" between different mysensors networks, you could make many people happy 😁
    dbemowskD
    dbemowskD
    @gohan Wouldn't that be handled in the bridges that he has shown in this image?
    0_1509815372555_upload-c8029759-6a17-4ce1-b04d-3f48014cbd36
    Maybe I am thinking of this wrong, but I would think of it in the sense of a MySensors gateway being the bridge or router that would translate the communication from the local computer network to the different types of devices. Instead of connecting that gateway to a controller like Vera, Domoticz or OpenHAB, it would connect to the IP network. It is basically converting the data from one transmission media such as nRF24L01 or RFM69, over to ethernet.
      you could use bridges but you would need to have unique IDs throughout all the networks if you want nodes to talk to each other across networks, if I understood right.
      dbemowskD 1 Reply Last reply
        dbemowskD
        dbemowskD
        @gohan Wouldn't you need that anyway? How else would you address a node?
        • axillentA
          axillentA
          axillent
          yes, to address devices across different network segments you need a global ID
          but there is a trick... Please see the first picture. It is a layer called Translator.
          it is possible to translate non-global ID to global and back and this will allow to create a bridge
          sense and drive
          • axillentA axillent
            dbemowskD
            dbemowskD
            @axillent Isn't that in a sense a broad definition of what a bridge does? Translating information between two different types of networks.
            axillentA 1 Reply Last reply
            • dbemowskD dbemowsk
              axillentA
              axillentA
              axillent
              @dbemowsk each layer does it's job
              bridge just creates a bridge
              will it do a translation between depends on translation layer
              translation job can be about translation of address or translation of data form or even both
              all this depends on the goal but brings wide flexibility
              sense and drive
              • axillentA
                axillentA
                axillent
                some more details about addressing
                global adress is 16 bit number. 12 most significant bits are defining network segment number while 4 less significant bits are providing nodeID
                section 0xFE00-0xFEFF is reserved for local broadcasting, 0xFF00-0xFFFF - for global broadcasts. Etc. 256 broadcasts of each type
                segments and differenciation between local and global broadcasts are needed for efficient support of bridging and routing.
                bridging is a simplified version of routing. bridging is connecting network segments on different physycal inrterfaces while routing can assume to bypass many physical interfaces between (routing throuth).
                one of the bridge example is a link between wired interface and MQTT.
                one of the routing example is a link between 2 wired interfaces across public Internet
                each network segment can have 15 nodes. nodeID = 0 is a special local segment broadcast addressing all devices in segment.
                each physical interface can have several segments, etc. there is no limitation to have 15 nodes on physical interface. you just add as many segments to interface as you need to have devices
                sense and drive
                • alowhumA
                  alowhumA
                  alowhum
                  Is encryption built in?
                  • Z
                    Z
                    Zeph
                    What is W3P? Is this some sort of CANBUS?
                    • K
                      K
                      kimot
                      wrote on last edited by kimot
                      I think your addressing concept do not respect hardware - microcontrollers and radio modules we are using.
                      Some hardware ( RFM69, serial in 9bit mode, etc. ) can filter incoming messages itself and do not disturb controller when
                      receive different address then node own ID or broadcast.
                      For example with RFM69 you can store node ID and broadcast address in radiomodule and it will receive only messages with this specific addresses.
                      But your address schema uses 4 lower bits for node ID ( 0-16 ) and lower 8 bits in all combination for broadcast too.
                      Your node must receive all 16 bits to distinguish - if it is node addressed message or broadcast call.
                      So you cannot use addressing features of our hardware.
                      I think, better is divide 16 bits to 8 bit node ID and 8 bits network ID.
                      Network filtering and routing then make gateway and distribute messages to connected nodes or other networks.
