  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 116.9k Views 41 Watching
  • I iteafreely
    It looks like there is a limit of 1 type of each sensor. Is there a way to modify this?
    My use-case is a french sliding glass door. I would like to use a single node with 2 magnetic sensors (one on each end of the node) with the node mounted in the middle of the door, so that if either side is moved the interrupt is triggered.
    U
    U
    user2684
    @iteafreely your understanding is correct. I see two options here: you can either create a new custom sensor inheriting from SensorDoor and adding an additional child and the extra logic you require or create two instances of SensorDoor and playing with hooking functions to make one checking on the other. In this latter case you probably need some additional variables to keep track of the status.
    • R
      R
      reinhold
      wrote on last edited by reinhold
      #179
      @iteafreely I don't think there is a limit of one sensor per type, not even for interrupts like door sensors. You just need to make sure you are using different pins and different child ids for the two magnetic sensors. I'm using 8 analog sensors (MQ-... gas sensors) on eight different pins on the same node and it works just fine.
      Of course, if you need some interdependence on what the two magnetic sensors report, then you must follow @user2684's suggestion of creating a custom sensor (a C++ class derived from an existing sensor class).
      But if you simply want two independent magnetic sensors (for each of the ends of your sliding door), then you can simply create two instances of SensorDoor on two different pins (here pins 3 and 4) and different hardcoded child_id (1 and 2 in this case):
      SensorDoor doorLeft(node,3,1);
      SensorDoor doorRight(node, 4,2);
      Unfortunately, both of them will report to the gateway with name "DOOR" (and there's no way to change it without subclassing SensorDoor), but they will have a different child_id 1 and 2 to distinguish the two values sent by the node.
      You can then use your smart home controller to handle the two door sensors like one.
      U 1 Reply Last reply
      • I iteafreely
        zboblamontZ
        zboblamontZ
        zboblamont
        @iteafreely Not sure of software issues as I don't use NodeManager, but your use-case indicates you do not need to know which door is opened, only that one or both is/are.
        If by magnetic sensor you mean magnet/reed, would a single reed where both doors meet, or two reeds (one on each door end) wired in parallel, to a single interrupt pin not provide this?
        • R reinhold
          U
          U
          user2684
          @reinhold just for completeness, that "DOOR" can be customized too by calling setDescription() of the (only) child of the SensorDoor instance. Thanks!
          • R
            R
            reinhold
            @user2684 Right, thanks for pointing this out. I mixed up the child name that was sent to the controller (which can be changed by e.g.
            void before() {
              doorLeft.children.get(1)->setDescription("Door Left");
              doorRight.children.get(1)->setDescription("Door Right");
              node.before();
            ) and the sensor's _name field, which is printed to the debug output. That "DOOR" debug output cannot be changed without subclassing. But as this is just debug output, it's just a minor nuissance.
            • R reinhold
              void before() {
                node.before();
              U
              U
              user2684
              @reinhold oh you're right I didn't even noticed that DOOR would show up in the debug output, thanks. Anyway with v1.8-dev this should have gone since debug output has been completely re-worked (and made compatible with https://www.mysensors.org/build/parser). Thanks
                MHofer
                hello, I wanted to use the function for FEATURE_CONDITIONAL_REPORT for an LDR sensor but except a value when starting the arduino, no more values are transferred, must be configured for the function specifically something? Node manager 1.8dev
                • M MHofer
                  U
                  U
                  user2684
                  @mhofer a few issues came out with conditional reporting during some recent tests, https://github.com/mysensors/NodeManager/pull/430 just merged into development should have solved them. Could you please give it a try? Thanks!
                  • U
                    U
                    user2684
                    Hello all, NodeManager v1.8 is almost ready and likewise with the previous releases I like to give brave users a few weeks to test it out before actually releasing it. If you are one of those, download it from https://github.com/mysensors/NodeManager/tree/development; for a full list of changes, have a look at https://github.com/mysensors/NodeManager/projects/2.
                    Of course feel free to open a ticket on Github for any issue you could come across. Thanks!
                      maddinthebrain
                      wrote on last edited by maddinthebrain
                      #187
                      Re: 💬 NodeManager
                      Hi @user2684,
                      Hi all,
                      First a great compliment for this work! This should make things just easy, but...
                      It doesn't work for me. I have Ethernet Gateway and a 1wire Tempsensor node. Both flashed with the sketches from tutorials found on the mysensors.org website. Those are working without any problem.
