  3. Concept of a flexible but simple smart network
25 Posts 6 Posters 7.3k Views 4 Watching
  • axillentA
    axillentA
    axillent
    Doing my staff and doing mysensors, thinking about others I came intp conclusion that smart network required to be more abstract, it's basics should be in logic disconnected from hardware realization. From a long long thinking I made a concept I'm currently working on. I will be glad to share and discuss it to get different views.
    Abstracting requires to split all into separate levels starting from application and dropping down up to hardware. It can be done in different ways. I will describe here my way.
    First of all the message. It very common to have here a header with RX & TX ids and message type. But it should have nothing about underling like CRC sum. The underling is coming on lower level. This allows to write an application which does not depends on hardware.
    So to start I present a layering diagram
    Layers are listed here from left to right:
    • Super Application. This is top-top abstract layer as a cover of regular application. Example are the Bridge (interconnects two networks) and Router (interconnects with routing 2+ networks)
    • Application. This is a regular application required by any smart device. It allows you have a network connected device. It is so common that it can be used for whatever you want and you can plug so called Features into it to extend its functionality without re-programm the applicariton. See Features bellow.
    • Application Feature. This is a plug-and-play extensions to Application. Examples are:
    • basic1 allows the device to auto assign ID or to have ID assigned manually by network command
    • basic2 contains support for "red" button and indicating LED. LED represents Application status: Normal, NOIDUssigned, WAITCOMMAND. Button allows enter/leave WAITCOMMAND status. This status allows device to receive messages with special WAITCOMMAND broadcast address regardless its own ID. This one is similar as Inclusion status for ZWave devices.
    • callback. regular application allows you to read network messages by ::RX method. callback Feature allows you to define per message type callback functions
    • broadcast. regular application address device by its direct ID. broadcast Feature allows you to define a list of special broadcasts for device to have an alternative addressing. For example you can put RTC clock inside your network and any device can request clock source without knowing the source ID
    • Dispatcher. This Feature organize needed logistic for incoming and outgoing messages. Example:
    • P2P peer to peer network. All outgoing messages are send immediately to hardware
    • M&S master and slave. Outgoing messages from slaves will be send only on session start request from Master. This for example can be used on half-duplex RS485 networks
    • Translator. This one is very close to hardware. It translate abstract standard message from-to hardware layer. For example it can put the message into cover with CRC checksum if underling interface requires this. Other example - text console. All messages are translated to text for manual monitoring and also there is a possibility to send message
    • Driver. This one deals with hardware directly or using specified hardware library. Examples:
    • NRF24
    • RS485
    • UART
    sense and drive
    • axillentA
      axillentA
      axillent
      An Example of simple device, application configuration:
      // --- Smartlets
      typedef Message::Message<20>		msg_type;
      // --- Options
      // w3p driver
      typedef HandlerPortD<ExtIntMode::FallingRising>	pinchange_drv;
      typedef PortD<6, PinMode::Interrupt>		w3p_rx;
      typedef PortD<5, PinMode::Inverse | PinMode::OutputPushPull> w3p_tx;
      typedef Timer2<mcu, 0, 6, 1000>			w3p_timer;
      typedef Driver::W3P<w3p_rx, pinchange_drv, w3p_tx, w3p_timer>	drv;
      // translator
      typedef Translator::W3P<msg_type>		transl;
      // dispatcher
      typedef Dispatcher::P2P<msg_type, transl, drv>	disp;
      // application
      typedef Feature::Basic1<msg_type, disp, ep_id>	basic1;
      typedef Feature::CallBackByType<Message::Type::LightScene, msg_scene_cbk>	scene_callback;
      typedef Feature::CallBack<msg_type, scene_callback, basic1>	callback;
      typedef Feature::Basic2<msg_type, disp, button, led1, callback>	basic2;
      typedef Application::Application<msg_type, disp, basic2>	appl;
      And simple main, this one supports 2 channel relay functions and 2 NTC sensors
      int main()
        mcu::Init();
        ep_id::SetDefault(Message::ID(THIS_NET_SEGMENT_ID));
        ep_key::Set();
        appl::Init();
        adc::Start();
        timer::Start();
        mcu::InterruptEnable();
        var.timer	 = 10;
        var.timer1 = 60;
        var.timer2 = 60;
