  3. Blink on nodeMCU / RFM69 gateway
nodemcugateway mqttrfm69hwblink
3 Posts 3 Posters 1.4k Views 3 Watching
  • R
    R
    rmh
    My gateway works fine with the vanilla wiring as per RFM69/95 & ESP8266 at https://www.mysensors.org/build/connect_radio and the example GatewayESP8266MQTTClient sketch.
    I have tried adding the Radio Traffic LEDs as per https://www.mysensors.org/build/advanced_gateway but whichever available pins I use:
    D2 / D3 / D4 : leds blink but comms to nodes seem to fail with NOACK
    D9 / D10 : seems to work but lose serial output for debug.
    I expect someone has made this work before - what am I doing wrong?
    Richard
    Andrew MaynardA 1 Reply Last reply
    • R rmh
      Richard
      Andrew MaynardA
      Andrew MaynardA
      Andrew Maynard
      @rmh same here
      • mfalkviddM
        In the default wiring, D1 is the only unused pin that is easy to work with.
        D2 is used for CE so using it to blink a led as well will not work.