                      Now I have Tsl2561 Lux sensor. This is supported by nodemanager. Just downloaded the latest dev version uncommented two lines as expected, but it the node won't appear.
                      The sketch looks as followed
                      * Copyright (C) 2013-2017 Sensnology AB
                      Template
                      This sketch can be used as a template since containing the most relevant MySensors library configuration settings,
                      NodeManager's settings, all its the supported sensors commented out and a sketch structure fully functional to operate with
                      NodeManager. Just uncomment the settings you need and the sensors you want to add and configure the sensors in before()
                       * MySensors node configuration
                      // General settings
                      #define SKETCH_NAME "NodeManager"
                      #define SKETCH_VERSION "1.0"
                      //#define MY_NODE_ID 99
                      // NRF24 radio settings
                      //#define MY_RF24_CHANNEL 125
                      //#define MY_RF24_DATARATE RF24_250KBPS
                      // RFM69 radio settings
                      //#define MY_RFM69_FREQUENCY RFM69_433MHZ
                      //#define MY_IS_RFM69HW
                      //#define MY_RFM69_NEW_DRIVER
                      //#define MY_RFM69_NETWORKID 100
                      //#define MY_RF69_IRQ_PIN D1
                      //#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
                      //#define MY_RF69_SPI_CS D2
                      //#define MY_RFM69_ATC_MODE_DISABLED
                      // RFM95 radio settings
                      //#define MY_RADIO_RFM95
                      //#define MY_RFM95_FREQUENCY (RFM95_868MHZ)
                      //#define MY_RFM95_MAX_POWER_LEVEL_DBM (20)
                      //#define MY_RFM95_IRQ_PIN D1
                      //#define MY_RFM95_IRQ_NUM MY_RFM95_IRQ_PIN
                      //#define MY_RFM95_CS_PIN D8
                      // RS485 serial transport settings
                      //#define MY_RS485
                      //#define MY_RS485_BAUD_RATE 9600
                      //#define MY_RS485_DE_PIN 2
                      //#define MY_RS485_MAX_MESSAGE_LENGTH 40
                      //#define MY_RS485_HWSERIAL Serial1
                      // Message signing settings
                      //#define MY_SIGNING_SOFT
                      //#define MY_SIGNING_ATSHA204
                      //#define MY_SIGNING_ATSHA204_PIN 4
                      // OTA Firmware update settings
                      //#define OTA_WAIT_PERIOD 300
                      //#define FIRMWARE_MAX_REQUESTS 2
                      //#define MY_OTA_RETRY 2
                      // OTA debug output
                      //#define MY_DEBUG_OTA (0)
                      //#define MY_DEBUG_OTA_DISABLE_ACK
                      // Advanced settings
                      #define MY_BAUD_RATE 9600
                      //#define MY_SMART_SLEEP_WAIT_DURATION_MS 500
                      //#define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE
                      //#define MY_SIGNAL_REPORT_ENABLED
                      // Optimizations when running on 2032 Coin Cell. Also set nodeManager.setSleepBetweenSend(500) and run the board at 1Mhz
                      //#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
                      //#define MY_TRANSPORT_WAIT_READY_MS  5000
                      //#define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 2000
                      //#define MY_PARENT_NODE_ID 0
                       * MySensors gateway configuration
                      // Common gateway settings
                      //#define MY_REPEATER_FEATURE
                      // Serial gateway settings
                      //#define MY_GATEWAY_SERIAL
                      // Ethernet gateway settings
                      //#define MY_GATEWAY_W5100
                      // ESP8266 gateway settings
                      //#define MY_GATEWAY_ESP8266
                      //#define MY_ESP8266_SSID ""
                      //#define MY_ESP8266_PASSWORD ""
                      // Gateway networking settings
                      //#define MY_PORT 5003
                      //#define MY_GATEWAY_MAX_CLIENTS 2
                      //#define MY_USE_UDP
                      // Gateway MQTT settings
                      //#define MY_GATEWAY_MQTT_CLIENT
                      //#define MY_PORT 1883
                      //#define MY_MQTT_CLIENT_ID "mysensors-1"
                      //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
                      //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
                      // Gateway inclusion mode
                      // Gateway Leds settings
                      //#define MY_DEFAULT_ERR_LED_PIN 4