        struct {
      	int	temperature1, temperature2;
        } prev;
        while(1) {
          appl::Loop();
      	if( !var.timer ) {
      	  var.timer = 10;
      	  if( !var.timer1 || abs_int(prev.temperature1 - var.temperature1) > 10 ) {
      		Message::Value	msg(100, var.temperature1, Message::Value::TemperatureInt16);
      		if( appl::Tx(Message::ID(Message::ID::Value), msg.Type(), msg, msg.Size(), false) == Message::State::TxOK ) {
      			// message is to be send
      			prev.temperature1 = var.temperature1;
      			var.timer1 = 60;
      	  if( !var.timer2 || abs_int(prev.temperature2 - var.temperature2) > 10 ) {
      		Message::Value	msg(101, var.temperature2, Message::Value::TemperatureInt16 );
      			prev.temperature2 = var.temperature2;
      			var.timer2 = 60;
          mcu::InterruptWait();
      call back:
      bool msg_scene_cbk(const uint8_t& msg) {
        const Message::Relay& data = *(const Message::Relay*)&(&msg)[sizeof(Message::Header)];
        switch( data.channel ) {
        case 0:
      	relay1.Set(data.relay);
      	led2.Run(1, 5);
      	return true;
        case 1:
      	relay2.Set(data.relay);
      	led2.Run(2, 5);
      	return true;
        return false;
      sense and drive
        That resembles pretty much computers' network stack, am I wrong?
        • axillentA
          axillentA
          axillent
          in details it is very different but by the idea it looks like TCP/IP stack
          Also by addressing, I assume 16 bit global address allows you to address any devices on the same network or other network through bridge or router. And there is no any requirement to have a controller. Devices are able to communicated directly. Controller is a device able to manage network config.uration by assigning ID's (very similar to DHCP). But. ID can be assigned manually and it is also possible to run ID-less configuration by using local or global broadcasts. For example wall switch can be configured to send Scene ID to LightScene brodcast address, and any lighting devices can receive this by brodcast and be activated based on scene ID instead of network address.
          Just to illustrate idea in more details I have other picture
          sense and drive
          • axillentA
            axillentA
            axillent
            based on this concept I make a text based console which is actually Super Application, application one is 3 wire physical interface with manchester encoding, application 2 is UART console connected to VT220 terminal. Super Application bridges to networks together. By adding Broadcast with accept to All messages broadcast I allow Bridge to pass all the messages between two networks
            // --- bridge application
            typedef Application::Bridge<msg_type, w3p_appl, uart_appl>						bridge_appl;
            // Variables
            // Main
            int main()
              mcu::Init();
              ep_key::Set();
              bridge_appl::Init();
              timer::Start();
              led2.Set();
              uart_transl::SetID(ep_id::Get());
              uart_transl::Print("\n\n\x1b[31m--- Console v1.0 started\x1b[30m");
              while(1) {
            	bridge_appl::Loop();
            All is plug & play. Etc. it requires NO modification of basic library to create this console. A typical session bellow:
            sense and drive
            • axillentA
              axillentA
              axillent
              Not that important. But there is no stick to Arduino. It is multiplatform based thing-set. Atmel + STM8 + STM32 are supported. ESP is comming
              sense and drive
                If you can find a way to make a "router" between different mysensors networks, you could make many people happy 😁
                dbemowskD 1 Reply Last reply
                  dbemowskD
                  dbemowskD
                  @gohan Wouldn't that be handled in the bridges that he has shown in this image?
                  0_1509815372555_upload-c8029759-6a17-4ce1-b04d-3f48014cbd36
                  Maybe I am thinking of this wrong, but I would think of it in the sense of a MySensors gateway being the bridge or router that would translate the communication from the local computer network to the different types of devices. Instead of connecting that gateway to a controller like Vera, Domoticz or OpenHAB, it would connect to the IP network. It is basically converting the data from one transmission media such as nRF24L01 or RFM69, over to ethernet.
                    you could use bridges but you would need to have unique IDs throughout all the networks if you want nodes to talk to each other across networks, if I understood right.
                      dbemowskD
                      dbemowskD
                      @gohan Wouldn't you need that anyway? How else would you address a node?
