  3. Sensor measuring force during pulling
3 Posts 2 Posters 989 Views 1 Watching
  • B
    B
    bartseger
    I’m surching a sensor as small
    As
    Possible. It has to kome in a little machine to measure the force during pulling at both sides of the machine. The range of the forces’ll be between 0 and 300kg or 0 till 3000 N
    Anyone can help me witj that?
    Grts
    Bart
    B 1 Reply Last reply
    • B bartseger
      As
      Grts
      Bart
      B
      B
      bartseger
      No help possible?
      Is force measuring so difficult?
      Grts bart
      • nagelcN
        nagelcN
        nagelc
        The 300kg might be a challenge. It seems most ali express load cells are aimed at light weights, or weighing humans.
        Here are some for lighter weights:
        https://www.aliexpress.com/item/1kg-5kg-10kg-small-range-weighing-pressure-sensor-load-cell-set-weight-sensor-set-sensor-HX711AD/32765498523.html
        Here is one for 200kg:
        https://www.aliexpress.com/item/New-Arrival-1PCX-200kg-electronic-platform-scale-load-cell-pressure-balanced-cantilever-load-weight-sensor-New/32703877639.html
        If you can't find one that does 300kg, you could use a lever mechanism to scale the force appropriately. I also saw some adds for custom load cells, but that is more expensive.
