  3. πŸ’¬ EFEKTA Temp&Hum sensor(ver. nRF52 )+E-Ink display
nrf52832e-ink displaye-papernrf52nrf52810nrf52811nrf52840temperature & humidity sensor
105 Posts 11 Posters 34.1k Views 12 Watching
  • H heinzv
    Once the code is available I would order 10x PCB's.
    Also, do you have a link to the nRF52832 module? (a 840 version would be also very nice :-))
    ok, I just odered the 5 PCB Sets.
    Beside the link to the nRF52832 Module, please provide also the link to the e-Paper Module.
    berkseoB
    berkseoB
    berkseo
    @heinzv said in πŸ’¬ EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
    Code in the work. BOM added.
    • tbowmoT tbowmo
      Really nice design..
      Could you please post the schematics / board files as well, as this is a openhardware site.
      Also if you upload the gerber files directly (not in a zip / rar file), then the openhardware.io site is able to render 3D views of the boards etc.
      berkseoB
      berkseoB
      berkseo
      @tbowmo
      Thank you for rating. I will lay out the scheme in the near future, it needs to be drawn :). 3D-model does not work, it turns out a piece of cheese. I work at Diptrace( https://diptrace.com ), but this problem is not only mine - https://forum.mysensors.org/topic/9528/temperature-and-humidity-sensor-ver-atmega328-e-ink-display/30
      • H heinzv
        berkseoB
        berkseoB
        berkseo
        @heinzv
        Still no support nRF52840 in the Arduino IDE. What Sandeepmistry implemented uses is the old SDK ...still. I am guided by this editor as it is easy to use for regular users as well as MySensors :)
        • berkseoB
          berkseoB
          berkseo
          #30
          • berkseoB
            berkseoB
            berkseo
            https://youtu.be/sLmR-i1RvpQ
            J 1 Reply Last reply
            • berkseoB berkseo
              J
              J
              jeti
              @berkseo it looks very good! Is testing running good?
              Any hickups ?
              • berkseoB
                berkseoB
                berkseo
                @jeti
                So far I'm satisfied, there is one point with updating the screen. I do not really want to do a full update in the program, but probably have to. Partial update gives the effect of visible lines from the previous symbol. Look at the photo, but it is a problem of code and beauty :)
                • berkseoB berkseo
                  @jeti
                  J
                  J
                  jeti
                  wrote on last edited by jeti
                  #34
                  @berkseo cool thanks for your update, really impressive which detail you are aiming to achieve!
                  I'm planning to get some as soon as possible :-) already gathering the parts. Any chance you upload the PCB?
                  berkseoB 1 Reply Last reply
                  • berkseoB
                    berkseoB
                    berkseo
                    The work of the program was changed. Now the screen update is better. Looks more beautiful :)
                    https://youtu.be/J9Kp3K8ah9g
                    • J jeti
                      berkseoB
                      berkseoB
                      berkseo
                      @jeti said in πŸ’¬ EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
                      I'm planning to get some as soon as possible already gathering the parts. Any chance you upload the PCB?
                      PCB files have already been added, they are in the archives.
                      • H
                        H
                        heinzv
                        wrote on last edited by heinzv
                        #37
                        @berkseo I have ordered already the 10x PCB's and also most of the BOM. I'm also going to order one full mounted PCB (if still available).
                        Can you do me a favour: I need one decimal digit for the temp (not required for hum) but certainly for the temp!
                        Here is a hint/proposal: You can make the decimal digit smaller. I attach one sample from a Xiaomi device (unfortunatly has no wireless and not sure if/how it can be hacked and wireless added).
                        berkseoB 2 Replies Last reply
                        • H heinzv
                          berkseoB
                          berkseoB
                          berkseo
                          Do you want me to change the SOFTWARE a bit? Well, I do not think this is a problem. Question ... Maybe you like some kind of special font? I don’t know which one to use. I can also add technical sensors that can set device parameters through the controller of an intelligent home. An example of such sensors, see the video of my new prototype sensor. ... Now there is only one device left, but I plan to make a little more by the end of next week (I hope :)). Since I started posting my projects on openhardware, I realized that I don’t like to solder for sale, it’s not interesting :)
                          https://www.youtube.com/watch?v=NtYbx0TqP_o
                          https://www.youtube.com/watch?v=HkxbiTkkVXA&t=8s
                          • H heinzv
                            berkseoB
                            berkseoB
                            berkseo
                            Note, the device consists of two printed circuit boards, the order system on openhardware does not allow you to add two printed circuit boards for one device, just formed a second revision. For self-order download archives.