                      • axillentA
                        axillentA
                        axillent
                        yes, to address devices across different network segments you need a global ID
                        but there is a trick... Please see the first picture. It is a layer called Translator.
                        it is possible to translate non-global ID to global and back and this will allow to create a bridge
                        sense and drive
                        • axillentA axillent
                          dbemowskD
                          dbemowskD
                          @axillent Isn't that in a sense a broad definition of what a bridge does? Translating information between two different types of networks.
                          axillentA 1 Reply Last reply
                          • dbemowskD dbemowsk
                            axillentA
                            axillentA
                            axillent
                            @dbemowsk each layer does it's job
                            bridge just creates a bridge
                            will it do a translation between depends on translation layer
                            translation job can be about translation of address or translation of data form or even both
                            all this depends on the goal but brings wide flexibility
                            sense and drive
                            • axillentA
                              axillentA
                              axillent
                              some more details about addressing
                              global adress is 16 bit number. 12 most significant bits are defining network segment number while 4 less significant bits are providing nodeID
                              section 0xFE00-0xFEFF is reserved for local broadcasting, 0xFF00-0xFFFF - for global broadcasts. Etc. 256 broadcasts of each type
                              segments and differenciation between local and global broadcasts are needed for efficient support of bridging and routing.
                              bridging is a simplified version of routing. bridging is connecting network segments on different physycal inrterfaces while routing can assume to bypass many physical interfaces between (routing throuth).
                              one of the bridge example is a link between wired interface and MQTT.
                              one of the routing example is a link between 2 wired interfaces across public Internet
                              each network segment can have 15 nodes. nodeID = 0 is a special local segment broadcast addressing all devices in segment.
                              each physical interface can have several segments, etc. there is no limitation to have 15 nodes on physical interface. you just add as many segments to interface as you need to have devices
                              sense and drive
                              • alowhumA
                                alowhumA
                                alowhum
                                Is encryption built in?
                                • Z
                                  Z
                                  Zeph
                                  What is W3P? Is this some sort of CANBUS?
                                  • K
                                    K
                                    kimot
                                    wrote on last edited by kimot
                                    I think your addressing concept do not respect hardware - microcontrollers and radio modules we are using.
                                    Some hardware ( RFM69, serial in 9bit mode, etc. ) can filter incoming messages itself and do not disturb controller when
                                    receive different address then node own ID or broadcast.
                                    For example with RFM69 you can store node ID and broadcast address in radiomodule and it will receive only messages with this specific addresses.
                                    But your address schema uses 4 lower bits for node ID ( 0-16 ) and lower 8 bits in all combination for broadcast too.
                                    Your node must receive all 16 bits to distinguish - if it is node addressed message or broadcast call.
                                    So you cannot use addressing features of our hardware.
                                    I think, better is divide 16 bits to 8 bit node ID and 8 bits network ID.
                                    Network filtering and routing then make gateway and distribute messages to connected nodes or other networks.
                                    • Z Zeph
                                      axillentA
                                      axillentA
                                      axillent
                                      @zeph yes and no. it is very very simple hardware, similar to LocoNet. allows to transfer a few kbit/sec on single wire (w3p - 3 wire VCC + Signal + GND) using 1 npn transistor + 4 resistors at absolute minimum
                                      sense and drive
                                      • K kimot
                                        axillentA
                                        axillentA
                                        axillent
                                        @kimot the main idea of all my project is to manage network abstraction layer regardless hardware
                                        only translation + driver layers are hardware related, but them allow to transfer logical layer data throuth any physical hardware
                                        my 16bit addressing could be translated to addresses used by your hardware to keep handle communication based on hardware advantages.
                                        I just launched a network with translation throuth Ethernet/TCP with application server running on orangepi
                                        Working pretty well. On logical level it is always 16bit addressing with broadcasting support.
                                        developing device you should not take care how message will reach another device
                                        this is handled while developing appropriate translations/drivers on bridge side.
                                        bridge - a device connecting 2 or more different physycal layers.