                      • Z Zeph
                        axillentA
                        axillentA
                        axillent
                        @zeph yes and no. it is very very simple hardware, similar to LocoNet. allows to transfer a few kbit/sec on single wire (w3p - 3 wire VCC + Signal + GND) using 1 npn transistor + 4 resistors at absolute minimum
                        sense and drive
                        • K kimot
                          axillentA
                          axillentA
                          axillent
                          @kimot the main idea of all my project is to manage network abstraction layer regardless hardware
                          only translation + driver layers are hardware related, but them allow to transfer logical layer data throuth any physical hardware
                          my 16bit addressing could be translated to addresses used by your hardware to keep handle communication based on hardware advantages.
                          I just launched a network with translation throuth Ethernet/TCP with application server running on orangepi
                          Working pretty well. On logical level it is always 16bit addressing with broadcasting support.
                          developing device you should not take care how message will reach another device
                          this is handled while developing appropriate translations/drivers on bridge side.
                          bridge - a device connecting 2 or more different physycal layers.
                          it is also allows to crate a building blocks.
                          For example I'm running ESP8266 with TCP interface to network on one side and UART&JSON interface on other side
                          attaching MCU to ESP by UART a can connect any kind of network to my network
                          sense and drive
                          • axillentA
                            axillentA
                            axillent
                            just to illustrate how translation is working
                            you do not need direct logic match between abstract layer and the layer of used interface
                            here is how translation is working between my network and MQTT broker:
                            bellow is initialization of 2 different nodes attached to 2 different interfaces, one to TCP/IP network, other to MQTT broker
                            it is a code from linux application server
                            // Nodes
                            // --- inet
                            typedef Smartlets::Common::RouteTableFile									RouteTable;
                            typedef STAVRP::Linux::TCPDrv<0>											TCPDrv;
                            typedef Smartlets::Interface::Translator::INet<Message, TCPDrv, RouteTable>	TranslINet;
                            typedef Smartlets::Interface::P2P<Message, TranslINet, 16, 16>			InterfaceINet;
                            typedef Smartlets::Node::NodeBasic<Message, InterfaceINet, ApplInet>		NodeINet;
                            // --- mqtt
                            typedef Smartlets::Interface::Translator::Mqtt<Message>				TranslMqtt;
                            typedef Smartlets::Interface::P2P<Message, TranslMqtt, 16, 16>			InterfaceMqtt;
                            typedef Smartlets::Node::NodeBasic<Message, InterfaceMqtt, ApplMqtt>		NodeMqtt;
                            Inside Translator:Mqtt the following is used for example inside TX method (sending message):
                            	static bool TX(const Message& msg) {
                            		char key[128];
                            		if( msg.header.tx.IsBroadcast() )
                            			sprintf(key, "/%s/bc/o/%d/%d/%d/%d", data.swi_domain.c_str(), msg.header.tx.GetBroadcastID(), msg.header.rx.GetNetSegment(), msg.header.rx.GetNetDevID(), msg.header.type.type);
                            			sprintf(key, "/%s/m/o/%d/%d/%d/%d/%d", data.swi_domain.c_str(), msg.header.tx.GetNetSegment(), msg.header.tx.GetNetDevID(), msg.header.rx.GetNetSegment(), msg.header.rx.GetNetDevID(), msg.header.type.type);
                            		std::string	payload = json_ext::FromMessage(msg);
                            		data.drv.TXPut(STAVRP::Linux::MqttEntry(key, payload));
                            		return true;
                            and this is how it is finally bridged between:
                            while(1) {
                            	// loop inet
                            	if( NodeINet::Loop() ) {
                            		Message msg = NodeINet::RX();
                            		Logger::root() << log4cpp::Priority::DEBUG << "inet-> tx=" << msg.header.tx.id;
                            		NodeINet::CommitRX(false);
                            		// --- routing
                            		if( NodeINet::TX(msg) ) {
                            			Logger::root() << log4cpp::Priority::DEBUG << "inet->inet TX OK";
                            			// delayed queue
                            			Logger::root() << log4cpp::Priority::ERROR << "inet->inet TX failed";
                            		if( NodeMqtt::TX(msg) ) {
                            			Logger::root() << log4cpp::Priority::DEBUG << "inet->mqtt TX OK";
                            			Logger::root() << log4cpp::Priority::ERROR << "inet->mqtt TX failed";
                            	// loop mqtt
                            	if( NodeMqtt::Loop() ) {
                            		Message msg = NodeMqtt::RX();
                            		Logger::root() << log4cpp::Priority::DEBUG << "mqtt-> tx=" << msg.header.tx.id;
                            		NodeMqtt::CommitRX(false);
                            		if( NodeINet::TX(msg) ) Logger::root() << log4cpp::Priority::DEBUG << "mqtt->inet TX OK";
                            		else Logger::root() << log4cpp::Priority::ERROR << "mqtt->inet TX failed";
