  3. 💬 EFEKTA Temp&Hum sensor(ver. nRF52 )+E-Ink display
nrf52832e-ink displaye-papernrf52nrf52810nrf52811nrf52840temperature & humidity sensor
105 Posts 11 Posters 35.0k Views 12 Watching
  • berkseoB berkseo
    @jeti
    On video, now I understand)). Used software for the Atmega328 , so was error. This chip is very fast. I fix it.
    J
    J
    jeti
    @berkseo ah thanks. If you need somebody to test. I would be happy to do so.
    • H
      H
      heinzv
      wrote on last edited by heinzv
      #24
      Once the code is available I would order 10x PCB's.
      Also, do you have a link to the nRF52832 module? (a 840 version would be also very nice :-))
      ok, I just odered the 5 PCB Sets.
      Beside the link to the nRF52832 Module, please provide also the link to the e-Paper Module.
      berkseoB 2 Replies Last reply
      • H
        H
        heinzv
        • tbowmoT
          tbowmoT
          tbowmo
          Really nice design..
          Could you please post the schematics / board files as well, as this is a openhardware site.
          Also if you upload the gerber files directly (not in a zip / rar file), then the openhardware.io site is able to render 3D views of the boards etc.
          berkseoB 1 Reply Last reply
          • H heinzv
            berkseoB
            berkseoB
            berkseo
            @heinzv said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
            Code in the work. BOM added.
            • tbowmoT tbowmo
              berkseoB
              berkseoB
              berkseo
              @tbowmo
              Thank you for rating. I will lay out the scheme in the near future, it needs to be drawn :). 3D-model does not work, it turns out a piece of cheese. I work at Diptrace( https://diptrace.com ), but this problem is not only mine - https://forum.mysensors.org/topic/9528/temperature-and-humidity-sensor-ver-atmega328-e-ink-display/30
              • H heinzv
                berkseoB
                berkseoB
                berkseo
                @heinzv
                Still no support nRF52840 in the Arduino IDE. What Sandeepmistry implemented uses is the old SDK ...still. I am guided by this editor as it is easy to use for regular users as well as MySensors :)
                • berkseoB
                  berkseoB
                  berkseo
                  #30
                  • berkseoB
                    berkseoB
                    berkseo
                    https://youtu.be/sLmR-i1RvpQ
                    J 1 Reply Last reply
                    • berkseoB berkseo
                      J
                      J
                      jeti
                      @berkseo it looks very good! Is testing running good?
                      Any hickups ?
                      • berkseoB
                        berkseoB
                        berkseo
                        @jeti
                        So far I'm satisfied, there is one point with updating the screen. I do not really want to do a full update in the program, but probably have to. Partial update gives the effect of visible lines from the previous symbol. Look at the photo, but it is a problem of code and beauty :)
                        • berkseoB berkseo
                          @jeti
                          J
                          J
                          jeti
                          wrote on last edited by jeti
                          #34
                          @berkseo cool thanks for your update, really impressive which detail you are aiming to achieve!
                          I'm planning to get some as soon as possible :-) already gathering the parts. Any chance you upload the PCB?
                          • berkseoB
                            berkseoB
                            berkseo
                            The work of the program was changed. Now the screen update is better. Looks more beautiful :)
                            https://youtu.be/J9Kp3K8ah9g
                            • J jeti
                              berkseoB
                              berkseoB
                              berkseo
                              @jeti said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
                              I'm planning to get some as soon as possible already gathering the parts. Any chance you upload the PCB?
                              PCB files have already been added, they are in the archives.
                              • H
                                H
                                heinzv
                                #37
                                @berkseo I have ordered already the 10x PCB's and also most of the BOM. I'm also going to order one full mounted PCB (if still available).
                                Can you do me a favour: I need one decimal digit for the temp (not required for hum) but certainly for the temp!
                                Here is a hint/proposal: You can make the decimal digit smaller. I attach one sample from a Xiaomi device (unfortunatly has no wireless and not sure if/how it can be hacked and wireless added).
                                • H heinzv
                                  berkseoB
                                  berkseoB
                                  berkseo
                                  Do you want me to change the SOFTWARE a bit? Well, I do not think this is a problem. Question ... Maybe you like some kind of special font? I don’t know which one to use. I can also add technical sensors that can set device parameters through the controller of an intelligent home. An example of such sensors, see the video of my new prototype sensor. ... Now there is only one device left, but I plan to make a little more by the end of next week (I hope :)). Since I started posting my projects on openhardware, I realized that I don’t like to solder for sale, it’s not interesting :)
                                  https://www.youtube.com/watch?v=NtYbx0TqP_o
                                  https://www.youtube.com/watch?v=HkxbiTkkVXA&t=8s
                                  • H heinzv
                                    berkseoB
                                    berkseoB
                                    berkseo
                                    Note, the device consists of two printed circuit boards, the order system on openhardware does not allow you to add two printed circuit boards for one device, just formed a second revision. For self-order download archives.
                                    • H
                                      H
                                      heinzv
                                      @berkseo Yes, I'd like to change the SW so that the temp shows also one decimal like 21,6 C
                                      For the decimal a smaller font likes quite nice such as shown in the picture of the sensor from Xiaomi.
                                      I don't have a specical font in mind but rather recommend to take proportional font rather than a mono-space font whcih is rather used for debugger output but not for a productive end user display. The space between the digits is typically smaller/less using a proportional font and looks more elegant than using mono-font.
                                      I know, that the 10 PCB's are 5 + 5 (5 sets).
                                      I can imagine, that selling soldered PCB's is not a very interesting business and is boring and time consuming for just little amount of money. I was buying one just as reference and will solder the other 5 sets by myself. I know how much effort that is.
                                      • H
                                        H
                                        heinzv
                                        @berkseo I have now the PCB's and my parts. Ihave now a few questions
                                        1.) When can we expect the sketch code?
                                        2.) Can we also have the schematics?
                                        3.) How to you solder parts like the TPS62745DSSR? Are you using a reflow oven? or hot air or even a small solder iron?
                                        • H heinzv
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          @heinzv
                                          1. Added as a library with an example, see project page on openhardware
                                          2. Soon. ,..on PCB all marking is applied.
                                          3. First, I dissolve the flux paste and solder paste, apply a thin layer on the PCB. Installing a chip, clamping it with a reverse tweezer. Correct the position. It is then heated with a heat gun for soldering. Then remove the excess solder with a soldering iron (if any). It's simple, much harder to solder atmega 328.
                                          I recently modified the boards, moved the elements on the power Board to the other side, made more convenient cutouts for mounting in the case. How to get ready fees, you will receive again this option further. Just all who made orders, please do not refuse payments, now a small delay in sending due to the fact that waiting for a new modification of the Board. All orders will be shipped.
                                          H 1 Reply Last reply
