  3. Concept of a flexible but simple smart network
25 Posts 6 Posters 7.3k Views 4 Watching
  • axillentA
    axillentA
    axillent
    yes, to address devices across different network segments you need a global ID
    but there is a trick... Please see the first picture. It is a layer called Translator.
    it is possible to translate non-global ID to global and back and this will allow to create a bridge
    sense and drive
    dbemowskD 1 Reply Last reply
    • axillentA axillent
      dbemowskD
      dbemowskD
      @axillent Isn't that in a sense a broad definition of what a bridge does? Translating information between two different types of networks.
      axillentA 1 Reply Last reply
      • dbemowskD dbemowsk
        axillentA
        axillentA
        axillent
        @dbemowsk each layer does it's job
        bridge just creates a bridge
        will it do a translation between depends on translation layer
        translation job can be about translation of address or translation of data form or even both
        all this depends on the goal but brings wide flexibility
        sense and drive
        • axillentA
          axillentA
          axillent
          some more details about addressing
          global adress is 16 bit number. 12 most significant bits are defining network segment number while 4 less significant bits are providing nodeID
          section 0xFE00-0xFEFF is reserved for local broadcasting, 0xFF00-0xFFFF - for global broadcasts. Etc. 256 broadcasts of each type
          segments and differenciation between local and global broadcasts are needed for efficient support of bridging and routing.
          bridging is a simplified version of routing. bridging is connecting network segments on different physycal inrterfaces while routing can assume to bypass many physical interfaces between (routing throuth).
          one of the bridge example is a link between wired interface and MQTT.
          one of the routing example is a link between 2 wired interfaces across public Internet
          each network segment can have 15 nodes. nodeID = 0 is a special local segment broadcast addressing all devices in segment.
          each physical interface can have several segments, etc. there is no limitation to have 15 nodes on physical interface. you just add as many segments to interface as you need to have devices
          sense and drive
          • alowhumA
            alowhumA
            alowhum
            Is encryption built in?
            • Z
              Z
              Zeph
              What is W3P? Is this some sort of CANBUS?
              • K
                K
                kimot
                wrote on last edited by kimot
                I think your addressing concept do not respect hardware - microcontrollers and radio modules we are using.
                Some hardware ( RFM69, serial in 9bit mode, etc. ) can filter incoming messages itself and do not disturb controller when
                receive different address then node own ID or broadcast.
                For example with RFM69 you can store node ID and broadcast address in radiomodule and it will receive only messages with this specific addresses.
                But your address schema uses 4 lower bits for node ID ( 0-16 ) and lower 8 bits in all combination for broadcast too.
                Your node must receive all 16 bits to distinguish - if it is node addressed message or broadcast call.
                So you cannot use addressing features of our hardware.
                I think, better is divide 16 bits to 8 bit node ID and 8 bits network ID.
                Network filtering and routing then make gateway and distribute messages to connected nodes or other networks.
                • Z Zeph
                  axillentA
                  axillentA
                  axillent
                  @zeph yes and no. it is very very simple hardware, similar to LocoNet. allows to transfer a few kbit/sec on single wire (w3p - 3 wire VCC + Signal + GND) using 1 npn transistor + 4 resistors at absolute minimum
                  sense and drive
                  • K kimot
                    axillentA
                    axillentA
                    axillent
                    @kimot the main idea of all my project is to manage network abstraction layer regardless hardware
                    only translation + driver layers are hardware related, but them allow to transfer logical layer data throuth any physical hardware
                    my 16bit addressing could be translated to addresses used by your hardware to keep handle communication based on hardware advantages.
                    I just launched a network with translation throuth Ethernet/TCP with application server running on orangepi
                    Working pretty well. On logical level it is always 16bit addressing with broadcasting support.
                    developing device you should not take care how message will reach another device
                    this is handled while developing appropriate translations/drivers on bridge side.
                    bridge - a device connecting 2 or more different physycal layers.
                    it is also allows to crate a building blocks.