                            	sleep(1);
                            sense and drive
                            • axillentA
                              axillentA
                              axillent
                              #21
                              made a few steps forward
                              launched ESP8266 node & bridge and STM32 bridge and TCP/IP router based on linux (orangepi)
                              bellow is my working example
                              list of supported platforms:
                              • STM8S/IAR
                              • STM32F0/Keil - draft
                              • ATMEL/Atmel studio - draft
                              • Arduino ESP8266
                              • Arduino STM32
                              • Linux/g++
                              i;m working on 2 libs. first is to handle platform dependant things. second is platform independant smart devices network
                              regardless platform and regardless communication hardware the framework allows to transfer messages using RX/TX notation with 16 bit global addressing.
                              Addressing is organized as 4096 segments where 4094 are 15 node segments each and 2 segments are for broadcadsting
                              framework allows to connect potentially absolutelly different communication hardware
                              currently i'm running:
                              • simple one wire (1 wire signal + 2 wire power) network
                              • wifi based nodes
                              • twisted pair connected ethernet devices
                              bridge between different types of network is organized on TCP/IP application server running currently on linux
                              etc. potentially allows to connect network segments regardless physicall location, only internet connection is required
                              why i'm doing this? mostly for fan but also to implement 2 principles:
                              • application layer to be independant from hardware and transport. message format is universal and is the same regardless platform and communication hardware. Addressing is also universal. Application should not take care about intermediate specific, this is handled by other components
                              • avoid a central unit. each device can communicate with each device. the only central component is application server. but is is very simple, robust and reliable. failover is supported
                              My example:
                              sense and drive
                              • axillentA
                                axillentA
                                axillent
                                for esp8266 i made an universal bridge application
                                it can be used for both:
                                • single node, esp8266 is running a final application. on the photo above my thermostats to measure room temperature, report it and to send ON/OFF commands to heaters
                                • bridge. can be used to connect other type networks wirelessly to application server. UART is used for this + json translation. currently this is implemented to connect heating controllers located on each floor
                                main and failover servers can be configured
                                also each node is configured to handle from one to a few network segments. this allows simple routing from application server back to node
                                esp8266 is using ArduinoOTA and zero hardcording.
                                after fresh programming esp creates AP and smartphone can be used to preconfigure a node
                                any updates are keeping configuration except major updates there stored structure can be affected
                                application server is also support MQTT translation
                                etc. it looks like a routing between my network and MQTT server
                                RX/TX adresing are mapped to MQTT topic while message is translated into JSON:
                                sense and drive
                                • axillentA
                                  axillentA
                                  axillent
                                  #23
                                  also from last
                                  byteorder handling is build in
                                  library allows to choose any order
                                  I select bigendian because this is natural to my major MCU - STM8
                                  on little endian platforms (like STM32, ESP8266 and ARM64) data is automatically translated
                                  sense and drive
                                  • axillentA
                                    axillentA
                                    axillent
                                    just published my libraries
                                    anyonw is welsome on review and comments https://github.com/axillent :
                                    • list item stavrp C++ multiplafrom suport library, platforms are at different level of support
                                    • list item smartletsp C++ smart devices network
                                    • list item swilib and integration of above two libraries with arduino framework
                                    sense and drive
                                    • axillentA
                                      axillentA
                                      axillent
                                      Linux Router https://github.com/axillent/swi_appserver
                                      sense and drive