                            • H
                              H
                              heinzv
                              @berkseo Yes, I'd like to change the SW so that the temp shows also one decimal like 21,6 C
                              For the decimal a smaller font likes quite nice such as shown in the picture of the sensor from Xiaomi.
                              I don't have a specical font in mind but rather recommend to take proportional font rather than a mono-space font whcih is rather used for debugger output but not for a productive end user display. The space between the digits is typically smaller/less using a proportional font and looks more elegant than using mono-font.
                              I know, that the 10 PCB's are 5 + 5 (5 sets).
                              I can imagine, that selling soldered PCB's is not a very interesting business and is boring and time consuming for just little amount of money. I was buying one just as reference and will solder the other 5 sets by myself. I know how much effort that is.
                              • H
                                H
                                heinzv
                                @berkseo I have now the PCB's and my parts. Ihave now a few questions
                                1.) When can we expect the sketch code?
                                2.) Can we also have the schematics?
                                3.) How to you solder parts like the TPS62745DSSR? Are you using a reflow oven? or hot air or even a small solder iron?
                                • H heinzv
                                  berkseoB
                                  berkseoB
                                  berkseo
                                  @heinzv
                                  1. Added as a library with an example, see project page on openhardware
                                  2. Soon. ,..on PCB all marking is applied.
                                  3. First, I dissolve the flux paste and solder paste, apply a thin layer on the PCB. Installing a chip, clamping it with a reverse tweezer. Correct the position. It is then heated with a heat gun for soldering. Then remove the excess solder with a soldering iron (if any). It's simple, much harder to solder atmega 328.
                                  I recently modified the boards, moved the elements on the power Board to the other side, made more convenient cutouts for mounting in the case. How to get ready fees, you will receive again this option further. Just all who made orders, please do not refuse payments, now a small delay in sending due to the fact that waiting for a new modification of the Board. All orders will be shipped.
                                  H 1 Reply Last reply
                                  • berkseoB berkseo
                                    @heinzv
                                    H
                                    H
                                    heinzv
                                    @berkseo thanks a lot for the demo code. With some small correction I got it working (give some compile errors).
                                    Could you please check if the font90.c is missing (which is used in the code but not found).
                                    And there seem to be a typo (?) in the font36 (gives an error). I changed from Font24_Table to Font36_Table.
                                    sFONT Font36 = {
                                    Font24_Table,
                                    41, /* Width /
                                    46, /
                                    Height */
                                    • H heinzv
                                      sFONT Font36 = {
                                      Font24_Table,
                                      41, /* Width /
                                      46, /
                                      Height */
                                      berkseoB
                                      berkseoB
                                      berkseo
                                      #44
                                      @heinzv
                                      Uploaded the updated archive to Google drive. Download again
                                      • berkseoB berkseo
                                        @heinzv
                                        H
                                        H
                                        heinzv
                                        #45
                                        @berkseo thanks, that version works!
                                        Maybe you can consider the one decimal digit for the temp (21,6 C). Otherwise I'll do some investigations.
                                        The font90 will be too large (maybe font72) or we need a smaller font and the decimal digit can be a smaller font (mix of two fonts for temp e.g. font72 and font48).
                                        Have you found a utility to convert fonts (e.g. TTF from Windwos) to generate matching font's for e-Paper (I have not yet found someting).
                                        Since we have now enough RAM, have you thought about using the e-paper standard lib GxEPD? That has a least better font support (and also partial update)?
                                        • H heinzv
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          @heinzv Yes, I plan to add one-tenth resolution.
                                          Convert numbers and letters to an array in C is simple. I use a program TheDotFactory. http://www.eran.io/the-dot-factory-an-lcd-font-and-image-generator/
                                          I would be glad if someone made his version of the software in the public domain.
                                          Please show photos of your assembled working device.
                                          With your input, this post could be even better πŸ’—