                    For example I'm running ESP8266 with TCP interface to network on one side and UART&JSON interface on other side
                    attaching MCU to ESP by UART a can connect any kind of network to my network
                    sense and drive
                    • axillentA
                      axillentA
                      axillent
                      just to illustrate how translation is working
                      you do not need direct logic match between abstract layer and the layer of used interface
                      here is how translation is working between my network and MQTT broker:
                      bellow is initialization of 2 different nodes attached to 2 different interfaces, one to TCP/IP network, other to MQTT broker
                      it is a code from linux application server
                      // Nodes
                      // --- inet
                      typedef Smartlets::Common::RouteTableFile									RouteTable;
                      typedef STAVRP::Linux::TCPDrv<0>											TCPDrv;
                      typedef Smartlets::Interface::Translator::INet<Message, TCPDrv, RouteTable>	TranslINet;
                      typedef Smartlets::Interface::P2P<Message, TranslINet, 16, 16>			InterfaceINet;
                      typedef Smartlets::Node::NodeBasic<Message, InterfaceINet, ApplInet>		NodeINet;
                      // --- mqtt
                      typedef Smartlets::Interface::Translator::Mqtt<Message>				TranslMqtt;
                      typedef Smartlets::Interface::P2P<Message, TranslMqtt, 16, 16>			InterfaceMqtt;
                      typedef Smartlets::Node::NodeBasic<Message, InterfaceMqtt, ApplMqtt>		NodeMqtt;
                      Inside Translator:Mqtt the following is used for example inside TX method (sending message):
                      	static bool TX(const Message& msg) {
                      		char key[128];
                      		if( msg.header.tx.IsBroadcast() )
                      			sprintf(key, "/%s/bc/o/%d/%d/%d/%d", data.swi_domain.c_str(), msg.header.tx.GetBroadcastID(), msg.header.rx.GetNetSegment(), msg.header.rx.GetNetDevID(), msg.header.type.type);
                      			sprintf(key, "/%s/m/o/%d/%d/%d/%d/%d", data.swi_domain.c_str(), msg.header.tx.GetNetSegment(), msg.header.tx.GetNetDevID(), msg.header.rx.GetNetSegment(), msg.header.rx.GetNetDevID(), msg.header.type.type);
                      		std::string	payload = json_ext::FromMessage(msg);
                      		data.drv.TXPut(STAVRP::Linux::MqttEntry(key, payload));
                      		return true;
                      and this is how it is finally bridged between:
                      while(1) {
                      	// loop inet
                      	if( NodeINet::Loop() ) {
                      		Message msg = NodeINet::RX();
                      		Logger::root() << log4cpp::Priority::DEBUG << "inet-> tx=" << msg.header.tx.id;
                      		NodeINet::CommitRX(false);
                      		// --- routing
                      		if( NodeINet::TX(msg) ) {
                      			Logger::root() << log4cpp::Priority::DEBUG << "inet->inet TX OK";
                      			// delayed queue
                      			Logger::root() << log4cpp::Priority::ERROR << "inet->inet TX failed";
                      		if( NodeMqtt::TX(msg) ) {
                      			Logger::root() << log4cpp::Priority::DEBUG << "inet->mqtt TX OK";
                      			Logger::root() << log4cpp::Priority::ERROR << "inet->mqtt TX failed";
                      	// loop mqtt
                      	if( NodeMqtt::Loop() ) {
                      		Message msg = NodeMqtt::RX();
                      		Logger::root() << log4cpp::Priority::DEBUG << "mqtt-> tx=" << msg.header.tx.id;
                      		NodeMqtt::CommitRX(false);
                      		if( NodeINet::TX(msg) ) Logger::root() << log4cpp::Priority::DEBUG << "mqtt->inet TX OK";
                      		else Logger::root() << log4cpp::Priority::ERROR << "mqtt->inet TX failed";
                      	sleep(1);
                      sense and drive
                      • axillentA
                        axillentA
                        axillent
                        #21
                        made a few steps forward
                        launched ESP8266 node & bridge and STM32 bridge and TCP/IP router based on linux (orangepi)
                        bellow is my working example
                        list of supported platforms:
                        • STM8S/IAR
                        • STM32F0/Keil - draft
                        • ATMEL/Atmel studio - draft
                        • Arduino ESP8266
                        • Arduino STM32
                        • Linux/g++
                        i;m working on 2 libs. first is to handle platform dependant things. second is platform independant smart devices network
                        regardless platform and regardless communication hardware the framework allows to transfer messages using RX/TX notation with 16 bit global addressing.
                        Addressing is organized as 4096 segments where 4094 are 15 node segments each and 2 segments are for broadcadsting
                        framework allows to connect potentially absolutelly different communication hardware
                        currently i'm running:
                        • simple one wire (1 wire signal + 2 wire power) network
                        • wifi based nodes
                        • twisted pair connected ethernet devices
                        bridge between different types of network is organized on TCP/IP application server running currently on linux
                        etc. potentially allows to connect network segments regardless physicall location, only internet connection is required
                        why i'm doing this? mostly for fan but also to implement 2 principles:
                        • application layer to be independant from hardware and transport. message format is universal and is the same regardless platform and communication hardware. Addressing is also universal. Application should not take care about intermediate specific, this is handled by other components
                        • avoid a central unit. each device can communicate with each device. the only central component is application server. but is is very simple, robust and reliable. failover is supported
                        My example:
                        sense and drive
                        • axillentA
                          axillentA
                          axillent
                          for esp8266 i made an universal bridge application
                          it can be used for both:
                          • single node, esp8266 is running a final application. on the photo above my thermostats to measure room temperature, report it and to send ON/OFF commands to heaters
                          • bridge. can be used to connect other type networks wirelessly to application server. UART is used for this + json translation. currently this is implemented to connect heating controllers located on each floor
                          main and failover servers can be configured
                          also each node is configured to handle from one to a few network segments. this allows simple routing from application server back to node
                          esp8266 is using ArduinoOTA and zero hardcording.
                          after fresh programming esp creates AP and smartphone can be used to preconfigure a node
                          any updates are keeping configuration except major updates there stored structure can be affected
                          application server is also support MQTT translation
                          etc. it looks like a routing between my network and MQTT server
                          RX/TX adresing are mapped to MQTT topic while message is translated into JSON:
                          sense and drive
                          • axillentA
                            axillentA
                            axillent
                            #23
                            also from last
                            byteorder handling is build in
                            library allows to choose any order
                            I select bigendian because this is natural to my major MCU - STM8
                            on little endian platforms (like STM32, ESP8266 and ARM64) data is automatically translated
                            sense and drive
                            • axillentA
                              axillentA
                              axillent
                              just published my libraries
                              anyonw is welsome on review and comments https://github.com/axillent :
                              • list item stavrp C++ multiplafrom suport library, platforms are at different level of support
                              • list item smartletsp C++ smart devices network
                              • list item swilib and integration of above two libraries with arduino framework
                              sense and drive
                              • axillentA
                                axillentA
                                axillent
                                Linux Router https://github.com/axillent/swi_appserver
                                sense and drive