                                        it is also allows to crate a building blocks.
                                        For example I'm running ESP8266 with TCP interface to network on one side and UART&JSON interface on other side
                                        attaching MCU to ESP by UART a can connect any kind of network to my network
                                        sense and drive
                                        • axillentA
                                          axillentA
                                          axillent
                                          just to illustrate how translation is working
                                          you do not need direct logic match between abstract layer and the layer of used interface
                                          here is how translation is working between my network and MQTT broker:
                                          bellow is initialization of 2 different nodes attached to 2 different interfaces, one to TCP/IP network, other to MQTT broker
                                          it is a code from linux application server
                                          // Nodes
                                          // --- inet
                                          typedef Smartlets::Common::RouteTableFile									RouteTable;
                                          typedef STAVRP::Linux::TCPDrv<0>											TCPDrv;
                                          typedef Smartlets::Interface::Translator::INet<Message, TCPDrv, RouteTable>	TranslINet;
                                          typedef Smartlets::Interface::P2P<Message, TranslINet, 16, 16>			InterfaceINet;
                                          typedef Smartlets::Node::NodeBasic<Message, InterfaceINet, ApplInet>		NodeINet;
                                          // --- mqtt
                                          typedef Smartlets::Interface::Translator::Mqtt<Message>				TranslMqtt;
                                          typedef Smartlets::Interface::P2P<Message, TranslMqtt, 16, 16>			InterfaceMqtt;
                                          typedef Smartlets::Node::NodeBasic<Message, InterfaceMqtt, ApplMqtt>		NodeMqtt;
                                          Inside Translator:Mqtt the following is used for example inside TX method (sending message):
                                          	static bool TX(const Message& msg) {
                                          		char key[128];
                                          		if( msg.header.tx.IsBroadcast() )
                                          			sprintf(key, "/%s/bc/o/%d/%d/%d/%d", data.swi_domain.c_str(), msg.header.tx.GetBroadcastID(), msg.header.rx.GetNetSegment(), msg.header.rx.GetNetDevID(), msg.header.type.type);
                                          			sprintf(key, "/%s/m/o/%d/%d/%d/%d/%d", data.swi_domain.c_str(), msg.header.tx.GetNetSegment(), msg.header.tx.GetNetDevID(), msg.header.rx.GetNetSegment(), msg.header.rx.GetNetDevID(), msg.header.type.type);
                                          		std::string	payload = json_ext::FromMessage(msg);
                                          		data.drv.TXPut(STAVRP::Linux::MqttEntry(key, payload));
                                          		return true;
                                          and this is how it is finally bridged between:
                                          while(1) {
                                          	// loop inet
                                          	if( NodeINet::Loop() ) {
                                          		Message msg = NodeINet::RX();
                                          		Logger::root() << log4cpp::Priority::DEBUG << "inet-> tx=" << msg.header.tx.id;
                                          		NodeINet::CommitRX(false);
                                          		// --- routing
                                          		if( NodeINet::TX(msg) ) {
                                          			Logger::root() << log4cpp::Priority::DEBUG << "inet->inet TX OK";
                                          			// delayed queue
                                          			Logger::root() << log4cpp::Priority::ERROR << "inet->inet TX failed";
                                          		if( NodeMqtt::TX(msg) ) {
                                          			Logger::root() << log4cpp::Priority::DEBUG << "inet->mqtt TX OK";
                                          			Logger::root() << log4cpp::Priority::ERROR << "inet->mqtt TX failed";
                                          	// loop mqtt
                                          	if( NodeMqtt::Loop() ) {
                                          		Message msg = NodeMqtt::RX();
                                          		Logger::root() << log4cpp::Priority::DEBUG << "mqtt-> tx=" << msg.header.tx.id;
                                          		NodeMqtt::CommitRX(false);
                                          		if( NodeINet::TX(msg) ) Logger::root() << log4cpp::Priority::DEBUG << "mqtt->inet TX OK";
                                          		else Logger::root() << log4cpp::Priority::ERROR << "mqtt->inet TX failed";
                                          	sleep(1);
                                          sense and drive
                                          With your input, this post could be even better πŸ’—