                      //#define MY_DEFAULT_RX_LED_PIN  5
                      //#define MY_DEFAULT_TX_LED_PIN  6
                       * NodeManager configuration
                      #define NODEMANAGER_DEBUG ON
                      #define NODEMANAGER_INTERRUPTS ON
                      #define NODEMANAGER_SLEEP OFF
                      #define NODEMANAGER_RECEIVE OFF
                      #define NODEMANAGER_DEBUG_VERBOSE ON
                      #define NODEMANAGER_POWER_MANAGER OFF
                      #define NODEMANAGER_CONDITIONAL_REPORT OFF
                      #define NODEMANAGER_EEPROM OFF
                      #define NODEMANAGER_TIME OFF
                      #define NODEMANAGER_RTC OFF
                      #define NODEMANAGER_SD OFF
                      #define NODEMANAGER_HOOKING OFF
                      #define NODEMANAGER_OTA_CONFIGURATION OFF
                      #define NODEMANAGER_SERIAL_INPUT OFF
                      // import NodeManager library (a nodeManager object will be then made available)
                      #include <MySensors_NodeManager.h>
                       * Add your sensors
                      //PowerManager power(5,6);
                      //#include <sensors/SensorBattery.h>
                      //SensorBattery battery;
                      //#include <sensors/SensorConfiguration.h>
                      //SensorConfiguration configuration;
                      //#include <sensors/SensorSignal.h>
                      //SensorSignal signal;
                      //#include <sensors/SensorAnalogInput.h>
                      //SensorAnalogInput analog(A0);
                      //#include <sensors/SensorLDR.h>
                      //SensorLDR ldr(A0);
                      //#include <sensors/SensorRain.h>
                      //SensorRain rain(A0);
                      //#include <sensors/SensorSoilMoisture.h>
                      //SensorSoilMoisture soil(A0);
                      //#include <sensors/SensorThermistor.h>
                      //SensorThermistor thermistor(A0);
                      //#include <sensors/SensorML8511.h>
                      //SensorML8511 ml8511(A0);
                      //#include <sensors/SensorACS712.h>
                      //SensorACS712 acs712(A0);
                      //#include <sensors/SensorDigitalInput.h>
                      //SensorDigitalInput digitalIn(6);
                      //#include <sensors/SensorDigitalOutput.h>
                      //SensorDigitalOutput digitalOut(6);
                      //#include <sensors/SensorRelay.h>
                      //SensorRelay relay(6);
                      //#include <sensors/SensorLatchingRelay1Pin.h>
                      //SensorLatchingRelay1Pin latching1pin(6);
                      //#include <sensors/SensorLatchingRelay2Pins.h>
                      //SensorLatchingRelay2Pins latching2pins(6,7);
                      //#include <sensors/SensorDHT11.h>
                      //SensorDHT11 dht11(6);
                      //#include <sensors/SensorDHT22.h>
                      //SensorDHT22 dht22(6);
                      //#include <sensors/SensorSHT21.h>
                      //SensorSHT21 sht21;
                      //#include <sensors/SensorHTU21D.h>
                      //SensorHTU21D htu21;
                      //#include <sensors/SensorInterrupt.h>
                      //SensorInterrupt interrupt(3);
                      //#include <sensors/SensorDoor.h>
                      //SensorDoor door(3);
                      //#include <sensors/SensorMotion.h>
                      //SensorMotion motion(3);
                      //#include <sensors/SensorDs18b20.h>
                      //SensorDs18b20 ds18b20(6);
                      //#include <sensors/SensorBH1750.h>
                      //SensorBH1750 bh1750;
                      //#include <sensors/SensorMLX90614.h>
                      //SensorMLX90614 mlx90614;
                      //#include <sensors/SensorBME280.h>
                      //SensorBME280 bme280;
                      //#include <sensors/SensorBMP085.h>
                      //SensorBMP085 bmp085;
                      //#include <sensors/SensorBMP180.h>
                      //SensorBMP180 bmp180;
                      //#include <sensors/SensorBMP280.h>
                      //SensorBMP280 bmp280;
                      //#include <sensors/SensorSonoff.h>
                      //SensorSonoff sonoff;
                      //#include <sensors/SensorHCSR04.h>
                      //SensorHCSR04 hcsr04(6,7);
                      //#include <sensors/SensorMCP9808.h>
                      //SensorMCP9808 mcp9808;
                      //#include <sensors/SensorMQ.h>
                      //SensorMQ mq(A0);
                      //#include <sensors/SensorMHZ19.h>
                      //SensorMHZ19 mhz19(6,7);
                      //#include <sensors/SensorAM2320.h>
                      //SensorAM2320 am2320;
