  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.6k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    You should use username and not <username>. The same goes for the API key.
    In UI5 you can test your Lua in Vera from APPS -> Develop Apps -> Test Luup code
    Here is a few more examples of variable_get:
    local InAirHum = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 347)
    local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
    local InAirTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 346)
    local InAirQ = luup.variable_get("urn:upnp-org:serviceId:VContainer1", "Variable1", 348)
    • Tomas
    • korttomaK
      korttomaK
      korttoma
      I'm having trouble with one variable to. I would like to have the status of a qubino switch in the same graph.
      I tried this:
      local VentOn = 100 luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
      It gives me the value 100 in the graph. Please let me know what this 100 in front of the luup.variable_get does. If I remove it the Luup code fails.
      • Tomas
      S 1 Reply Last reply
      • korttomaK korttoma
        I tried this:
        samppa
        wrote on last edited by samppa
        I tried this:
        Actually there should be asterisk character between 100 and the luup.variable_get and the (forum editor does not show that) since the returned value 1 or 0 is scaled to 100 so try:
        local VentOn = 100 * luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
        Then you get 100 if binary light is on. Remove the 100 if you like it to be 1 or 0.
        korttomaK 1 Reply Last reply
        • NuubiN Nuubi
          Uh...oh...still.. do you need to initialize the graph or what? Still not getting this to work, sorry for being such a dummie :-E
          samppa
          You just send the data and the graph named with "filename":"xxxx" gets created if not yet existing.
          NuubiN 1 Reply Last reply
          • S samppa
            I tried this:
            korttomaK
            korttomaK
            korttoma
            I thought it was a multiplier of some kind. Anyhow the code fails allso if I add the asterisk so I thik it has a problem with:
            Any suggestions what I should try instead? Tried also this but no luck:
            luup.variable_get("urn:micasaverde-com:serviceId:BinaryLight1", "Status", 356)
            • Tomas
            • korttomaK
              korttomaK
              korttoma
              Had a chat with @BulldogLowell and he taught me that you can hover the mouse on a variable to check the complete variable name so it turned out I had to use the following:
              luup.variable_get("urn:micasaverde-com:serviceId:SwitchPower1", "Status", 356)
              • Tomas
              • S samppa
                NuubiN
                NuubiN
                Nuubi
                @samppa Yep, works now, thanks!
                The problem turned out to be the actual value I wanted to send. Need to figure out how to read MySensors based values in LUA...
                • NuubiN Nuubi
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @Nuubi
                  have you tried luup.inet.wget( )
                  local brightness = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 118)
                  luup.inet.wget("192.168.1.50//?brightLevel="..brightness.."&", 1)
                  • korttomaK
                    korttomaK
                    korttoma
                    Anyone figured out a way to add another variable to an old graph without deleting the file from plot.ly? Seems like it does not include the new variable unless you delete and create a new file.
                    • Tomas
                      samppa
                      I have noticed the same thing; If you want to add a trace you need to delete the file..
                      So perhaps it is wise to be prepared and add a few extra traces for some future use.
                      • S samppa
                        korttomaK
                        korttomaK
                        korttoma
                        Good suggestion for a workaround but it does not seem to pick up name changes for the trace either. Tried also to edit one of the plots on the website but when I wanted to save I could not save the changes to the file used by "Vera". I had to save the file with a different name so no editing seems to be possible.
                        • Tomas
                        • korttomaK
                          korttomaK
                          korttoma
                          Since the nightly heal at 2 in the morning no data is transferred to plot.ly any more :( anyone else see this and know how to solv it?
                          • Tomas
                          DwaltD 1 Reply Last reply
                            DwaltD
                            DwaltD
                            Dwalt
                            @korttoma
                            My plots stopped last night as well, last data point transmitted was at 12:03am GMT, but not after a nightly heal.
                            -Dwalt
                            • korttomaK
                              korttomaK
                              korttoma
                              12 GMT is 2 in my timezone so I guess it was just a coincidence that it happened at the time of the heel. Maybe plot.ly blocked us for some reason.
                              • Tomas
                                samppa
                                My graphs stopped as well. I have asked what is going on.. Let's see when it gets back up again..
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  I sent them some feedback to but have not heard anything yet. Maybe we should try the "Streaming API" instead?
                                  • Tomas
                                  DwaltD S 2 Replies Last reply
                                    DwaltD
                                    DwaltD
                                    Dwalt
                                    wrote on last edited by Dwalt
                                    #23
                                    @korttoma
                                    I tried to set up a new graph using the REST API and could not get it to register with Plot.ly. Without any explanation from Plot.ly, I tried sending the same data streams to ThingSpeak.com and it set up with out any trouble. The API is slightly different but just as easy to use. I set up a scene to run every 15 minutes with the following code:
                                    -- Get Light Levels
                                    local LR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                                    local BR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 55)
                                    - - Get Temps
                                    local LR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 46)
                                    local BR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 54)
                                    local OUT_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 23)
                                    -- Send data to ThingSpeak.com
                                    local http = require("socket.http")
                                    http.TIMEOUT = 5
                                    result, status = http.request("http://api.thingspeak.com/update?key=Insert Your API Key here&field1="..LR_TEMP.."&field2="..BR_TEMP.."&field3="..OUT_TEMP.."&field4="..LR_LIGHT_LEVEL.."&field5="..BR_LIGHT_LEVEL.."", "run=run") ````
                                    The service has a limited functionality to manipulate your data but the base configuration is easy to tweak and can be made public or private.  See [here for my sample data](https://thingspeak.com/channels/25629).
                                    ...plus it is free to use.
                                      samppa
                                      #24
                                      @korttoma
                                      Now plot.ly is back up again.
                                      Apparently they upgraded the infrastructure and broke something. Hopefully that does not happen too often..
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        Yes, now it is working again. Maybe you should try again @Dwalt ?
                                        • Tomas
                                          DwaltD
                                          DwaltD
                                          Dwalt
                                          @korttoma
                                          I noticed it back online right after I posted my Thingspeak scene. I had not deleted my Plot.ly scenes and they continued to send http requests during the outage and when Plot.ly came back online, my data resumed plotting.
                                          I have both services running right now plotting similar data and I will leave them both running to test reliability and quirks. It seems the time reporting drifts a little in Plot.ly. I am also going to test Beebotte.
