  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.5k Views 2 Watching
  • NuubiN Nuubi
    Uh...oh...still.. do you need to initialize the graph or what? Still not getting this to work, sorry for being such a dummie :-E
    samppa
    You just send the data and the graph named with "filename":"xxxx" gets created if not yet existing.
    NuubiN 1 Reply Last reply
    • S samppa
      @korttoma said:
      I'm having trouble with one variable to. I would like to have the status of a qubino switch in the same graph.
      I tried this:
      local VentOn = 100 luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
      It gives me the value 100 in the graph. Please let me know what this 100 in front of the luup.variable_get does. If I remove it the Luup code fails.
      Actually there should be asterisk character between 100 and the luup.variable_get and the (forum editor does not show that) since the returned value 1 or 0 is scaled to 100 so try:
      local VentOn = 100 * luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
      Then you get 100 if binary light is on. Remove the 100 if you like it to be 1 or 0.
      korttomaK
      korttomaK
      korttoma
      I thought it was a multiplier of some kind. Anyhow the code fails allso if I add the asterisk so I thik it has a problem with:
      Any suggestions what I should try instead? Tried also this but no luck:
      luup.variable_get("urn:micasaverde-com:serviceId:BinaryLight1", "Status", 356)
      • Tomas
      • korttomaK
        korttomaK
        korttoma
        Had a chat with @BulldogLowell and he taught me that you can hover the mouse on a variable to check the complete variable name so it turned out I had to use the following:
        luup.variable_get("urn:micasaverde-com:serviceId:SwitchPower1", "Status", 356)
        • Tomas
        • S samppa
          NuubiN
          NuubiN
          Nuubi
          @samppa Yep, works now, thanks!
          The problem turned out to be the actual value I wanted to send. Need to figure out how to read MySensors based values in LUA...
          • NuubiN Nuubi
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @Nuubi
            have you tried luup.inet.wget( )
            local brightness = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 118)
            luup.inet.wget("192.168.1.50//?brightLevel="..brightness.."&", 1)
            • korttomaK
              korttomaK
              korttoma
              Anyone figured out a way to add another variable to an old graph without deleting the file from plot.ly? Seems like it does not include the new variable unless you delete and create a new file.
              • Tomas
              S 1 Reply Last reply
              • korttomaK korttoma
                samppa
                I have noticed the same thing; If you want to add a trace you need to delete the file..
                So perhaps it is wise to be prepared and add a few extra traces for some future use.
                korttomaK 1 Reply Last reply
                • S samppa
                  korttomaK
                  korttomaK
                  korttoma
                  Good suggestion for a workaround but it does not seem to pick up name changes for the trace either. Tried also to edit one of the plots on the website but when I wanted to save I could not save the changes to the file used by "Vera". I had to save the file with a different name so no editing seems to be possible.
                  • Tomas
                  • korttomaK
                    korttomaK
                    korttoma
                    Since the nightly heal at 2 in the morning no data is transferred to plot.ly any more :( anyone else see this and know how to solv it?
                    • Tomas
                    DwaltD 1 Reply Last reply
                      DwaltD
                      DwaltD
                      Dwalt
                      @korttoma
                      My plots stopped last night as well, last data point transmitted was at 12:03am GMT, but not after a nightly heal.
                      -Dwalt
                      • korttomaK
                        korttomaK
                        korttoma
                        12 GMT is 2 in my timezone so I guess it was just a coincidence that it happened at the time of the heel. Maybe plot.ly blocked us for some reason.
                        • Tomas
                          samppa
                          My graphs stopped as well. I have asked what is going on.. Let's see when it gets back up again..
                          • korttomaK
                            korttomaK
                            korttoma
                            I sent them some feedback to but have not heard anything yet. Maybe we should try the "Streaming API" instead?
                            • Tomas
                            DwaltD S 2 Replies Last reply
                              DwaltD
                              DwaltD
                              Dwalt
                              wrote on last edited by Dwalt
                              #23
                              @korttoma
                              I tried to set up a new graph using the REST API and could not get it to register with Plot.ly. Without any explanation from Plot.ly, I tried sending the same data streams to ThingSpeak.com and it set up with out any trouble. The API is slightly different but just as easy to use. I set up a scene to run every 15 minutes with the following code:
                              -- Get Light Levels
                              local LR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                              local BR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 55)
                              - - Get Temps
                              local LR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 46)
                              local BR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 54)
                              local OUT_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 23)
                              -- Send data to ThingSpeak.com
                              local http = require("socket.http")
                              http.TIMEOUT = 5
                              result, status = http.request("http://api.thingspeak.com/update?key=Insert Your API Key here&field1="..LR_TEMP.."&field2="..BR_TEMP.."&field3="..OUT_TEMP.."&field4="..LR_LIGHT_LEVEL.."&field5="..BR_LIGHT_LEVEL.."", "run=run") ````
                              The service has a limited functionality to manipulate your data but the base configuration is easy to tweak and can be made public or private.  See [here for my sample data](https://thingspeak.com/channels/25629).
                              ...plus it is free to use.
                                samppa
                                wrote on last edited by samppa
                                #24
                                @korttoma
                                Now plot.ly is back up again.
                                Apparently they upgraded the infrastructure and broke something. Hopefully that does not happen too often..
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  Yes, now it is working again. Maybe you should try again @Dwalt ?
                                  • Tomas
                                    DwaltD
                                    DwaltD
                                    Dwalt
                                    @korttoma
                                    I noticed it back online right after I posted my Thingspeak scene. I had not deleted my Plot.ly scenes and they continued to send http requests during the outage and when Plot.ly came back online, my data resumed plotting.
                                    I have both services running right now plotting similar data and I will leave them both running to test reliability and quirks. It seems the time reporting drifts a little in Plot.ly. I am also going to test Beebotte.
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      There was an outage again last night. No data uploaded for 3h. Was it just me or plot.ly?
                                      • Tomas
                                        DwaltD
                                        DwaltD
                                        Dwalt
                                        @korttoma I got it too.
                                        • D
                                          derrij