                      #include <sensors/SensorTSL2561.h>
                      SensorTSL2561 tsl2561;
                      //#include <sensors/SensorPT100.h>
                      //SensorPT100 pt100(6);
                      //#include <sensors/SensorDimmer.h>
                      //SensorDimmer dimmer(3);
                      //#include <sensors/SensorRainGauge.h>
                      //SensorRainGauge rainGauge(3);
                      //#include <sensors/SensorPowerMeter.h>
                      //SensorPowerMeter powerMeter(3);
                      //#include <sensors/SensorWaterMeter.h>
                      //SensorWaterMeter waterMeter(3);
                      //#include <sensors/SensorPlantowerPMS.h>
                      //SensorPlantowerPMS pms(6,7);
                      //#include <sensors/SensorVL53L0X.h>
                      //SensorVL53L0X vl53l0x(3);
                      //#include <sensors/DisplaySSD1306.h>
                      //DisplaySSD1306 ssd1306;
                      //#include <sensors/SensorSHT31.h>
                      //SensorSHT31 sht31;
                      //#include <sensors/SensorSI7021.h>
                      //SensorSI7021 si7021;
                      //#include <sensors/SensorChirp.h>
                      //SensorChirp chirp;
                      //#include <sensors/DisplayHD44780.h>
                      //DisplayHD44780 hd44780;
                      //#include <sensors/SensorTTP.h>
                      //SensorTTP ttp;
                      //#include <sensors/SensorServo.h>
                      //SensorServo servo(6);
                      //#include <sensors/SensorAPDS9960.h>
                      //SensorAPDS9960 apds9960(3);
                      //#include <sensors/SensorNeopixel.h>
                      //SensorNeopixel neopixel(6);
                      //#include <sensors/SensorSDS011.h>
                      //SensorSDS011 sds011(6,7);
                      //#include <sensors/SensorFPM10A.h>
                      //SensorFPM10A fpm10a(4,5);
                      //#include <sensors/SensorPH.h>
                      //SensorPH ph(A0);
                      //#include <sensors/SensorPca9685W.h>
                      //SensorPca9685W pca9685W;
                      //#include <sensors/SensorPca9685Rgb.h>
                      //SensorPca9685Rgb pca9685Rgb;
                      //#include <sensors/SensorPca9685Rgbw.h>
                      //SensorPca9685Rgbw pca9685Rgbw;
                      //#include <sensors/SensorDSM501A.h>
                      //SensorDSM501A DSM501A;
                      //#include <sensors/SensorPN532.h>
                      //SensorPN532 pn532;
                      //#include <sensors/SensorCCS811.h>
                      //SensorCCS811 ccs811;
                      //#include <sensors/SensorGSM.h>
                      //SensorGSM gsm(6,7);
                       * Main Sketch
                      // before
                      void before() {
                         * Configure your sensors
                        // report measures of every attached sensors every 10 seconds
                        nodeManager.setReportIntervalSeconds(10);
                        // report measures of every attached sensors every 10 minutes
                        //nodeManager.setReportIntervalMinutes(10);
                        // set the node to sleep in 30 seconds cycles
                        //nodeManager.setSleepSeconds(30);
                        // set the node to sleep in 5 minutes cycles
                        //nodeManager.setSleepMinutes(5);
                        // report battery level every 10 minutes
                        //battery.setReportIntervalMinutes(10);
                        // set an offset to -1 to a thermistor sensor
                        //thermistor.setOffset(-1);
                        // change the id of a the first child of a sht21 sensor
                        //sht21.children.get(1)->setChildId(5);
                        // report only when the analog value is above 40%
                        //analog.children.get(1)->setMinThreshold(40);
                        // power all the nodes through dedicated pins
                        //nodeManager.setPowerManager(power);
                        // call NodeManager before routine
                        nodeManager.before();
                      // presentation
                        nodeManager.presentation();
                      // setup
                        nodeManager.setup();
                      // loop
                        nodeManager.loop();
                      #if NODEMANAGER_RECEIVE == ON
                      // receive
                        nodeManager.receive(message);
                      #if NODEMANAGER_TIME == ON
                      // receiveTime
                        nodeManager.receiveTime(ts);
                      Now what's wrong, what's missing?
                      Help is highly appreciated! Thanks
                      Martin
                      • A
                        alfredosc8
                        wrote on last edited by alfredosc8
                        #188
                        Did same body the port on Intel Edison? Arduino IDE is not finding SerialPort.h ?
                        • M maddinthebrain
                          Re: 💬 NodeManager
                          Hi @user2684,
                          Hi all,
                          Template
                          // General settings
                          //#define MY_RS485
                          // OTA debug output
                           * Add your sensors
                          //SensorMQ mq(A0);
                          //SensorTTP ttp;
                          //SensorPH ph(A0);
                           * Main Sketch
                          // before
                          void before() {
                          // presentation
                          // setup
                          // loop
                            nodeManager.loop();
                          // receive
                          // receiveTime
                          Martin
                          U
                          U
                          user2684
                          @maddinthebrain sorry for the huge delay...would you mind sharing the logs? Also feel free to open an issue on https://github.com/mysensors/NodeManager/issues with the logs. Thanks!
                          • U
                            U
                            user2684
                            Hello All, NodeManager v1.8 has just been released! I've opened up as usual a dedicated thread on the forum containing all the details of new release: https://forum.mysensors.org/topic/9944/nodemanager-v1-8-now-available
                            • RPunktR
                              RPunktR
                              RPunkt
                              wrote on last edited by RPunkt
                              #191
                              Question about PowerManger:
                              I am a bit confused or I can't find the right information.
                              I have an Ultrasonic sensor (SensorHCSR04) that needs to be only powered in case of measuring, due to power consumption.
                              An the sensor needs to be switched on a time before the actual measuring starts.
                              So my first approach was to switch the
                              #define NODEMANAGER_POWER_MANAGER ON
                              Then I set
                               nodeManager.setPowerPins(5,6,500)
                              Where I a a bit surprised, why I need two pins (for vcc and ground)?
                              At what logic level are the when the PowerManager switches to ON or OFF?
                              Do I need to connect both pins, or is the vcc- connection enough?
                              Anyway, somehow it did not work with me. It seemed, that the pins are not switched in that way, that pin5 goes to ground and pin 6 goes to 3,3 volt.
                              So I found that thing :
                              But here is no timing possible.
                              Am I missing something?
                              • RPunktR RPunkt
                                Then I set
                                U
                                U
                                user2684
                                @rpunkt you don't necessarily need to use an additional pin for ground, just set the value to -1 in case you don't need it (https://github.com/mysensors/NodeManager/blob/master/nodemanager/PowerManager.cpp#L34). The logic is when PowerManager is set, at the end of a sleep cycle, the virtual vcc pin is set to HIGH and all the sensors' loop are executed, then is set back to LOW and board goes back to sleep.
                                To use it for all the sensors try just with:
                                PowerManager power(5,6, 500);
                                Also ensure the sensor can work with the limited current the arduino's pin is able to provide. Thanks
                                RPunktR 1 Reply Last reply
                                • U user2684
                                  RPunktR
                                  RPunktR
                                  RPunkt
                                  @user2684 Thanks for the advice. Now I got it running.:yum::pray:
                                  • RPunktR
                                    RPunktR
                                    RPunkt
                                    @user2684
                                    Hello, it is me again. Going the next steps.
                                    Now I want to operate another sensor (SensorVL53L0X).
                                    this sensor should transmit the distance and the battery voltage every hour. in between it should sleep.
                                    The normal reporting interval of the battery is once every hour
                                    I set setReportIntervalHours(1); to report the sensor value.
                                    But how do I set the node to sleep in between?
                                    setSleepOrWait(True); and sleepBetweenSend(); ?
                                    or
                                    setSleepOrWait(True); and setSleepMinutes(60); ?
                                    And is the NodeManager so clever that all the transmits are at the same time,
                                    meaning once every hour the sensor value and the battery voltage is transmitted.
                                    • RPunktR RPunkt
                                      @user2684
                                      or
                                      U
                                      U
                                      user2684
                                      @rpunkt you just need to set setSleepMinutes() which will automatically put the board to sleep for the given timeframe. At the end of it, any sensor due to report at that time or before it, will do
                                      • U user2684
                                        RPunktR
                                        RPunktR
                                        RPunkt
                                        @user2684 Thanks a lot
